Code doesn't display the sensor readings
Hey guys,
I'm trying to display sensor readings onto an LCD (128x64).
I tested the gas sensor to check if its functional. It worked and displayed the reading on a serial monitor.
I then wrote this code but I could not get it to display on the LCD. I'm basically trying to implement a smoke/gas alarm system.
Here is the code:
#include <U8g2lib.h>
#include <U8x8lib.h>
int LED1 = 9;
int LED2 = 12;
int buzzer = 22;
int smokeA0 = A6;
int sensorThreshold = 600;
 int analogSensor ;
 char gas [3];
U8G2_ST7920_128X64_1_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* CS=*/ 10, /* reset=*/17);
  u8g2.begin();
  u8g2.enableUTF8Print();
  u8g2.setFont(u8g2_font_helvB10_tf);
  u8g2.setColorIndex(1);
  pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(smokeA0, INPUT);
void draw(){
  u8g2.drawFrame(0,0,128,31);
  u8g2.drawFrame(0,33,128,31);
  u8g2.drawStr( 15, 13, "Gas/Smoke:");
  u8g2.drawStr( 35, 38, analogSensor);
  u8g2.drawUTF8(76, 28, "PPM");
void readsmoke()
  float g = analogRead(smokeA0);
  dtostrf(g,3 , 0, gas);
  u8g2.firstPage();
  do {
    draw();
  } while( u8g2.nextPage() );
analogSensor = analogRead(smokeA0);
if (analogSensor > sensorThreshold)
digitalWrite(LED1, HIGH);
digitalWrite(LED2, LOW);
tone(buzzer, 1000, 200);
digitalWrite(LED1, LOW);
digitalWrite(LED2, HIGH);
noTone(buzzer);
I have attached the results I got on the LCD. Everything is displayed but not the readings. It shows symbols instead of numbers.
Any help is appreciated
The first thing I notice is that analogRead() returns an int not a float
Maybe your library doesn't know about floats.
UKHeliBob:
How can I solve this problem?
Make "g" not a float.
Try "int"
Is "gas" big enough?
TheMemberFormerlyKnownAsAWOL:
It should display 3 numbers max. So I think it is.
Three digits?
What about the terminator?
Try "int"
I did but it still doesn't display the number.
Three digits?
I dont know what a terminator is. If you could tell me how I can add a terminator, that would be great.
Google, "C terminator"
dtostrf converts a double to a string.
In C, strings need a terminator, and the array needs to be big enough to hold the characters in the string AND the terminator.
Make "gas" bigger.
aarg:
Basically what I understood is that is should add = '\0'; after the char array.
Is that what you mean?
dtostrf will add one for you, but you'd better be sure the destination buffer is large enough.
Make "gas" bigger.
I made the array size 20 but still does not work.
"drawStr" suggests to me that "analogSensor" should be a string.
How about you?
How about you?
I tried it and that is the compiler message:
"no matching function for call to 'U8G2_ST7920_128X64_1_SW_SPI::drawStr(int, int, String&)'"
You tried a String?
Why?
Did you declare analogSensor as a String or as an array of chars (aka a C style string) ? From the error message it looks like you did the former. Please post your complete revised sketch
I did manage to solve it.For people having the same issue in the future, I was using the wrong display function.
This is what it should look like:
void draw(){
  u8g2.drawStr( 20, 13, "Gas/Smoke:");
u8g2.setCursor(35, 28);
u8g2.print(analogSensor);
  u8g2.drawUTF8(65, 28, "PPM");
This is the part that I modified.
The print function is used for displaying numbers.
