Hi, back again after a break!
Thanks to a bunch of you, especially Mr WildBill who basically rewrote my code into something that actually worked
Time to move on, and I'd like to add a pot so the user can adjust the speed without reprogramming the Arduino...
The code below, drives the 1.7A NEMA17 motor approx 900mm fowards and then 900mm reverse in 16 minutes (please ignore the "30 minute" multiplier... needed to double the speed quick at the request of the user and forgot about it! I'll fix it later, but first, I'd like to know, can I actually connect a pot to the Arduino/CNC shield combo, I'm sure this must be possible, but information seems to be unavailable???
I'm using UNO with 4 axis v3 CNC shield, so I can add more machines later, all controlled from here...
// Stepper Code with Limit Switch for
// CNC Shield V2.1 on Y axis by WildBill and me
// Shield loaded with full jumpers for full microsteps
const byte EnablePin = 8;
const byte Y_DirectionPin = 6;
const byte Y_StepPin = 3;
const byte Y_LimitPin = 10;
unsigned long Stepdelay = (432 / 4);Â Â Â //Speed Microseconds 600 = 20mm/min
unsigned long RequiredSteps = (720et99UL * 30); //revolutions(1 minute) * 30 minutes
unsigned long StepCount = 0;
int EndPointDelay = 6660; // Milliseconds
void Step(byte StepPin)
 digitalWrite(StepPin, HIGH);
 delayMicroseconds(Stepdelay);
 digitalWrite(StepPin, LOW);
 StepCount++;
 Serial.println("Starting Mervs Mover");
 pinMode(Y_DirectionPin, OUTPUT);
 pinMode(Y_StepPin, OUTPUT);
 pinMode(EnablePin, OUTPUT);
 digitalWrite(EnablePin, LOW);
 pinMode(Y_LimitPin, INPUT_PULLUP);
 HomeStepper(Y_DirectionPin, Y_StepPin, Y_LimitPin);
 if (StepCount < RequiredSteps)
  Step(Y_StepPin);
  delay(EndPointDelay);
void HomeStepper(byte DirectionPin, byte StepPin, byte LimitPin)
 Serial.println("Home Stepper");
 digitalWrite(DirectionPin, LOW);
 while (digitalRead(LimitPin) == HIGH)
  Step(StepPin);
 StepCount = 0;
 digitalWrite(DirectionPin, HIGH);
 Serial.println("Stepper at home");
Here is the pin to pin map of the CNC shield to the Uno.
You can use any of the analog inputs that you are not using for the pot(s). A4 and A5 are on the CNC shield in the blue box. The cyan box shows where the rest of the analog pins are.
Thanks guys! I even asked the guy who sold the shield, and he thought I'd "struggle" to get a pot to work with the shield, but I was sure it must be possible... here we go again, trying to get my head around Arduino lol
On the header with SCL and SDA there are 5V and ground pins available that you can use to supply the pot. Connect one end of the pot to 5V the other end to ground and the wiper to the pin marked Resume. Read the pot with
const byte analogIn = A2; // resume on CNC shield
 static unsigned long timer = 0;
 unsigned long interval = 1000;
 if (millis() - timer >= interval)
   timer = millis();
   unsigned int analogValue = analogRead(analogIn);
   Serial.print(" analog value = ");
   Serial.println(analogValue);
groundFungus:
On the header with SCL and SDA there are 5V and ground pins available the you can use to supply the pot. Connect one end of the pot to 5V the other end to ground and the wiper to the pin marked Resume. Read the pot with
Wow, this is a great start, thanks... I think I shall try ans spend some time breaking it down before I go hacking at it
So, I ran the code provided by GroundFungus, wired as proposed, with a cheap 10k breadboard pot and, and watched the terminal...
It's interesting that the reading falls from it's start at around 500 and diminishes to below 300, then fluctuates between 280 and 300 (see attachment)... I'm guessing this is just the capacitors doing their thing?
However, as I adjust the pot, I see no change in the figures... Also, tho it still works, I smoked the pot a couple of times before I realized you can't turn the knob all the way to the left! At first I was quite happy, as this position shut down the boards, till smoke appeared from the pot! I am guessing (again) that this is due to the breadboard pot not having an "off" position, and so I need a pot with a switch, which is an outcome I like, as at present the machine is powered up by connecting the 12v power supply direct to the Arduino input. I hope my guess is correct? In the mean time, until I get a decent potentiometer, I may have to raid one of my guitars!
BTW: I just check the 10K pot, which is operating just fine, ranging from approx 150 Ohms to 13K Ohms, so I am trying to understand why there is no change to the reading, which I understand is an integer of the voltage read at a2. I checked the voltage at a2/gnd, which ranges from 0 to 2.0mV, past 2mV and the pot starts to smoke at the stop lol
Sorry about the lengthy note, but I'm just trying to understand what I'm seeing on the terminal, and why nothing changes as I adjust the pot?
I actually connected a 10K linear taper pot as described to my CNC shield and tested the code before I posted the code so I know that it works. The pot should never smoke if connected properly. My guess is that you connected the wiper and one end of the pot to ground and 5V and the other end of the pot to resume (A2). That would cause a dead short at one end of the pot travel. Here is the right way.
groundFungus:
Thanks for this... I think the wiring is correct, see images... red and black are power, and white is the wiper connected to A2, resume.
I wonder if the trimpot is suitable, or has a fault?
