Hi!
Quite new to Arduino. I have now used bout 8 hours trying to wrap my head around this, but to no avail. I have tried googling and chatgpt aswell.
I am working on a 3d print project from Thingiverse. It's an Iron Man helmet. The code is supplied, but it does not work as expected. I have added a diagram thats shows the wiring. It might be one of those Fritzing diagrams. I hope you bear with me, as I am in no position to make a scheme on my own.
When the button is triggered, it seems like all servos works as expected when they go to the open position. When it's set for closed position, the two MG90S servos works as expected, but the SG90 servos all just keeps spinning.
Hardware:
Arduino Nano
PCA 9658
2x MG90S servo
8x SG90 servo
A pair of flexible led panels for eyes.
Does anyone have a suggestion to where I should look for the problems?
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// Adjust for global change in small sg90 servo movement //
#define SERVOMIN 150
#define SERVOMAX 450
#define SERVO_FREQ 50
uint8_t servonum = 0;
int buttonPin = 2;
int ledPin = 6;
int buttonState = 0;
int globalPos = 1;
unsigned long previousMillis = 0;
unsigned long interval = 5000;
int a = 60;
int animDelay = 1;
int mainServoL = 0;
int mainServoR = 1;
int servoBrowCenter = 4;
// Adjust below numbers for individual servos
int mainServoClosed = 750;
int mainServoOpen = 1950;
int servoBrowCenterOpen = 40;
int servoBrowCenterClosed = 120;
int servoCheeksOpen = 20;
int servoCheeksClosed = 90;
int servoNoseSideOpen = 10;
int servoNoseSideClosed = 86;
int servoBrowSideOpen = 30;
int servoBrowSideClosed = 90;
int servoNoseCenterOpen = 1;
int servoNoseCenterClosed = 110;
Serial.println("Boot Up");
pwm.begin();
pwm.setOscillatorFrequency(27000000);
pwm.setPWMFreq(SERVO_FREQ);
pinMode(buttonPin, INPUT_PULLUP);
delay(50);
pwm.sleep();
int getAngleToPulse(int angle) {
return map(angle, 0, 180, SERVOMIN, SERVOMAX);
buttonState = digitalRead(buttonPin);
if (buttonState == 0) {
Serial.println("Wake up");
pwm.wakeup();
if (globalPos > 0) {
Serial.println("Opening");
// CHEEKS
for (uint16_t pulselen = servoCheeksClosed; pulselen >= servoCheeksOpen; pulselen--) {
pwm.setPWM(9, 0, getAngleToPulse(servoCheeksClosed + servoCheeksOpen - pulselen));
pwm.setPWM(8, 0, getAngleToPulse(pulselen));
delay(animDelay);
Serial.println("1. Cheeks Open");
// NOSE Side
for (uint16_t pulselen = servoNoseSideClosed; pulselen >= servoNoseSideOpen; pulselen--) {
pwm.setPWM(6, 0, getAngleToPulse(servoNoseSideClosed + servoNoseSideOpen - pulselen));
pwm.setPWM(7, 0, getAngleToPulse(pulselen));
delay(animDelay);
Serial.println("2. Nose Side Open");
//BROW Center
for (uint16_t pulselen = servoBrowCenterClosed; pulselen >= servoBrowCenterOpen; pulselen--) {
pwm.setPWM(servoBrowCenter, 0, getAngleToPulse(pulselen));
delay(animDelay);
Serial.println("3. Brow Center Open");
// BROW Side
for (uint16_t pulselen = servoBrowSideOpen; pulselen <= servoBrowSideClosed; pulselen++) {
pwm.setPWM(2, 0, getAngleToPulse(pulselen));
pwm.setPWM(3, 0, getAngleToPulse(servoBrowSideOpen + servoBrowSideClosed - pulselen));
delay(animDelay);
Serial.println("4. Brow Side Open");
// NOSE Center
for (uint16_t pulselen = servoNoseCenterClosed; pulselen >= servoNoseCenterOpen; pulselen--) {
pwm.setPWM(5, 0, getAngleToPulse(pulselen));
delay(animDelay);
Serial.println("5. Nose Center Open");
// EYES
analogWrite(ledPin, 0);
// MAIN SERVOS
for (uint16_t microsec = mainServoClosed; microsec < mainServoOpen; microsec +=5) {
pwm.writeMicroseconds(mainServoL, microsec);
pwm.writeMicroseconds(mainServoR, (mainServoOpen+mainServoClosed-microsec));
globalPos = 0;
delay(animDelay);
Serial.println("6. Main Open");
Serial.println("Closing");
//MAIN SERVOS
for (uint16_t microsec = mainServoOpen; microsec > mainServoClosed; microsec-=5) {
delay(animDelay);
//NOSE Center
for (uint16_t pulselen = servoNoseCenterOpen; pulselen <= servoNoseCenterClosed; pulselen++) {
delay(animDelay);
// BROW Side
for (uint16_t pulselen = servoBrowSideClosed; pulselen >= servoBrowSideOpen; pulselen--) {
delay(animDelay);
// BROW Center
for (uint16_t pulselen = servoBrowCenterOpen; pulselen <= servoBrowCenterClosed; pulselen++) {
delay(animDelay);
// NOSE Side
for (uint16_t pulselen = servoNoseSideOpen; pulselen <= servoNoseSideClosed; pulselen++) {
delay(animDelay);
//CHEEKS
for (uint16_t pulselen = servoCheeksOpen; pulselen <= servoCheeksClosed; pulselen++) {
delay(animDelay);
//EYES
analogWrite(ledPin, 255);
globalPos = 1;
delay(100);
Serial.println("Sleep");
pwm.sleep();
delay(10);
