CNC shield, steppers and servo wiring
I’m using an Arduino Uno in conjunction with CNC shield with 4 drivers a4988. I also need to run servo mg996r as a gripper. I can’t get the gripper to operate properly. I am assuming this is a wiring issue instead of code as the stepper motors operate fine until I hook up the servo. I’ve attached a wiring diagram I was provided and also where I’ve attached the ground wires. If you can help with my mistake it would appreciated.
Write a minimal program that ONLY tests the gripper and debug your wiring that way.
We can see neither.
What does it do that is not what you want?
servo signal
Green rectangle, servo signal to ground.
Post photos of the wiring, please.
Post your code, in code tags, please.
You noted the signal wire for the servo connected to ground, should that not be connected there? I will post code and pictures unless this is the issue. Thanks for the reply!
as GF asked, how exactly it it not operating properly? Does it not run at all? Skipping steps?
yup...get the gripper running on its own, then add he steppers back in, see what happens.
Is it just connecting the sevro that does it, or is is it possible the code you add to use it is causing you problems?
please don't be insulted by this question, but you are getting a high signal to the enable pins on the step sticks, correct? You could try disabling those one by one and see what happens, no guarantees, but something you can try easily.
lastly, make sure your grounds are common, the shield might be doing that internally, I have no idea from the info provided.
I can get the servo to operate with minimum code and on another Uno and the wires I have attached to the gripper on the robot. It does not work when I use it in conjunction with CNC shield. So what I do know so far is the gripper is functional, the wiring is fine to the gripper.
I can't seem to get the grippers working without the steppers either, I have another UNO and I tried that with another CNC shield attached.
The 4 steppers work fine without the servo. When I connect the servo wiring things go a little off the rails and operate errantly when I use the servo slider (it's controlled with Controlp5 library). Here is the Arduino code. Hopefully I posted that correctly. If not please let me know.
No worries on insulting me. I do not know if all the grounds are common on the shield either. If someone else can help that'd be helpful.
   Arduino based SCARA Robot
   by Dejan, www.HowToMechatronics.com
   AccelStepper: http://www.airspayce.com/mikem/arduino/AccelStepper/index.html
#include <AccelStepper.h>
#include <Servo.h>
#include <math.h>
#define limitSwitch1 11
#define limitSwitch2 10
#define limitSwitch3 9
#define limitSwitch4 A3
// Define the stepper motors and the pins the will use
AccelStepper stepper1(1, 2, 5); // (Type:driver, STEP, DIR)
AccelStepper stepper2(1, 3, 6);
AccelStepper stepper3(1, 4, 7);
AccelStepper stepper4(1, 12, 13);
Servo gripperServo;  // create servo object to control a servo
double x = 10.0;
double y = 10.0;
double L1 = 228; // L1 = 228mm
double L2 = 136.5; // L2 = 136.5mm
double theta1, theta2, phi, z;
int stepper1Position, stepper2Position, stepper3Position, stepper4Position;
const float theta1AngleToSteps = 44.444444;
const float theta2AngleToSteps = 35.555555;
const float phiAngleToSteps = 10;
const float zDistanceToSteps = 100;
byte inputValue[5];
int k = 0;
String content = "";
int data[10];
int theta1Array[100];
int theta2Array[100];
int phiArray[100];
int zArray[100];
int gripperArray[100];
int positionsCounter = 0;
  pinMode(limitSwitch1, INPUT_PULLUP);
  pinMode(limitSwitch2, INPUT_PULLUP);
  pinMode(limitSwitch3, INPUT_PULLUP);
  pinMode(limitSwitch4, INPUT_PULLUP);
  // Stepper motors max speed
  stepper1.setMaxSpeed(4000);
  stepper1.setAcceleration(2000);
  stepper2.setMaxSpeed(4000);
  stepper2.setAcceleration(2000);
  stepper3.setMaxSpeed(4000);
  stepper3.setAcceleration(2000);
  stepper4.setMaxSpeed(4000);
  stepper4.setAcceleration(2000);
  gripperServo.attach(A0, 600, 2500);
  // initial servo value - open gripper
  data[6] = 180;
  gripperServo.write(data[6]);
  data[5] = 100;
  homing();
  if (Serial.available()) {
    content = Serial.readString(); // Read the incomding data from Processing
    // Extract the data from the string and put into separate integer variables (data[] array)
    for (int i = 0; i < 10; i++) {
      int index = content.indexOf(","); // locate the first ","
      data[i] = atol(content.substring(0, index).c_str()); //Extract the number from start to the ","
      content = content.substring(index + 1); //Remove the number from the string
     data[0] - SAVE button status
     data[1] - RUN button status
     data[2] - Joint 1 angle
     data[3] - Joint 2 angle
     data[4] - Joint 3 angle
     data[5] - Z position
     data[6] - Gripper value
     data[7] - Speed value
     data[8] - Acceleration value
    // If SAVE button is pressed, store the data into the appropriate arrays
    if (data[0] == 1) {
      theta1Array[positionsCounter] = data[2] * theta1AngleToSteps; //store the values in steps = angles * angleToSteps variable
      theta2Array[positionsCounter] = data[3] * theta2AngleToSteps;
      phiArray[positionsCounter] = data[4] * phiAngleToSteps;
      zArray[positionsCounter] = data[5] * zDistanceToSteps;
      gripperArray[positionsCounter] = data[6];
      positionsCounter++;
    // clear data
    if (data[0] == 2) {
      // Clear the array data to 0
      memset(theta1Array, 0, sizeof(theta1Array));
      memset(theta2Array, 0, sizeof(theta2Array));
      memset(phiArray, 0, sizeof(phiArray));
      memset(zArray, 0, sizeof(zArray));
      memset(gripperArray, 0, sizeof(gripperArray));
  // If RUN button is pressed
  while (data[1] == 1) {
    stepper1.setSpeed(data[7]);
    stepper2.setSpeed(data[7]);
    stepper3.setSpeed(data[7]);
    stepper4.setSpeed(data[7]);
    stepper1.setAcceleration(data[8]);
    stepper2.setAcceleration(data[8]);
    stepper3.setAcceleration(data[8]);
    stepper4.setAcceleration(data[8]);
    // execute the stored steps
    for (int i = 0; i <= positionsCounter - 1; i++) {
      if (data[1] == 0) {
      stepper1.moveTo(theta1Array[i]);
      stepper2.moveTo(theta2Array[i]);
      stepper3.moveTo(phiArray[i]);
      stepper4.moveTo(zArray[i]);
      while (stepper1.currentPosition() != theta1Array[i] || stepper2.currentPosition() != theta2Array[i] || stepper3.currentPosition() != phiArray[i] || stepper4.currentPosition() != zArray[i]) {
        stepper1.run();
        stepper2.run();
        stepper3.run();
        stepper4.run();
      if (i == 0) {
        gripperServo.write(gripperArray[i]);
      else if (gripperArray[i] != gripperArray[i - 1]) {
        delay(800); // wait 0.8s for the servo to grab or drop - the servo is slow
      //check for change in speed and acceleration or program stop
        if (data[1] == 0) {
        // change speed and acceleration while running the program
      // execute the stored steps in reverse
      for (int i = positionsCounter - 2; i >= 0; i--) {
      if (data[1] == 0) {
        stepper1.run();
        stepper2.run();
        stepper3.run();
        stepper4.run();
        if (data[1] == 0) {
  stepper1Position = data[2] * theta1AngleToSteps;
  stepper2Position = data[3] * theta2AngleToSteps;
  stepper3Position = data[4] * phiAngleToSteps;
  stepper4Position = data[5] * zDistanceToSteps;
  stepper1.moveTo(stepper1Position);
  stepper2.moveTo(stepper2Position);
  stepper3.moveTo(stepper3Position);
  stepper4.moveTo(stepper4Position);
  while (stepper1.currentPosition() != stepper1Position || stepper2.currentPosition() != stepper2Position || stepper3.currentPosition() != stepper3Position || stepper4.currentPosition() != stepper4Position) {
    stepper1.run();
    stepper2.run();
    stepper3.run();
    stepper4.run();
  delay(100);
  delay(300);
void serialFlush() {
  while (Serial.available() > 0) {  //while there are characters in the serial buffer, because Serial.available is >0
    Serial.read();         // get one character
void homing() {
  // Homing Stepper4
  while (digitalRead(limitSwitch4) != 1) {
    stepper4.setSpeed(1500);
    stepper4.runSpeed();
    stepper4.setCurrentPosition(17000); // When limit switch pressed set position to 0 steps
  delay(20);
  stepper4.moveTo(10000);
  while (stepper4.currentPosition() != 10000) {
    stepper4.run();
  // Homing Stepper3
  while (digitalRead(limitSwitch3) != 1) {
    stepper3.setSpeed(-1100);
    stepper3.runSpeed();
    stepper3.setCurrentPosition(-1662); // When limit switch pressed set position to 0 steps
  delay(20);
  stepper3.moveTo(0);
  while (stepper3.currentPosition() != 0) {
    stepper3.run();
  // Homing Stepper2
  while (digitalRead(limitSwitch2) != 1) {
    stepper2.setSpeed(-1300);
    stepper2.runSpeed();
    stepper2.setCurrentPosition(-5420); // When limit switch pressed set position to -5440 steps
  delay(20);
  stepper2.moveTo(0);
  while (stepper2.currentPosition() != 0) {
    stepper2.run();
  // Homing Stepper1
  while (digitalRead(limitSwitch1) != 1) {
    stepper1.setSpeed(-1200);
    stepper1.runSpeed();
    stepper1.setCurrentPosition(-3955); // When limit switch pressed set position to 0 steps
  delay(20);
  stepper1.moveTo(0);
  while (stepper1.currentPosition() != 0) {
    stepper1.run();
Servo power and ground temp wiring.
The servo signal needs to go to a pin on the shield that is connected to an output from the Uno.
Look in the setup function for the servo.attach(pin);. Connect the servo to the header corresponding to the pin.
Post the code if you want help.
#include <Servo.h>
#include <math.h>
double x = 10.0;
double y = 10.0;
byte inputValue[5];
int k = 0;
int data[10];
int phiArray[100];
int zArray[100];
  data[6] = 180;
  data[5] = 100;
  homing();
    if (data[0] == 1) {
      positionsCounter++;
    // clear data
    if (data[0] == 2) {
      if (data[1] == 0) {
        stepper1.run();
        stepper2.run();
        stepper3.run();
        stepper4.run();
      if (i == 0) {
        if (data[1] == 0) {
      if (data[1] == 0) {
        stepper1.run();
        stepper2.run();
        stepper3.run();
        stepper4.run();
        if (data[1] == 0) {
    stepper1.run();
    stepper2.run();
    stepper3.run();
    stepper4.run();
  delay(100);
  delay(300);
void homing() {
  // Homing Stepper4
  delay(20);
    stepper4.run();
  // Homing Stepper3
  delay(20);
  stepper3.moveTo(0);
    stepper3.run();
  // Homing Stepper2
  delay(20);
  stepper2.moveTo(0);
    stepper2.run();
  // Homing Stepper1
  delay(20);
  stepper1.moveTo(0);
    stepper1.run();
Sorry for the double post on the code. The first one I added must have been flagged because it had the website url on it.
Isn't the code correct, it is showing A0 for the pin where I have the signal wire attached?
It looks like the servo should connect to A0. A0 on the Uno is Abort on the CNC shield.
Yes, that is where I have it connected. There are 2 pins next to abort, white and black rails. I assume the white is positive and black is ground? The wiring diagram shows connected to black/grnd. Is that also correct?
Any other suggestions? Thank you for the help.
All of the pins of the black header go to ground. The pins of the white header go to the Uno pins as shown in this image:
cnc shield Uno pins
Do you have the jumpers in place to connect the A axis driver to pins 12 (step) and pin 13 (dir)?
You have way too much code there for something that doesn't work.
I suggest that you write some test code that just operates a single stepper and the servo. Build up to something that does all four motors and the servo and hopefully you'll get some clues along the way as to what is going wrong.
That’s here correct?
Yes, you got it.
So I thought I had the servo working. Control wire to white abort, positive to 6 v battery pack, ground on 5v/ground pin.
If I move the slider in large increments to operate the servo, somehow it’s feeding power to the Z axis stepper. The stepper moves and then the servo moves. I thought maybe the wires were touching somehow on the post connections, but I can’t find anything. Short increments moving the servo slider in the GUI don’t seem to cause the issue.
Any suggestions on what could cause that?
Wiring has not changed from diagram posted.
:rofl: well put.
Got everything working. I had a loose ground on my temporary battery pack, along with a tight gripper that was possibly causing a stall on the servo. Thanks everyone for the insight, especially groundFungus for posting the helpful connection points. Obviously I’m new to this, but I enjoy learning new things. I’m Grateful people like you guys are willing to help out even when solutions seem obvious. Been learning a lot just by reading other posts.
