My project uses a Sparkfun Arduino Pro Micro, and I'm using a fairly old version of the IDE, 1.8.13.
The Micro is connected to a micro SD card module, a GY-521 gyro/accelerometer module, and a NEO-6m GPS module. The point of the project is to collect data from these modules, save them to an SD card, and then transfer the data onto a computer via micro SD.
It all works as expected when the micro is connected to my computer via usb, however, when it is disconnected and powered by a battery, data is no longer being saved onto the SD card. The data is timestamped, so it's easy to see that the last data taken on a given file is from just before it was power cycled.
To make things more confusing, if I power the Micro through the RAW pin and usb at the same time, and then disconnect the usb, everything works just fine on battery power and I can continue collecting data. The issue is, if the battery ever runs out of power I would have to reconnect the board to a computer to set it up again, which would be inconvenient. I'm sure there's an explanation/solution, but I'm not sure what it could be.
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
File f;
// The TinyGPS++ object
TinyGPSPlus gps;
static const int TXPin = 9, RXPin = 5;
static const uint32_t GPSBaud = 9600;
SoftwareSerial ss(TXPin, RXPin);
String data;
const int MPU_addr=0x68; // I2C address of the MPU-6050
double AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
String filename;
char filnum = 'a';
pinMode(OUTPUT,7);
while (!Serial) {
delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println("");
delay(100);
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
ss.begin(GPSBaud);
filename = "RIDE"+String(filnum)+".txt";
while(SD.exists(filename)){
filnum += 1;
Serial.println("Writing to"+filename);
Serial.println(gps.date.month());
void SDwrite(String file, String text){
f = SD.open(file, FILE_WRITE);
if (f) {
Serial.print("Writing to " + file + "...");
f.println(text);
// close the file:
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening " + file);
f.close();
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
while (ss.available() > 0)
if (gps.encode(ss.read()))
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while(true);
digitalWrite(7, HIGH);
delay(200);
digitalWrite(7,LOW);
data = String(AcX)+","+String(AcY)+","+String(AcZ)+","+String(GyX)+","+String(GyY)+","+String(GyZ)+","+String(gps.location.lat())+","+String(gps.location.lng())+","+String(gps.speed.mph())+","+String(gps.time.hour())+","+String(gps.time.minute());
Serial.println(data);
SDwrite(filename, data);
