Code explanation pleas
I want some explanation the code
#include <Encoder.h>
const int NUM_LEDS = 144; // number of leds in strip
const int LED_PIN = 5; // pin for led strip
const int BRIGHTNESS = 255; // brightness of all leds
const int WHEEL_SIZE = 256; // how many entries in the color wheel
const boolean MOVE_LIGHT = false; // move one light around or keep all lights on
const int ENCODER_PIN_1 = 1;
const int ENCODER_PIN_2 = 2;
const int ENCODER_BUTTON = 7;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, LED_PIN, NEO_RGB + NEO_KHZ800);
Encoder encoder(ENCODER_PIN_1, ENCODER_PIN_2);
int mode = 0;
long lastPush = 0;
int autoPosition = 0;
void initializeToBlack() {
for (int i =0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, 0);
pinMode(ENCODER_BUTTON, INPUT);
digitalWrite(ENCODER_BUTTON, HIGH); //turn pullup resistor on
strip.begin();
initializeToBlack();
strip.show();
long normalize(long value, long radix) {
long rval = value % radix;
if (rval < 0) return radix + rval;
else return rval;
int button= digitalRead(ENCODER_BUTTON);
if (button == 0) {
if ((millis() - lastPush) > 250) {
lastPush = millis();
mode++;
if (mode > 4) mode = 0;
long knobValue = encoder.read() / 2;
long ledPosition = normalize(knobValue, NUM_LEDS);
long colorValue = normalize(knobValue * 5, WHEEL_SIZE);
long sleepValue = abs(knobValue) % 500;
switch(mode) {
// off
case 0: initializeToBlack();
// knob moves led
case 1: initializeToBlack();
strip.setPixelColor(ledPosition, colorWheel(BRIGHTNESS, colorValue));
// all on, knob makes rainbow
case 2: for (int i =0; i < NUM_LEDS; i++) {
strip.setPixelColor(i, colorWheel(BRIGHTNESS, colorValue));
// one auto moving light, knob adjusts speed
case 3:
delay(sleepValue);
      strip.setPixelColor(autoPosition, colorWheel(BRIGHTNESS, autoPosition * (WHEEL_SIZE / NUM_LEDS)));
      autoPosition++;
      if (autoPosition >= NUM_LEDS) {
        autoPosition = 0;
// slug of rainbow auto moving lights, knob adjusts speed
case 4:
const int SLUG_SIZE = 15;
      delay(sleepValue);
      for (int i = 0; i < SLUG_SIZE; i++) {
strip.setPixelColor((i + autoPosition) % NUM_LEDS, colorWheel(BRIGHTNESS, i * (WHEEL_SIZE / SLUG_SIZE)));
      autoPosition++;
        autoPosition = 0;
strip.show();
// given a wheel position in 0-255 range
// return a rainbow color adjusted by intensity 0 to 1.0
uint32_t colorWheel(float intensity, byte wheelPos)
const int WHEEL_THIRD = (WHEEL_SIZE - 1) / 3;
if (intensity < 0.0 ) intensity = 0.0;
if (intensity > 1.0) intensity = 1.0;
// as wheelPos progresses from 0 to 255 once, colorIndex should progress from 0 to 255 3 times
// find out position in current third of wheel then multiple by 3 to get full color value
byte colorIndex = (wheelPos % WHEEL_THIRD) * 3;
int fadeColor = (255 - colorIndex) * intensity; // color going down
int increaseColor = colorIndex * intensity; // color going up
switch (wheelPos / WHEEL_THIRD) {
case 0: // first third of the wheel, red fading, no green, blue increasing
return Adafruit_NeoPixel::Color(fadeColor, 0, increaseColor);
case 1: // second third of the wheel no red, green increasing, blue fading
return Adafruit_NeoPixel::Color(0, increaseColor, fadeColor);
case 2:    // last third of the wheel, red increasing, green fading, no blue
  return Adafruit_NeoPixel::Color(increaseColor, fadeColor, 0);
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Where did you get the code from ?
Which part?
Hello
Post your current sketch, well formated, with comments and in so called code tags "</>" and a schematic, not a Fritzy diagram, to see how we can help.
Дайте миру шанс
all
Does it compile and and currently work as you have it hooked up on your hardware?
yes, but I need to understand everything cause I have a final review for my project. And, this code it not written by me.
Whose project ?
RGB LED strip controlled by a Rotary Encoder using Arduino.
How can it possibly be your project if you did not write the code ?
just I wont an explanation for the code
I know the hole idea but not in details
Hello
In this case start and insert describing comments to the sketch.
How?
I know what you want, but it sounds like cheating to me
Which parts do you understand, if any ?
I understand the first part where I defined the pins in Arduino.
the rest i do not understand.
Then how is it "your" project?
Well, for the next line:
...there's this: GitHub - adafruit/Adafruit_NeoPixel: Arduino library for controlling single-wire LED pixels (NeoPixel, WS2812, etc.)
Oops.
I work on it and it is my idea. the only thing that is not mine is the code.
