Code review request for RC car
I'm doing an obstacle avoiding car with an arduino uno r3 board, hc-sr04 ultrasonic sensor, dual h-bridge l298 and sg90 microservo.
My code doesn't work, can anyone tell me what i'm doing wrong?
#define MOTOR1_CTL1  8  // I1
#define MOTOR1_CTL2  9  // I2
#define MOTOR1_PWM   11 // EA
#define MOTOR2_CTL1  6  // I3
#define MOTOR2_CTL2  7  // I4
#define MOTOR2_PWM   10 // EB
#define MOTOR_DIR_FORWARD  0
#define MOTOR_DIR_BACKWARD   1
#include <Servo.h>
Servo myservo;
int pos = 0;
int frontal;
int dreta;
int esquerra;
   pinMode(MOTOR1_CTL1,OUTPUT);
   pinMode(MOTOR1_CTL2,OUTPUT);
   pinMode(MOTOR1_PWM,OUTPUT);
  // Setup pins for motor 2
   pinMode(MOTOR2_CTL1,OUTPUT);
   pinMode(MOTOR2_CTL2,OUTPUT);
   pinMode(MOTOR2_PWM,OUTPUT);
   myservo.attach(3);
   motorStart(1, 1);     //canvivi de direccio 1 endavant - 0 endarrera
  setSpeed(1, 0);     // velocitat 0-255
  motorStart(2, 1);     //canvivi de direccio 1 endavant - 0 endarrera
  setSpeed(2, 0);     // velocitat 0-255
   myservo.write(80);  // situem el servo al centre
void setSpeed(char motor_num, char motor_speed)
   if (motor_num == 1)
      analogWrite(MOTOR1_PWM, motor_speed);
      analogWrite(MOTOR2_PWM, motor_speed);
void motorStart(char motor_num, byte direccio)
   char pin_ctl1;
   char pin_ctl2;
   if (motor_num == 1)
      pin_ctl1 = MOTOR1_CTL1;
      pin_ctl2 = MOTOR1_CTL2;
      pin_ctl1 = MOTOR2_CTL1;
      pin_ctl2 = MOTOR2_CTL2;
   switch (direccio)
     case MOTOR_DIR_FORWARD:
       digitalWrite(pin_ctl1,LOW);
       digitalWrite(pin_ctl2,HIGH);
     case MOTOR_DIR_BACKWARD:
        digitalWrite(pin_ctl1,HIGH);
        digitalWrite(pin_ctl2,LOW);
void motorStop(char motor_num)
   setSpeed(motor_num, 0);
   if (motor_num == 1)
     digitalWrite(MOTOR1_CTL1,HIGH);
     digitalWrite(MOTOR1_CTL2,HIGH);
     digitalWrite(MOTOR2_CTL1,HIGH);
     digitalWrite(MOTOR2_CTL2,HIGH);
  //motors endavant
  setSpeed(1, 200);     // velocitat 0-255
  setSpeed(2, 200);     // velocitat 0-255
  //llegim sensor
  frontal =analogRead(3);
  if(frontal < 20)
      myservo.write(135);
      esquerra =analogRead(3);
      myservo.write(35);
      dreta =analogRead(3);
      if( dreta > esquerra)
         motorStart(1, 0);
         setSpeed(1, 200);
         motorStart(2, 1);
         setSpeed(2, 200);
        motorStart(1, 1);
        setSpeed(1, 200);
        motorStart(1, 0);
        setSpeed(1, 200);
    motorStart(1, 1);
    setSpeed(1, 200);
    motorStart(2, 0);
    setSpeed(2, 200);
Thank you guys!
You have not said what is wrong but from Servo - Arduino Reference
on boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins.
and in your program you have
#define MOTOR2_PWM   10 // EB  and analogWrite(MOTOR2_PWM, motor_speed);
Try moving the affected PWM output to another pin.
You're right, the problem is that when I use the myservo.attach(pin) function then the motor 2 don't run. But if I disconnect the enable B then the motor operates at maximum speed (255). So I can't regulate it.
I tried using different pins but it still doesn't work. Maybe the problem is the library or something. I don't know.
Please do not hijack other peoples discussion
  • splitted
  • changed topic.
There's that lame "it doesn't work" crap again. What pin did you change to? What ACTUALLY happens?
I doubt that the problem is in any library. I'm willing to bet that the "or something" will be your wiring, your power supply, or your code.
