I have exactly the same problem. Using windows 11. Using Google Chrome. Arduino cloud has worked just fine for a long time. On 4 June, using the USB port no longer worked. Was told to install ArduinoCreateAgent. This has been done many times. Have uninstalled previous version of CreateAgent. Have tested with Edge and Firefox. Exactly the same problem.
Have installed according to the link that xfpd refers to.
Hi @ptillisch . No, its not there in the taskbar.
I have now tried Arduino Cloud on another PC, which has not been used for this before. Installed CreateAgent on this as well. Behaves in the same way. Cannot find CreateAgent. But what I see is that after installing CreateAgent, it goes to the taskbar / notification area for a few seconds and then disappears. So I can't check if it's off or on.
On 3 June this worked perfectly fine. Then had another version on CreateAgent. When starting the PC on 4 June, a question popped up about which browser I want as default. Windows may have been updated.
I'm going to ask you to run Arduino Create Agent from the command line, then post the output in a reply here.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
If Arduino Create Agent is running, terminate it by clicking the Arduino icon in the Windows "notification area" and then selecting "Quit Agent" from the menu.
Right click the Windows "Start" button.
A context menu will open.
Select "Search" from the context menu.
The Windows "Start" menu will open with a search field selected.
Type windows powershell ise in the search field.
Select "Windows PowerShell ISE" from the search results.
A "Windows PowerShell ISE" window will open.
Repeat the operation in Arduino Cloud, just as you did before when you encountered the problem.
Switch back to the "Windows PowerShell ISE" window.
Select Edit > Select All from the Windows PowerShell ISE menus.
All the text in the terminal panel of the window will be selected.
Select Edit > Copy from the Windows PowerShell ISE menus.
This will copy the selected text to the clipboard.
Open a forum reply here by clicking the "Reply" button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press the Ctrl+V keyboard shortcut.
This will paste the output into the code block.
Move the cursor outside of the code block markup before you add any additional text to your reply.
Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
There seems to be several users having this same issue starting around a week a go. I have tried installing older versions of ACA, but to no avail. May there be something with a new Windows update creating this issue? Seems firewall has become more strict. Even if I allow ACA through it crashes.
@nesogram
I have only uploaded via USB. Done it several times now. Had no problems with USB.
Have not used OTA because I shall write a new program.
OTA have been worked just fine earlyer. The OTA icon is active.
Hello, I had the same problem, I tried uninstalling, even initiating the Arduino Agent through CLI, nothing worked. I just tried with Google Chrome and finally I could do it, I guess Firefox, Edge and Brave don't work to do that, idk why
