<= 0 || brightness >= 255)
Just getting started. In the examples I have the above in the fade code. The two vertical lines between the 0 and brightness are not on my keyboard. Can they be replaced with something else?
You can use two of these |
Copy and paste from this thread. 8^)
My | key is above the \ and looks more like a colon, not a solid bar.
You can just use the word "or". Not being sarcastic, either...
(brightness <= 0 or brightness >= 255)
RogerBeck:
Are you sure they are not above the backslash (shift-backslash)?
PaulMurrayCbr:
"They" would not be above the backslash, since it takes two keystrokes to get ||.
(Is yours a solid bar? Mine is actually two bars with a gap like a long colon. I would think that would be confusing for a newbie.)
Thanks guys I'm fixed.
RogerBeck:
<= 0 || brightness >= 255)Just getting started. In the examples I have the above in the fade code. The two vertical lines between the 0 and brightness are not on my keyboard. Can they be replaced with something else?
You can use a conditional expression to replace the || and && operators as that is what they are equivalent to,
here
(brightness <= 0 ? true : brightness >= 255)
