Apparently I have forgotten everything I knew about Arduino. Trying to use ArduStim
Several years ago I had great success with Arduino IDE, etc, but now cannot seem to get anything to work and could really use some spoon-feeding.
I’m trying to setup ArduStim using an older MacBook air, but every time I try to verify/compile a sketch, I get various undefined errors and as I said, I have forgotten how to run the IDE.
I’m trying to use the various files here: Pull out all the SerialUI code and setup PlatformIO project · speeduino/Ardu-Stim@2708c80 · GitHub
Any help, spoon-feeding, hints, even derision is encouraged and appreciated.
Thanx
PT
Hi @PTSchram.
I'm going to ask you to provide the full output from a compilation.
:red_exclamation_mark: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Open the sketch in Arduino IDE.
  2. Select Sketch > Verify/Compile from the Arduino IDE menus.
  3. Wait for the compilation to fail.
  4. You will see a "Compilation error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
  5. Open a reply here on this forum topic by clicking the "Reply" button.
  6. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  7. Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
    This will paste the compilation output into the code block.
  8. Move the cursor outside of the code block markup before you add any additional text to your reply.
  9. Click the "Reply" button to publish the post.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
Click here for attachment instructions
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a reply here on this forum topic by clicking the "Reply" button.
  5. Click the "Upload" icon (Upload icon) on the post composer toolbar:
    The "Open" dialog will open.
  6. Select the .txt file you saved from the "Open" dialog.
  7. Click the "Open" button.
    The dialog will close.
  8. Click the "Reply" button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
I think this is it.
I am beyond embarrassed at how I lost seemingly everything I learned a few years ago.
Use it or lose it indeed!
/* vim: set syntax=c expandtab sw=2 softtabstop=2 autoindent smartindent smarttab : /
  • Arbritrary wheel pattern generator
  • copyright 2014 David J. Andruczyk
  • Ardu-Stim software is free software: you can redistribute it and/or modify
  • it under the terms of the GNU General Public License as published by
  • the Free Software Foundation, either version 3 of the License, or
  • (at your option) any later version.
  • ArduStim software is distributed in the hope that it will be useful,
  • but WITHOUT ANY WARRANTY; without even the implied warranty of
  • MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
  • GNU General Public License for more details.
  • You should have received a copy of the GNU General Public License
  • along with any ArduStim software. If not, see Licenses - GNU Project - Free Software Foundation
#include "globals.h"
#include "ardustim.h"
#include "enums.h"
#include "comms.h"
#include "storage.h"
#include "wheel_defs.h"
#include <avr/pgmspace.h>
#include <EEPROM.h>
struct configTable config;
struct status currentStatus;
/* Sensistive stuff used in ISR's /
volatile uint16_t adc0; /
POT RPM /
volatile uint16_t adc1; /
Pot Wheel select /
Setting rpm to any value over 0 will enabled sweeping by default /
Stuff for handling prescaler changes (small tooth wheels are low RPM) /
volatile uint8_t analog_port = 0;
volatile bool adc0_read_complete = false;
volatile bool adc1_read_complete = false;
volatile bool reset_prescaler = false;
volatile uint8_t output_invert_mask = 0x00; /
Don't invert anything /
volatile uint8_t prescaler_bits = 0;
volatile uint8_t last_prescaler_bits = 0;
volatile uint16_t new_OCR1A = 5000; /
sane default */
volatile uint16_t edge_counter = 0;
volatile uint32_t cycleStartTime = micros();
volatile uint32_t cycleDuration = 0;
uint32_t sweep_time_counter = 0;
uint8_t sweep_direction = ASCENDING;
/* Less sensitive globals */
uint8_t bitshift = 0;
wheels Wheels[MAX_WHEELS] = {
/* Pointer to friendly name string, pointer to edge array, RPM Scaler, Number of edges in the array, whether the number of edges covers 360 or 720 degrees */
{ dizzy_four_cylinder_friendly_name, dizzy_four_cylinder, 0.03333, 4, 360 },
{ dizzy_six_cylinder_friendly_name, dizzy_six_cylinder, 0.05, 6, 360 },
{ dizzy_eight_cylinder_friendly_name, dizzy_eight_cylinder, 0.06667, 8, 360 },
{ sixty_minus_two_friendly_name, sixty_minus_two, 1.0, 120, 360 },
{ sixty_minus_two_with_cam_friendly_name, sixty_minus_two_with_cam, 1.0, 240, 720 },
{ sixty_minus_two_with_halfmoon_cam_friendly_name, sixty_minus_two_with_halfmoon_cam, 1.0, 240, 720 },
{ thirty_six_minus_one_friendly_name, thirty_six_minus_one, 0.6, 72, 360 },
{ twenty_four_minus_one_friendly_name, twenty_four_minus_one, 0.5, 48, 360 },
{ four_minus_one_with_cam_friendly_name, four_minus_one_with_cam, 0.06667, 16, 720 },
{ eight_minus_one_friendly_name, eight_minus_one, 0.13333, 16, 360 },
{ six_minus_one_with_cam_friendly_name, six_minus_one_with_cam, 0.15, 36, 720 },
{ twelve_minus_one_with_cam_friendly_name, twelve_minus_one_with_cam, 0.6, 144, 720 },
{ fourty_minus_one_friendly_name, fourty_minus_one, 0.66667, 80, 360 },
{ dizzy_four_trigger_return_friendly_name, dizzy_four_trigger_return, 0.15, 9, 720 },
{ oddfire_vr_friendly_name, oddfire_vr, 0.2, 24, 360 },
{ optispark_lt1_friendly_name, optispark_lt1, 3.0, 720, 720 },
{ twelve_minus_three_friendly_name, twelve_minus_three, 0.4, 48, 360 },
{ thirty_six_minus_two_two_two_friendly_name, thirty_six_minus_two_two_two, 0.6, 72, 360 },
{ thirty_six_minus_two_two_two_h6_friendly_name, thirty_six_minus_two_two_two_h6, 0.6, 72, 360 },
{ thirty_six_minus_two_two_two_with_cam_friendly_name, thirty_six_minus_two_two_two_with_cam, 0.6, 144, 720 },
{ fourty_two_hundred_wheel_friendly_name, fourty_two_hundred_wheel, 0.6, 72, 360 },
{ thirty_six_minus_one_with_cam_fe3_friendly_name, thirty_six_minus_one_with_cam_fe3, 0.6, 144, 720 },
{ six_g_seventy_two_with_cam_friendly_name, six_g_seventy_two_with_cam, 0.6, 144, 720 },
{ buell_oddfire_cam_friendly_name, buell_oddfire_cam, 0.33333, 80, 720 },
{ gm_ls1_crank_and_cam_friendly_name, gm_ls1_crank_and_cam, 6.0, 720, 720 },
{ gm_ls_58X_crank_and_4x_cam_friendly_name, GM_LS_58X_crank_and_4x_cam, 1.0, 240, 720},
{ lotus_thirty_six_minus_one_one_one_one_friendly_name, lotus_thirty_six_minus_one_one_one_one, 0.6, 72, 360 },
{ honda_rc51_with_cam_friendly_name, honda_rc51_with_cam, 0.2, 48, 720 },
{ thirty_six_minus_one_with_second_trigger_friendly_name, thirty_six_minus_one_with_second_trigger, 0.6, 144, 720 },
{ chrysler_ngc_thirty_six_plus_two_minus_two_with_ngc4_cam_friendly_name, chrysler_ngc_thirty_six_plus_two_minus_two_with_ngc4_cam, 3.0, 720, 720 },
{ chrysler_ngc_thirty_six_minus_two_plus_two_with_ngc6_cam_friendly_name, chrysler_ngc_thirty_six_minus_two_plus_two_with_ngc6_cam, 3.0, 720, 720 },
{ chrysler_ngc_thirty_six_minus_two_plus_two_with_ngc8_cam_friendly_name, chrysler_ngc_thirty_six_minus_two_plus_two_with_ngc8_cam, 3.0, 720, 720 },
{ weber_iaw_with_cam_friendly_name, weber_iaw_with_cam, 1.2, 144, 720 },
{ fiat_one_point_eight_sixteen_valve_with_cam_friendly_name, fiat_one_point_eight_sixteen_valve_with_cam, 3.0, 720, 720 },
{ three_sixty_nissan_cas_friendly_name, three_sixty_nissan_cas, 3.0, 720, 720 },
{ twenty_four_minus_two_with_second_trigger_friendly_name, twenty_four_minus_two_with_second_trigger, 0.3, 72, 720 },
{ yamaha_eight_tooth_with_cam_friendly_name, yamaha_eight_tooth_with_cam, 0.26667, 64, 720 },
{ gm_four_tooth_with_cam_friendly_name, gm_four_tooth_with_cam, 0.06666, 8, 720 },
{ gm_six_tooth_with_cam_friendly_name, gm_six_tooth_with_cam, 0.1, 12, 720 },
{ gm_eight_tooth_with_cam_friendly_name, gm_eight_tooth_with_cam, 0.13333, 16, 720 },
{ volvo_d12acd_with_cam_friendly_name, volvo_d12acd_with_cam, 4.0, 480, 720 },
{ mazda_thirty_six_minus_two_two_two_with_six_tooth_cam_friendly_name, mazda_thirty_six_minus_two_two_two_with_six_tooth_cam, 1.5, 360, 720 },
{ mitsubishi_4g63_4_2_friendly_name, mitsubishi_4g63_4_2, 0.6, 144, 720 },
{ audi_135_with_cam_friendly_name, audi_135_with_cam, 1.5, 1080, 720 },
{ honda_d17_no_cam_friendly_name, honda_d17_no_cam, 0.6, 144, 720 },
{ mazda_323_au_friendly_name, mazda_323_au, 1, 30, 720 },
{ daihatsu_3cyl_friendly_name, daihatsu_3cyl, 0.8, 144, 360 },
{ miata_9905_friendly_name, miata_9905, 0.6, 144, 720 },
{ twelve_with_cam_friendly_name, twelve_with_cam, 0.6, 144, 720 },
{ twenty_four_with_cam_friendly_name, twenty_four_with_cam, 0.6, 144, 720 },
{ subaru_six_seven_name_friendly_name, subaru_six_seven, 3.0, 720, 720 },
{ gm_seven_x_friendly_name, gm_seven_x, 1.502, 180, 720 },
{ four_twenty_a_friendly_name, four_twenty_a, 0.6, 144, 720 },
{ ford_st170_friendly_name, ford_st170, 3.0, 720, 720 },
{ mitsubishi_3A92_friendly_name, mitsubishi_3A92, 0.6, 144, 720 },
{ Toyota_4AGE_CAS_friendly_name, toyota_4AGE_CAS, 0.333, 144, 720 },
{ Toyota_4AGZE_friendly_name, toyota_4AGZE, 0.333, 144, 720 },
{ Suzuki_DRZ400_friendly_name, suzuki_DRZ400,0.6, 72, 360},
{ Jeep_2000_4cyl_friendly_name, jeep_2000_4cyl, 1.5, 360, 720},
{ Jeep_2000_6cyl_friendly_name, jeep_2000_6cyl, 1.5, 360, 720 },
{ BMW_N20_friendly_name, bmw_n20, 1.0, 240, 720},
{ VIPER9602_friendly_name, viper9602wheel, 1.0, 240, 720},
{ thirty_six_minus_two_with_second_trigger_friendly_name, thirty_six_minus_two_with_second_trigger, 0.6, 144, 720 },
{ GM_40_Tooth_Trans_OSS_friendly_name, GM40toothOSS, 1.0, 80, 360 },
/* Initialization */
loadConfig();
serialSetup();
cli(); // stop interrupts
/* Configuring TIMER1 (pattern generator) */
// Set timer1 to generate pulses
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
// Set compare register to sane default
OCR1A = 1000; /* 8000 RPM (60-2) */
// Turn on CTC mode
TCCR1B |= (1 << WGM12); // Normal mode (not PWM)
// Set prescaler to 1
TCCR1B |= (1 << CS10); /* Prescaler of 1 */
// Enable output compare interrupt for timer channel 1 (16 bit)
TIMSK1 |= (1 << OCIE1A);
// Set timer2 to run sweeper routine
TCCR2A = 0;
TCCR2B = 0;
TCNT2 = 0;
OCR2A = 249; /* With prescale of x64 gives 1ms tick */
// Turn on CTC mode
TCCR2A |= (1 << WGM21); // Normal mode (not PWM)
// Set prescaler to x64
TCCR2B |= (1 << CS22); /* Prescaler of 64 */
// Enable output compare interrupt for timer channel 2
//TIMSK2 |= (1 << OCIE2A); //Disabled as no longer using TIMER2 for sweep
/* Configure ADC as per http://www.glennsweeney.com/tutorials/interrupt-driven-analog-conversion-with-an-atmega328p */
// clear ADLAR in ADMUX (0x7C) to right-adjust the result
// ADCL will contain lower 8 bits, ADCH upper 2 (in last two bits)
ADMUX &= B11011111;
// Set REFS1..0 in ADMUX (0x7C) to change reference voltage to the
// proper source (01)
ADMUX |= B01000000;
// Clear MUX3..0 in ADMUX (0x7C) in preparation for setting the analog
// input
ADMUX &= B11110000;
// Set MUX3..0 in ADMUX (0x7C) to read from AD8 (Internal temp)
// Do not set above 15! You will overrun other parts of ADMUX. A full
// list of possible inputs is available in Table 24-4 of the ATMega328
// datasheet
// ADMUX |= 8;
// ADMUX |= B00001000; // Binary equivalent
// Set ADEN in ADCSRA (0x7A) to enable the ADC.
// Note, this instruction takes 12 ADC clocks to execute
ADCSRA |= B10000000;
// Set ADATE in ADCSRA (0x7A) to enable auto-triggering.
ADCSRA |= B00100000;
// Clear ADTS2..0 in ADCSRB (0x7B) to set trigger mode to free running.
// This means that as soon as an ADC has finished, the next will be
// immediately started.
ADCSRB &= B11111000;
// Set the Prescaler to 128 (16000KHz/128 = 125KHz)
// Above 200KHz 10-bit results are not reliable.
ADCSRA |= B00000111;
// Set ADIE in ADCSRA (0x7A) to enable the ADC interrupt.
// Without this, the internal interrupt will not trigger.
ADCSRA |= B00001000;
// pinMode(7, OUTPUT); /* Debug pin for Saleae to track sweep ISR execution speed /
pinMode(8, OUTPUT); /
Primary (crank usually) output /
pinMode(9, OUTPUT); /
Secondary (cam1 usually) output /
pinMode(10, OUTPUT); /
Tertiary (cam2 usually) output /
pinMode(11, OUTPUT); /
Knock signal for seank, ony on LS1 pattern, NOT IMPL YET /
#if defined(AVR_ATmega1280) || defined(AVR_ATmega2560)
pinMode(53, OUTPUT); /
crank /
pinMode(52, OUTPUT); /
cam 1 /
pinMode(51, OUTPUT); /
untested - should be cam2*/
#endif
sei(); // Enable interrupts
// Set ADSC in ADCSRA (0x7A) to start the ADC conversion
ADCSRA |= B01000000;
/* Make sure we are using the DEFAULT RPM on startup */
reset_new_OCR1A(currentStatus.rpm);
} // End setup
//! ADC ISR for alternating between ADC pins 0 and 1
  • Reads ADC ports 0 and 1 alternately. Port 0 is RPM, Port 1 is for
  • future fun (possible wheel selection)
    ISR(ADC_vect){
    if (analog_port == 0)
    adc0 = ADCL | (ADCH << 8);
    adc0_read_complete = true;
    Flip to channel 1 /
    //ADMUX |= B00000001;
    //analog_port = 1;
    Trigger another conversion /
    //ADCSRA |= B01000000;
    return;
    // if (analog_port == 1)
    // adc1 = ADCL | (ADCH << 8);
    // adc1_read_complete = true;
    Flip to channel 0 /
    Tell it to read ADC0, clear MUX0..3 /
    // ADMUX &= B11110000;
    // analog_port = 0;
    Trigger another conversion */
    // ADCSRA |= B01000000;
    // return;
/* Pumps the pattern out of flash to the port
  • The rate at which this runs is dependent on what OCR1A is set to
    ISR(TIMER1_COMPA_vect)
    This is VERY simple, just walk the array and wrap when we hit the limit /
    PORTB = output_invert_mask ^ pgm_read_byte(&Wheels[config.wheel].edge_states_ptr[edge_counter]); /
    Write it to the port */
edge_counter++;
if (edge_counter == Wheels[config.wheel].wheel_max_edges)
edge_counter = 0;
cycleDuration = micros() - cycleStartTime;
/* The tables are in flash so we need pgm_read_byte() */
/* Reset Prescaler only if flag is set /
if (reset_prescaler)
TCCR1B &= ~((1 << CS10) | (1 << CS11) | (1 << CS12)); /
Clear CS10, CS11 and CS12 /
TCCR1B |= prescaler_bits;
Reset next compare value for RPM changes /
OCR1A = new_OCR1A; /
Apply new "RPM" from Timer2 ISR, i.e. speed up/down the virtual "wheel" */
uint16_t tmp_rpm = currentStatus.base_rpm;
/* Just handle the Serial UI, everything else is in
  • interrupt handlers or callbacks from SerialUI.
    if(Serial.available() > 0) { commandParser(); }
if(config.mode == POT_RPM)
if (adc0_read_complete == true)
tmp_rpm = adc0 << TMP_RPM_SHIFT;
if (tmp_rpm > TMP_RPM_CAP) { tmp_rpm = TMP_RPM_CAP; }
else if (config.mode == LINEAR_SWEPT_RPM)
if(micros() > (sweep_time_counter + config.sweep_interval))
  sweep_time_counter = micros();
  if(sweep_direction == ASCENDING)
    tmp_rpm = currentStatus.base_rpm + 1;
    if(tmp_rpm >= config.sweep_high_rpm) { sweep_direction = DESCENDING; }
    tmp_rpm = currentStatus.base_rpm - 1;
    if(tmp_rpm <= config.sweep_low_rpm) { sweep_direction = ASCENDING; }
else if (config.mode == FIXED_RPM)
tmp_rpm = config.fixed_rpm;
currentStatus.base_rpm = tmp_rpm;
currentStatus.compressionModifier = calculateCompressionModifier();
if(currentStatus.compressionModifier >= currentStatus.base_rpm ) { currentStatus.compressionModifier = 0; }
setRPM( (currentStatus.base_rpm - currentStatus.compressionModifier) );
uint16_t calculateCompressionModifier()
if( (currentStatus.base_rpm > config.compressionRPM) || (config.useCompression != true) ) { return 0; }
//if( currentStatus.base_rpm > 400 ) { return 0;}
uint16_t crankAngle = calculateCurrentCrankAngle();
uint16_t modAngle = crankAngle;
uint16_t compressionModifier = 0;
switch(config.compressionType)
case COMPRESSION_TYPE_2CYL_4STROKE:
modAngle = crankAngle / 2;
compressionModifier = pgm_read_byte(&sin_100_180[modAngle]);
case COMPRESSION_TYPE_4CYL_4STROKE:
modAngle = (crankAngle % 180) ;
case COMPRESSION_TYPE_6CYL_4STROKE:
modAngle = crankAngle % 120;
compressionModifier = pgm_read_byte(&sin_100_120[modAngle]);
case COMPRESSION_TYPE_8CYL_4STROKE:
modAngle = crankAngle % 90;
compressionModifier = pgm_read_byte(&sin_100_90[modAngle]);
default:
//RPM scaler - Varies the amplitude of the compression modifier based on how far below the compression RPM point we are. Eg:
//If the compression RPM value is 400
//At 300rpm the amplitude will be 75%
//At 200rpm the amplitude will be 50%
//At 100rpm the amplitude will be 25% etc
//Base RPM must be below 650 to prevent overflow
if(config.compressionDynamic && (currentStatus.base_rpm < 655U) ) { compressionModifier = (compressionModifier * currentStatus.base_rpm) / config.compressionRPM; }
return compressionModifier;
uint16_t calculateCurrentCrankAngle()
if(cycleDuration == 0) { return 0; }
uint32_t cycleTime = micros() - cycleStartTime;
if( Wheels[config.wheel].wheel_degrees == 720 ) { cycleTime = cycleTime * 2; }
uint16_t tmpCrankAngle = ((cycleTime * 360U) / cycleDuration);
tmpCrankAngle += config.compressionOffset;
while(tmpCrankAngle > 360) { tmpCrankAngle -= 360; }
return tmpCrankAngle;
  • Validates the new user requested RPM and sets it if valid.
    void setRPM(uint16_t newRPM)
    if (newRPM < 10) { return; }
if(currentStatus.rpm != newRPM) { reset_new_OCR1A( newRPM ); }
currentStatus.rpm = newRPM;
void reset_new_OCR1A(uint32_t new_rpm)
uint32_t tmp;
uint8_t bitshift;
uint8_t tmp_prescaler_bits;
tmp = (uint32_t)(8000000.0/(Wheels[config.wheel].rpm_scaler * (float)(new_rpm < 10 ? 10:new_rpm)));
//tmp = (uint32_t)(8000000/(Wheels[config.wheel].rpm_scaler * (new_rpm < 10 ? 10:new_rpm)));
//uint64_t x = 800000000000ULL;
get_prescaler_bits(&tmp,&tmp_prescaler_bits,&bitshift);
new_OCR1A = (uint16_t)(tmp >> bitshift);
prescaler_bits = tmp_prescaler_bits;
reset_prescaler = true;
uint8_t get_bitshift_from_prescaler(uint8_t *prescaler_bits)
switch (*prescaler_bits)
case PRESCALE_1024:
return 10;
case PRESCALE_256:
return 8;
case PRESCALE_64:
return 6;
case PRESCALE_8:
return 3;
case PRESCALE_1:
return 0;
return 0;
//! Gets prescaler enum and bitshift based on OC value
void get_prescaler_bits(uint32_t *potential_oc_value, uint8_t *prescaler, uint8_t *bitshift)
if (*potential_oc_value >= 16777216)
*prescaler = PRESCALE_1024;
*bitshift = 10;
else if (*potential_oc_value >= 4194304)
*prescaler = PRESCALE_256;
*bitshift = 8;
else if (*potential_oc_value >= 524288)
*prescaler = PRESCALE_64;
*bitshift = 6;
else if (*potential_oc_value >= 65536)
*prescaler = PRESCALE_8;
*bitshift = 3;
*prescaler = PRESCALE_1;
*bitshift = 0;
This is the result of trying to compile the ArduStim.ino
Please keep in mind I don’t know what I don’t know.
/Users/ptschram/Downloads/ardustim/ardustim.ino:22:10: fatal error: globals.h: No such file or directory
compilation terminated.
exit status 1
Compilation error: globals.h: No such file or directory
Because the common example sketches mostly only consist of a single .ino file, it is easy to get the impression that this will always be the case. However, an Arduino sketch is actually a folder which may contain multiple code files. That is the case with the "ardustim" sketch. One of those multiple files is globals.h.
Perhaps you just copied the ardustim.ino file from the GitHub repository and thought you were done. That is not the case. You must download the entire sketch from the GitHub repository; not just the .ino file alone. I'll provide instructions you can follow to do that:
  1. Click the following link to open the page of the latest release in the Ardu-Stim project's GitHub repository:
    https://github.com/speeduino/Ardu-Stim/releases/latest
  2. Click the "Source code (zip)" link you will see under the "Assets" section of that page.
    A download of the ZIP file of the project will start.
  3. Wait for the download to finish.
  4. Extract the downloaded file to any convenient location on your computer.
  5. Start Arduino IDE.
  6. Select File > Open... from the Arduino IDE menus.
  7. In the "Open" dialog, navigate to the ardustim/ardustim subfolder of the folder you extracted at the previous step in these instructions.
  8. Select the ardustim.ino file from that folder.
  9. Click the "Open" button at the bottom of the dialog.
The "ardustim" sketch will open in a new Arduino IDE window. Take note that now Arduino IDE's editor panel will contain multiple tabs, one of which is named "globals.ino".
Now try compiling or uploading the sketch you opened using these instructions, just as you did before when you encountered the error before with the copy of the sketch you made. Hopefully this time everything will work as expected.
