Should start with the fact that I am very new to this but keen to learn...
I wrote a code for some project but can't get exactly what I want out of it...
First, I can't get it to stop as soon as level changes...
Second, due to the first problem not sure if it will cycle the pumps...
Would you be able to help me with this, or explain where are the mistakes and how to solve it?
Many thanks in advance.
// C++ code
const int potentiometerPin = A5;
const int PUMP1_PIN = 9;
const int PUMP2_PIN = 8;
int PrimaryPump = 0; // Assuming 0 for Pump 1, 1 for Pump 2 (can be modified in loop)
const int HIGH_LED_PIN = 7;
const int LOW_LED_PIN = 6;
const int ALARM_PIN = 12;
int primaryPumpPin;
int secondaryPumpPin;
pinMode(PUMP1_PIN, OUTPUT); // Pump 1 Output;
pinMode(PUMP2_PIN, OUTPUT); // Pump 2 Output;
pinMode(HIGH_LED_PIN, OUTPUT); // Red LED to indicate high water level;
pinMode(LOW_LED_PIN, OUTPUT); // Green LED to indicate Low water level;
pinMode(ALARM_PIN, OUTPUT); // Alarm buzzer
// Set pump pins based on PrimaryPump (can be adjusted in loop if needed)
primaryPumpPin = PrimaryPump == 0 ? PUMP1_PIN : PUMP2_PIN;
secondaryPumpPin = PrimaryPump == 0 ? PUMP2_PIN : PUMP1_PIN;
int waterLevel = analogRead(potentiometerPin);
// Handle Low Water Level
if (waterLevel <= 200) {
digitalWrite(ALARM_PIN, LOW); // Alarm Off
digitalWrite(LOW_LED_PIN, HIGH); // Green LED ON
digitalWrite(primaryPumpPin, LOW); // Stop Pump (assuming any pump was running)
digitalWrite(secondaryPumpPin, LOW);
} else if (waterLevel > 200 && waterLevel < 800) {
// Normal Level - Turn off LEDs and Alarm
digitalWrite(LOW_LED_PIN, LOW); // Green LED Off
digitalWrite(HIGH_LED_PIN, LOW); // Red LED Off
} else if (waterLevel >= 800) {
// High Level Detected - Red LED ON and activate Pump sequence
digitalWrite(HIGH_LED_PIN, HIGH);
delay(5000);
digitalWrite(primaryPumpPin, HIGH); // Start Pump 1
delay(30000);
if (waterLevel > 200) {
// Low Level NOT reached after 30s with Pump 1 - Flash Red LED
digitalWrite(secondaryPumpPin, HIGH); // Start Pump 2
delay(30000);
digitalWrite(ALARM_PIN, HIGH); // Alarm ON
// Level is not Low - Start Pump 2 (assuming level is normal)
delay(30000);
Your motors should not be fed from a pin. You need mosfets to control the motors.
Or a relay or a transistor....
Your code uses delay(30000).
That is 30 seconds doing nothing.
You need to use timers and non blocking code (no delay() anymore).
Look at the blinking without delay example in the IDE.
You may also want to use a state machine. On this forum there are excellent tutorials on this subject.
By the way: compliments for a clear text, a clear diagram and code in code tags!
I've made some comments about the structure of your if statements:
// Ok
// At this point, we know the water level is over 200, there is no need to check that again
// At this point, we know water level must be 800 or over, no need to check that again
// At this point, we know water level is 800 or over. No point checking if it's over 200.
// At this point, we know that water level is over 800. It can't be under 200. Therefore THIS CODE WILL NEVER EXECUTE!
Replace the if/ifelse/if salat by a range-based switch/case arrangement.
As already mentioned the call of the delay() function destroyes the expected realtime behaiviour of the sketch.
A design and coding of an event- and timer-controlled OOP-FSM will be helpfull.
as @paulpaulson posted a Finite State Machine (FSM) is a good tool to solve applications like yours.
I implemented a state machine into your sketch; feel free to test it here:
Sketch
Forum: https://forum.arduino.cc/t/code-check-please/1240893/2
Wokwi: https://wokwi.com/projects/393602101966308353
Sketch from TO at 2024/03/28
Modified by ec2021
// C++ code
enum States {UNKNOWN, LEVELLOW, LEVELNORMAL, LEVELHIGH};
States state = LEVELNORMAL;
States lastState = UNKNOWN;
const unsigned long waitBeforePumpTwo = 30000;
int primaryPumpPin;
boolean flashRed = false;
boolean secondPumpOn = false;
unsigned long levelHighStartTime;
checkLevel();
stateMachine();
flashRedLed();
void checkLevel() {
switch (waterLevel) {
case 0 ... 200 :
state = LEVELLOW;
case 201 ... 799 :
case 800 ... 1023:
state = LEVELHIGH;
default:
Serial.println("Error") ;
void stateMachine() {
switch (state) {
case LEVELLOW:
lowLevel();
case LEVELNORMAL:
normalLevel();
case LEVELHIGH:
highLevel();
void lowLevel() {
if (lastState != LEVELLOW) {
Serial.println("LOW");
flashRed = false;
lastState = state;
void normalLevel() {
if (lastState != LEVELNORMAL) {
Serial.println("NORMAL");
flashRed = false;
lastState = state;
void highLevel() {
if (lastState != LEVELHIGH) {
Serial.println("HIGH");
flashRed = false;
digitalWrite(ALARM_PIN, HIGH); // Alarm On
digitalWrite(HIGH_LED_PIN, HIGH); // Red LED On
levelHighStartTime = millis(); // Store the start time of LEVELHIGH here
lastState = state;
// Check if waitBeforePumpTwo has expired after start of the first pump
// If it has expired and pump 2 is off switch it on
if (millis() - levelHighStartTime >= waitBeforePumpTwo && !secondPumpOn) {
startSecondPump();
// The following part is not required but nice for this demo ...
static unsigned long lastPrint = 0;
if (millis() - lastPrint >= 1000 && !secondPumpOn) {
lastPrint = millis();
Serial.print(".");
void startSecondPump() {
// and flash Red Led
Serial.println("Start Second Pump");
flashRed = true;
secondPumpOn = true;
void flashRedLed() {
static unsigned long lastChange = 0;
static byte ledState = HIGH;
if (!flashRed) {
return;
if (millis() - lastChange > 300) {
lastChange = millis();
digitalWrite(HIGH_LED_PIN, ledState);
ledState = !ledState;
If you are interested in some basics regarding state machines just google for "arduino state machine" or check this out
This is amazing info all of you provided!
Thank you all very much!
I am already through the examples you linked in!
Could you guys point me in the right direction on how to cycle duty pump every cycle?
I googled abit about it and tried to write something but looking at what I wrote yesterday... even I can't understand it... (this is me on a 4th night shift trying to engage my brain at a "witching hour"...) Could I use FSM? not sure how but back of my brain shouting "YESSSS"...
Your code resembles a dual, alternating pump system, but is it a pump up (filling) or pump down (emptying) type system? What type of level sensor(s) will you use?
FSM is the way to go.
Not easy at the start, as it another way of thinking is needed.
But this different approach will make things way easier in the end...
Here is the revised code . There were few small errors. (My code could be wrong)
// C++ code
const int PRIMARY_PUMP = 0; // Pump 1 as primary pump
// Water level thresholds
const int LOW_WATER_THRESHOLD = 200;
const int HIGH_WATER_THRESHOLD = 800;
// Pump durations
const unsigned long PUMP_DURATION = 30000; // 30 seconds
// Function prototypes
void startPump(int pumpPin);
void stopPump(int pumpPin);
void flashRedLED();
if (waterLevel <= LOW_WATER_THRESHOLD) {
stopPump(PUMP1_PIN);
stopPump(PUMP2_PIN);
} else if (waterLevel >= HIGH_WATER_THRESHOLD) {
digitalWrite(HIGH_LED_PIN, HIGH); // Red LED ON
startPump(PUMP1_PIN);
delay(PUMP_DURATION);
// Check water level after primary pump
flashRedLED();
startPump(PUMP2_PIN);
// Water level is normal
void startPump(int pumpPin) {
digitalWrite(pumpPin, HIGH);
void stopPump(int pumpPin) {
digitalWrite(pumpPin, LOW);
void flashRedLED() {
for (int i = 0; i < 3; i++) {
The state machine approach is non-blocking. The advantage is that the water level is measured continuously and the pump/pumps stop immediately when low level is reached
With the use of delay this is not the case.
This may not happen in your application but prevents running pump/s while the level becomes too low...
apologies for disappearing, had some health issues with visit to hospital...
It is pump down system.
So every cycle pump is required it should change the duty pumps meaning pump 1 starts then pump 2 joins if required first cycle, pump 2 starts then pump 2 joins if required second cycle, pump 1 starts then pump 2 joins if required and so on...
(first Version Wokwi: https://wokwi.com/projects/393602101966308353)
Wokwi: https://wokwi.com/projects/395791344414641153
Modified by ec2021 2024/04/21
// C++ code
const unsigned long waitBeforePumpTwo = 4000; //30000;
const byte PUMP1_PIN = 9;
const byte PUMP2_PIN = 8;
const byte LOW_LEVEL_PIN = 5;
const byte HIGH_LEVEL_PIN = 4;
const byte HIGH_LED_PIN = 7;
const byte LOW_LED_PIN = 6;
const byte ALARM_PIN = 12;
int primaryPumpPin;
pinMode(LOW_LEVEL_PIN, INPUT_PULLUP); // Low level switch pin goes here
pinMode(HIGH_LEVEL_PIN, INPUT_PULLUP); // High level switch pin goes here
checkLevel();
stateMachine();
flashRedLed();
void checkLevel() {
boolean lowLevel = !digitalRead(LOW_LEVEL_PIN);
boolean highLevel = !digitalRead(HIGH_LEVEL_PIN);
delay(30);// Simple debouncing ...
if (lowLevel) {
state = LEVELLOW;
if (highLevel) {
state = LEVELHIGH;
// The next states are not simulated in Wokwi but
// could be possible with a real limit switch
if (!lowLevel && !highLevel) {
if (lowLevel && highLevel) {
Serial.println("Sensor defect -> Error!!");
switch (state) {
case LEVELLOW:
lowLevel();
case LEVELNORMAL:
normalLevel();
case LEVELHIGH:
highLevel();
void lowLevel() {
flashRed = false;
// Now we exchange the pumpPins for the next cycle
byte tempPin = primaryPumpPin;
primaryPumpPin = secondaryPumpPin;
secondaryPumpPin = tempPin;
lastState = state;
flashRed = false;
lastState = state;
void highLevel() {
flashRed = false;
lastState = state;
startSecondPump();
Serial.print(".");
flashRed = true;
if (!flashRed) {
return;
Everytime it comes from HIGH level to LOW level the pump pins are changed.
The delay for the second pump is set to 4 secs just for testing. See "waitBeforePumpTwo"
If the limit switches work like the slide switch, it should do it as you explained ...
