Code will no longer compile
Hi, so in the past this code compiled and I am currently using it. Now my system has upgraded to the newest Arduino and it will not compile. It says " 'A1' not declared in this scope, did you mean 'A0'? " Please help?
[code]
// last change 1/25/2020
// added graph recorder
// change charge pulse to 10 degrees from 30
// 8/17 added code for pulse out width
// 7/14/2017 added correct math and setting for position of pickup
// 10 10/28/2016 adds charging pulse with Timer 2
// lowest RPM = 615 with charge pulse to keep OCR2A <= 255
// CDI Tester Pulse Generator Serial Output Arduino Code
// replaced on 7/22/18 mod on 4/18/2019 changed to go simple transformer control of pos / neg trigger
// update 7/14/2017 added correct math and setting for position of pickup
// revision 10 10/28/2016 adds charging pulse with Timer 2
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h> // include i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate & config display for hd44780 chip
int pot1 = A1; // select the input pin for the pot for rpm
int pot2 = A2; // select the input pin for the pot for pickup location in degrees
int potValue = 0; // variable to store the value coming from the sensor
int pickupValue = 0; // position of pickup in degrees
int timerTopValue = 12500; // changed from timerTopValue = 0
int outputPin = 9; // select the pin for the output for trigger pulse, changed from 8
int output2Pin = 5;
int chargePin = 7; // select the pin for the output for charge pulses
volatile boolean trigger = false;
volatile unsigned long delayPeriod;
unsigned long copy_delayPeriod;
volatile unsigned long delayPeriodStart;
float delayDegrees; // changed from int to float for decimal place display
int RPM;
int pickup;
int pulseWidth;
unsigned int numberMeasures;
volatile boolean interruptFlag;
unsigned long analogReadInterval = 500; // read pots and map
unsigned long lastAnalogRead;
const byte setChargePulseSwitch = 6;
boolean chargePulse = false ;  // default dc powered mode
volatile byte timeSliceCount = 0; // TDC 0 degrees
  lcd.begin(20, 4); // initialize the lcd for 20 chars 4 lines, turn on backlight
  lcd.setCursor(1, 0); // lcd display setup of unchanging headings
  lcd.print("RPM:"); // print fixed characters
  lcd.setCursor(12, 0);
  lcd.print("Deg");
  lcd.setCursor(1, 1);
  lcd.print("Pos:");
  lcd.setCursor(1, 2);
  lcd.print("Us Delay:");
  lcd.setCursor(1, 3);
  lcd.print("Deg Advance:");
  pinMode(outputPin, OUTPUT); // declare the outputPin as an OUTPUT
  pinMode(output2Pin, OUTPUT);
  pinMode(chargePin, OUTPUT); // declare the chargePin as an OUTPUT
  pinMode(setChargePulseSwitch, INPUT_PULLUP);
  if (digitalRead(setChargePulseSwitch) == LOW)
    chargePulse = true; // AC CDI
 // Timer1 default set up .5ms trigger pulse every 50 ms
  TCCR1A = (1<< WGM11);//Fast PWM to ICR1
  TCCR1B = (1 << WGM13) | (1 << WGM12);
  //TCCR1B = (1 << WGM12); // CTC mode to OCR1A
  TCCR1B = (1 << WGM13) | (1 << WGM12);//CTC mode to ICR1
  //OCR1A = timerTopValue;
  ICR1 = timerTopValue;
  TIMSK1 |= (1 << OCIE1A); // interrupt enable compareA
  TIMSK1 |= (1 << OCIE1B); // interrupt enable compareB
  TIMSK1 |= (1<< TOIE1);//overflow interrupt at top
  OCR1B = 250; // sets trigger pulse width, 500 = 2Ms, 250 = 1Ms, 125 = .5Ms, set to 1250 for 5013 *********************************************
  OCR1A = OCR1B +500;//add default
  TCCR1B |= (1 << CS11) | (1 << CS10); // prescaler 64 4us/tick
// Timer2 default setup charge pulse 36 periods 10 degrees each; only 5 get turned on
// charge pulse timing interval = Timer1 trigger period/12 = timerTopValue/96
  TCCR2A = 0;
  TCCR2B = 0;
  TCCR2A = 1 << WGM20; // lsb of mode 7 pwm to OCR2A
  TCCR2B = 1 << WGM22; // msb of mode 7 pwm to OCR2A;
  //OCR2A = timerTopValue / 96; // 96 = 12*4*2 (#periods, prescaler difference, up/down timer mode )
  OCR2A = timerTopValue / 288; //  = 36*4*2 (#periods, prescaler difference, up/down timer mode )
  TIMSK2 = 0;
  TIMSK2 = 1 << TOIE2; // enable overflow interrupt
// actually start timer in ISR(TIMER1_COMPA_vect
// to prevent out of sync charge pulse, no prescaler set here
  attachInterrupt(digitalPinToInterrupt(3), delayPeriodTiming, FALLING);
  if (millis() - lastAnalogRead >= analogReadInterval)
    lastAnalogRead += analogReadInterval;
    potValue = analogRead(pot1); // rpm
    pickupValue = analogRead(pot2); // pickup position
    chargePulse = false;
// Timer2 OCR2A requires max value 255 => 615 lowest RPM
// if (chargePulse)
      RPM = map(potValue, 0, 1023, 615, 10000);
      pickup = map(pickupValue, 0, 1023, 10, 85); // position so advance will read based on delay, 57 for yamaha 350 2 pu, 74 for 1 pu, 72 for tw200, 25 for 5013
      pulseWidth = (60000000/RPM)/360; // time for 1° in uS
    timerTopValue = 15000000UL / RPM;
    OCR1B = pulseWidth;
    OCR1A = OCR1B + pulseWidth;
    lcd.setCursor(6, 0);
    lcd.print("     "); // print blank spaces to clear old data
    lcd.print(RPM);  // print rpm
    lcd.setCursor(16, 0);
    lcd.print("  ");
    lcd.print(pulseWidth, 1); // print us per degree
    lcd.setCursor(6, 1);
    lcd.print("   ");
    lcd.print(pickup); // print pickup coil position
    lcd.setCursor(11, 2);
    lcd.print("       ");
    lcd.print(copy_delayPeriod);
    lcd.setCursor(14, 3);
    lcd.print("      ");
    lcd.print(delayDegrees, 1);   // delayDegrees, 1);
  // -------------------------- Export to USB in CSV format
numberMeasures = numberMeasures+1;
if (numberMeasures > 5 && delayDegrees != 0.00); // Delete the first 2 values that have been eroded after the display cut
Serial.print(RPM); Serial.print(", "); Serial.println(delayDegrees);
delay(200);
  if (trigger == true && interruptFlag == true )
    trigger = false;
    interruptFlag = false;
    noInterrupts();
    copy_delayPeriod = delayPeriod;
    interrupts();
    delayDegrees = pickup - (360.0 * (copy_delayPeriod) / (timerTopValue * 4.0)); // for decimal place in deg display.
//ISR(TIMER1_COMPA_vect) {
ISR(TIMER1_OVF_vect){
  //OCR1A = (timerTopValue); // value to set delay between pulses to trigger cdi
  ICR1 = (timerTopValue);
  digitalWrite(chargePin, LOW); // guarantee off charge pin at trigger
  digitalWrite(outputPin, HIGH); // turn on pin  trigger
    delayPeriodStart = micros(); // start looking for response as pulse rises
    trigger = true;
// start Timer 2 for charge pulses
  if (chargePulse)
    timeSliceCount = 0;
    TCNT2 = 0;
    //OCR2A = timerTopValue/96; // set 12 periods
    OCR2A = timerTopValue/288;//set 36 periods
    TCCR2B |=  1 << CS22 | 1 << CS21; //prescaleer 256 16us/tick
ISR(TIMER1_COMPB_vect) {
  digitalWrite(outputPin, LOW);
  //could add short delayMiocroseconds here for gap
  digitalWrite(output2Pin,HIGH);
  //  delayPeriodStart = micros(); // start looking for response as pulse falls
  //  trigger = true;
  digitalWrite(output2Pin, LOW);
void delayPeriodTiming()
  delayPeriod = micros() - delayPeriodStart;
  interruptFlag = true;
ISR(TIMER2_OVF_vect)
// 5 pulses of 10 degrees starting at 60 degrees
// ON at 60,120,180,240,300 = slice count 6,12,18,24,30
// OFF at 70,130,190,250,310
  if (timeSliceCount != 0 && timeSliceCount % 6 == 0)
    digitalWrite (chargePin, HIGH);
  timeSliceCount++;
  if (timeSliceCount == 36)
    timeSliceCount = 0;
// stop Timer2 by clearing prescaler bits
    TCCR2B &= ~1<< CS22;
    TCCR2B &= ~1<< CS21;
[/code]
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
I remove the errant [code] stuff and then I tried to compile your code and it compiled with one warning:
... \AppData\Local\Temp\arduino_modified_sketch_842490\sketch_dec22a.ino:161:51: warning: suggest braces around empty body in an 'if' statement [-Wempty-body]
I removed the semicolon [;] from the if statement and the warning went away. It then compiled with no warnings or errors.
Hi, how do I see what you did? Why did it compile 2 years ago and not now?
Thanks, Tom
// [code]  ***************************************** comment this
#include <Wire.h>
int output2Pin = 5;
int RPM;
int pickup;
int pulseWidth;
   lcd.print("Deg");
   lcd.print("Pos:");
   TCCR1A = (1 << WGM11); //Fast PWM to ICR1
   TIMSK1 |= (1 << TOIE1); //overflow interrupt at top
   OCR1A = OCR1B + 500; //add default
   TCCR2A = 0;
   TCCR2B = 0;
   TIMSK2 = 0;
      // if (chargePulse)
      pulseWidth = (60000000 / RPM) / 360; // time for 1° in uS
      OCR1B = pulseWidth;
      lcd.print("  ");
      lcd.print("   ");
      lcd.print("       ");
      lcd.print("      ");
   numberMeasures = numberMeasures + 1;
   if (numberMeasures > 5 && delayDegrees != 0.00)//; **************************** comment the semicolon
      delay(200);
      trigger = false;
      noInterrupts();
      interrupts();
      trigger = true;
   if (chargePulse)
      timeSliceCount = 0;
      TCNT2 = 0;
      OCR2A = timerTopValue / 288; //set 36 periods
   digitalWrite(output2Pin, HIGH);
   //  trigger = true;
   timeSliceCount++;
      timeSliceCount = 0;
      TCCR2B &= ~1 << CS22;
      TCCR2B &= ~1 << CS21;
// [ / code] ***************************************** comment this
comment the and at the top and bottom of the code. Look for "********* comment this"
Line 163 comment semicolon
Arduino: 1.8.13 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Tom Bauer\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Tom Bauer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M64,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=04F9_02AD -ide-version=10813 -build-path C:\Users\TOMBAU~1\AppData\Local\Temp\arduino_build_811720 -warnings=none -build-cache C:\Users\TOMBAU~1\AppData\Local\Temp\arduino_cache_428002 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Arduino\cdi-tester_version_15B\cdi-tester_version_15B.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Tom Bauer\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Tom Bauer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Arduino\libraries -fqbn=esp8266:esp8266:generic:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,ResetMethod=nodemcu,CrystalFreq=26,FlashFreq=40,FlashMode=dout,eesz=1M64,led=2,sdk=nonosdk_190703,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -vid-pid=04F9_02AD -ide-version=10813 -build-path C:\Users\TOMBAU~1\AppData\Local\Temp\arduino_build_811720 -warnings=none -build-cache C:\Users\TOMBAU~1\AppData\Local\Temp\arduino_cache_428002 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Arduino\cdi-tester_version_15B\cdi-tester_version_15B.ino
Using board 'generic' from platform in folder: C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\sketch\\cdi-tester_version_15B.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\sketch\\cdi-tester_version_15B.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for hd44780.h: [hd44780-master@1.1.0 hd44780-1.1.0@1.1.0 hd44780@1.0.2]
ResolveLibrary(hd44780.h)
  -> candidates: [hd44780-master@1.1.0 hd44780-1.1.0@1.1.0 hd44780@1.0.2]
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Arduino\\libraries\\hd44780" "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\sketch\\cdi-tester_version_15B.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Arduino\\libraries\\hd44780" "C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire\\Wire.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Arduino\\libraries\\hd44780" "C:\\Arduino\\libraries\\hd44780\\hd44780.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Arduino\\libraries\\hd44780" "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\sketch\\cdi-tester_version_15B.ino.cpp" -o "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode header --publickey "C:\\Arduino\\cdi-tester_version_15B/public.key" --out "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core/Updater_Signing.h"
"C:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10813 -DARDUINO_ESP8266_GENERIC -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_GENERIC\"" -DLED_BUILTIN=2 -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\generic" "-IC:\\Users\\Tom Bauer\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\Wire" "-IC:\\Arduino\\libraries\\hd44780" "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\sketch\\cdi-tester_version_15B.ino.cpp" -o "C:\\Users\\TOMBAU~1\\AppData\\Local\\Temp\\arduino_build_811720\\sketch\\cdi-tester_version_15B.ino.cpp.o"
cdi-tester_version_15B:22:12: error: 'A1' was not declared in this scope; did you mean 'A0'?
   22 | int pot1 = A1; // select the input pin for the pot for rpm
      |            A0
cdi-tester_version_15B:23:12: error: 'A2' was not declared in this scope; did you mean 'A0'?
   23 | int pot2 = A2; // select the input pin for the pot for pickup location in degrees
      |            A0
cdi-tester_version_15B:180:5: error: expected constructor, destructor, or type conversion before '(' token
  180 | ISR(TIMER1_OVF_vect){
cdi-tester_version_15B:201:5: error: expected constructor, destructor, or type conversion before '(' token
  201 | ISR(TIMER1_COMPB_vect) {
cdi-tester_version_15B:212:5: error: expected constructor, destructor, or type conversion before '(' token
  212 | ISR(TIMER1_COMPA_vect) {
cdi-tester_version_15B:222:5: error: expected constructor, destructor, or type conversion before '(' token
  222 | ISR(TIMER2_OVF_vect)
C:\Arduino\cdi-tester_version_15B\cdi-tester_version_15B.ino: In function 'void setup()':
cdi-tester_version_15B:73:3: error: 'TCCR1A' was not declared in this scope
   73 |   TCCR1A = (1<< WGM11);//Fast PWM to ICR1
cdi-tester_version_15B:73:17: error: 'WGM11' was not declared in this scope
cdi-tester_version_15B:74:3: error: 'TCCR1B' was not declared in this scope
   74 |   TCCR1B = (1 << WGM13) | (1 << WGM12);
cdi-tester_version_15B:74:18: error: 'WGM13' was not declared in this scope
cdi-tester_version_15B:74:33: error: 'WGM12' was not declared in this scope
cdi-tester_version_15B:78:3: error: 'ICR1' was not declared in this scope
   78 |   ICR1 = timerTopValue;
cdi-tester_version_15B:79:3: error: 'TIMSK1' was not declared in this scope
   79 |   TIMSK1 |= (1 << OCIE1A); // interrupt enable compareA
cdi-tester_version_15B:79:19: error: 'OCIE1A' was not declared in this scope
cdi-tester_version_15B:80:19: error: 'OCIE1B' was not declared in this scope
   80 |   TIMSK1 |= (1 << OCIE1B); // interrupt enable compareB
cdi-tester_version_15B:81:18: error: 'TOIE1' was not declared in this scope; did you mean 'TEIE1'?
   81 |   TIMSK1 |= (1<< TOIE1);//overflow interrupt at top
      |                  TEIE1
cdi-tester_version_15B:82:3: error: 'OCR1B' was not declared in this scope
   82 |   OCR1B = 250; // sets trigger pulse width, 500 = 2Ms, 250 = 1Ms, 125 = .5Ms, set to 1250 for 5013 *********************************************
cdi-tester_version_15B:83:3: error: 'OCR1A' was not declared in this scope
   83 |   OCR1A = OCR1B +500;//add default
cdi-tester_version_15B:84:19: error: 'CS11' was not declared in this scope
   84 |   TCCR1B |= (1 << CS11) | (1 << CS10); // prescaler 64 4us/tick
cdi-tester_version_15B:84:33: error: 'CS10' was not declared in this scope
cdi-tester_version_15B:88:3: error: 'TCCR2A' was not declared in this scope
   88 |   TCCR2A = 0;
cdi-tester_version_15B:89:3: error: 'TCCR2B' was not declared in this scope
   89 |   TCCR2B = 0;
cdi-tester_version_15B:90:17: error: 'WGM20' was not declared in this scope
   90 |   TCCR2A = 1 << WGM20; // lsb of mode 7 pwm to OCR2A
cdi-tester_version_15B:91:17: error: 'WGM22' was not declared in this scope
   91 |   TCCR2B = 1 << WGM22; // msb of mode 7 pwm to OCR2A;
cdi-tester_version_15B:93:3: error: 'OCR2A' was not declared in this scope
   93 |   OCR2A = timerTopValue / 288; //  = 36*4*2 (#periods, prescaler difference, up/down timer mode )
cdi-tester_version_15B:94:3: error: 'TIMSK2' was not declared in this scope
   94 |   TIMSK2 = 0;
cdi-tester_version_15B:95:17: error: 'TOIE2' was not declared in this scope
   95 |   TIMSK2 = 1 << TOIE2; // enable overflow interrupt
C:\Arduino\cdi-tester_version_15B\cdi-tester_version_15B.ino: In function 'void loop()':
cdi-tester_version_15B:130:5: error: 'OCR1B' was not declared in this scope
  130 |     OCR1B = pulseWidth;
cdi-tester_version_15B:131:5: error: 'OCR1A' was not declared in this scope
  131 |     OCR1A = OCR1B + pulseWidth;
C:\Arduino\cdi-tester_version_15B\cdi-tester_version_15B.ino: At global scope:
cdi-tester_version_15B:180:4: error: expected constructor, destructor, or type conversion before '(' token
cdi-tester_version_15B:201:4: error: expected constructor, destructor, or type conversion before '(' token
cdi-tester_version_15B:212:4: error: expected constructor, destructor, or type conversion before '(' token
cdi-tester_version_15B:222:4: error: expected constructor, destructor, or type conversion before '(' token
Multiple libraries were found for "hd44780.h"
 Used: C:\Arduino\libraries\hd44780
 Not used: C:\Arduino\libraries\hd44780-master
 Not used: C:\Arduino\libraries\hd44780-1.1.0
Using library Wire at version 1.0 in folder: C:\Users\Tom Bauer\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\Wire
Using library hd44780 at version 1.0.2 in folder: C:\Arduino\libraries\hd44780
exit status 1
Where did you get that code? What board was it running on 2 years ago?
That code is not written for the ESP8266. There are references to register names that the ESP does not have.
The ESP8266 has only one ADC pin, that is A0. There are no A1 and A2 on and ESP8266.
  TCCR2A = 0;
  TCCR2B = 0;
  TIMSK2 = 0;
That appears to be Arduino Uno code which is not a ESP8266.
Why did it run 2987.6 years ago but not now? One or more libraires has been updated and some of the old ways have not been moved forward.
OK, solved. I had not realized it was set to ESP8266 and not Uno. Thanks guys!
