Coding multiple switches/servo on Uno
By the way:
  • Always, always, always, always, always, always, always, always, always start with a schematic !
Hello danq84
Find below a simple solution coded in C++. You may need to mod the port pin addresses.
/* BLOCK COMMENT
  ATTENTION: This Sketch contains elements of C++.
  https://www.learncpp.com/cpp-tutorial/
  Many thanks to LarryD
  https://europe1.discourse-cdn.com/arduino/original/4X/7/e/0/7e0ee1e51f1df32e30893550c85f0dd33244fb0e.jpeg
  https://forum.arduino.cc/t/coding-multiple-switches-servo-on-uno/955336
#define ProjectName "Coding multiple switches/servo on Uno"
// INCLUDES
#include <Servo.h>
       Servo - Class for manipulating servo motors connected to Arduino pins.
    attach(pin )  - Attaches a servo motor to an I/O pin.
    attach(pin, min, max  ) - Attaches to a pin setting min and max values in microseconds
    default min is 544, max is 2400
    write()     - Sets the servo angle in degrees.  (invalid angle that is valid as pulse in microseconds is treated as microseconds)
    writeMicroseconds() - Sets the servo pulse width in microseconds
    read()      - Gets the last written servo pulse width as an angle between 0 and 180.
    readMicroseconds()   - Gets the last written servo pulse width in microseconds. (was read_us() in first release)
    attached()  - Returns true if there is a servo attached.
    detach()    - Stops an attached servos from pulsing its I/O pin.
// HARDWARE AND TIMER SETTINGS
// YOU MAY NEED TO CHANGE THESE CONSTANTS TO YOUR HARDWARE AND NEEDS
constexpr byte ButtonPins[] {A0, A1};     // portPin o---|button|---GND
constexpr byte LedPins[] {2, 3, 4, 5, 6, 7, 8, 9}; // portPin o---|220|---|LED|---GND
#define OutPutTest
constexpr  unsigned long OutPutTestTime {100};
// CONSTANT DEFINITION
enum {One, Two, Three, Four,Five,Six,Seven,Eight};
// VARIABLE DECLARATION AND DEFINITION
unsigned long currentTime;
struct TIMER {              // has the following members
  unsigned long duration;   // memory for interval time
  unsigned long stamp;      // memory for actual time
  bool onOff;               // control for start/stop
struct BUTTON {             // has the following members
  byte pin;                 // port pin
  bool statusQuo;           // current state
  TIMER scan;               // see timer struct
struct SERVO {
  int minimum;
  int maximum;
  int start_;
  int pin;
  Servo device;
} servos[] {
  {0, 180, 90, 10},
constexpr int SizeOfLeds {sizeof(LedPins) / sizeof(LedPins[0] / 2)};
struct KNOPPIN {
  BUTTON  knop;
  int counter;
  byte led[SizeOfLeds];
  TIMER stepper;
KNOPPIN knopPins[] {
  {ButtonPins[One], false, 20, 0, true, 0, LedPins[One], LedPins[Two], LedPins[Three], LedPins[Four], 1000, 0, false},
  {ButtonPins[Two], false, 20, 0, true, 0, LedPins[Five], LedPins[Six], LedPins[Seven], LedPins[Eight], 1000, 0, false},
  Serial.println(F("."));
  Serial.print(F("File   : ")), Serial.println(__FILE__);
  Serial.print(F("Date   : ")), Serial.println(__DATE__);
  Serial.print(F("Project: ")), Serial.println(ProjectName);
  pinMode (LED_BUILTIN, OUTPUT);  // used as heartbeat indicator
  //  https://www.learncpp.com/cpp-tutorial/for-each-loops/
  for (auto Input : ButtonPins) pinMode(Input, INPUT_PULLUP);
  for (auto Output_ : LedPins) pinMode(Output_, OUTPUT);
#ifdef OutPutTest
  // check outputs
  for (auto Output_ : LedPins) digitalWrite(Output_, HIGH), delay(OutPutTestTime);
  for (auto Output_ : LedPins) digitalWrite(Output_, LOW), delay(OutPutTestTime);
#endif
  for (auto servo : servos) servo.device.attach(servo.pin);
void loop () {
  currentTime = millis();
  digitalWrite(LED_BUILTIN, (currentTime / 500) % 2);
  bool trigger = true;
  for (auto &knopPin : knopPins) {
    if (currentTime - knopPin.knop.scan.stamp >= knopPin.knop.scan.duration) {
      knopPin.knop.scan.stamp = currentTime;
      int stateNew = digitalRead(knopPin.knop.pin) ^ 1;
      if (knopPin.knop.statusQuo != stateNew) {
        knopPin.knop.statusQuo = stateNew;
        Serial.println(stateNew ? "pressed" : "released");
        if (stateNew) {
          knopPin.stepper.stamp = 0;
          knopPin.stepper.onOff = true;
    if (currentTime - knopPin.stepper.stamp >= knopPin.stepper.duration && knopPin.stepper.onOff) {
      knopPin.stepper.stamp = currentTime;
      digitalWrite(knopPin.led[knopPin.counter], HIGH);
      if (++knopPin.counter == SizeOfLeds) knopPin.stepper.onOff = false;
  for (auto LedPin : LedPins) trigger = trigger && digitalRead(LedPin);
  servos[One].device.write(trigger ? servos[One].maximum : servos[One].minimum);
Thank you for both the code assistance/lesson and the instructions on how to use the forum(i.e., starting with a schematic)! What is the schematic software you are using? Is it easy to learn?
The software I use is no longer available (called WinQcad)
:frowning:
However, there is free software out there that is as good or better.
Example:
  • KiCAD
  • EasyEDA
  • and others
Look at YouTube for instructional videos.
Okay, I tried to "do my stuff" and everything works fine except the servo doesn't move so I'm assuming I've done a noob mistake(s). Thanks for pointing me to schematic software.
#define LEDon                   HIGH
#define LEDoff                  LOW
#define switchPushed            LOW
#define switchReleased          HIGH
const byte leds[]             = {3, 4, 5, 6,};
const byte leds2[]            = {7, 8, 9, 10,};
const byte heartbeatLED       = 13;
const byte pushButton1        = 2;
const byte pushButton2        = 11;
byte counter1                 = 0;
byte counter2                 = 0;
byte lastPushButton1          = switchReleased;
byte lastPushButton2          = switchReleased;
unsigned long switchMillis;
unsigned long yswitchMillis;
unsigned long lastHeartbeatMillis;
//  Below this is the servo code ***********************
#include <Servo.h>
Servo myservo;  // creat servo object to control a servo
int pos = 0;     // variable to store the servo position
// end of servo setup code
  myservo.attach(12);    // attaches servo on pin 12 to the servo object
  pinMode(heartbeatLED, OUTPUT);
  for (byte x = 0; x < sizeof(leds); x++)
    pinMode(leds[x], OUTPUT);
    digitalWrite(leds[x], LOW);
  for (byte x = 0; x < sizeof(leds2); x++)
    pinMode(leds2[x], OUTPUT);
    digitalWrite(leds2[x], LOW);
  pinMode(pushButton1, INPUT_PULLUP);
  pinMode(pushButton2, INPUT_PULLUP);
} //END of   setup()
  //**********************************          h e a r t b e a t   T I M E R
  if (millis() - lastHeartbeatMillis >= 500)
    //restart this TIMER
    lastHeartbeatMillis = millis();
    //toggle the LED
    digitalWrite(heartbeatLED, ! digitalRead(heartbeatLED));
  //**********************************          c h e c k S w i t c h e s   T I M E R
  //is it time to check the switches ?
  if (millis() - switchMillis >= 50)
    switchMillis = millis();
    checkSwitches();
if (counter1 == 4 && counter2 == 4)
          for (pos = 0; pos <= 90; pos += 1) {  //goes from 0 to 90 degrees
            myservo.write(pos);  // tell servo to go to position in variable 'pos'
            delay(15); //  waits 15 ms for the servo to reach the position
} //END of loop()
void checkSwitches()
  byte state;
  //**********************************            s w i t c h   1
  state = digitalRead(pushButton1);
  if (lastPushButton1 != state)
    //update to the new state
    lastPushButton1 = state;
    //is the switch pushed ?
    if (state == switchPushed)
      digitalWrite(leds[counter1], LEDon);
      counter1++;
      if (counter1 > sizeof(leds))
        counter1 = sizeof(leds);
  } //END of switch1
    //**********************************            s w i t c h   2
  state = digitalRead(pushButton2);
  if (lastPushButton2 != state)
    lastPushButton2 = state;
      digitalWrite(leds2[counter2], LEDon);
      counter2++;
      if (counter2 > sizeof(leds2))
        counter2 = sizeof(leds2);
  } //END of switch 2
} //END of   checkSwitches()
What do your debug prints tell you is happening with your code?
Schematic software can be nice, but really a hand drawn schematic is much easier, no learning curve except what makes a good schematic vs. a bad one, or a useful one from a useless one, neither of which any schematic cad program is going to help you along with much.
A schematic diagram is occasionally overkill. Many times a block diagram just showing your components and the signals that go between them is more than halfway helpful.
a7
To pass, you must ask 5 programming questions (that you do not understand) about the attached sketch:
//  https://forum.arduino.cc/t/coding-multiple-switches-servo-on-uno/955336
//  Version   YY/MM/DD     Comments
//  1.00      22/02/05     Running code
#include <Servo.h>
Servo myServo;
#define LEDon                     HIGH
#define LEDoff                    LOW
#define ENABLED                   true    //we are timing the servo
#define DISABLED                  false   //we are not timing the servo
const byte leds1[]              = {3, 4, 5, 6,};
const byte servoPin             = 12;
bool servoFlag                  = DISABLED;
const byte servoHomePosition    = 0;
const byte servoMaximumPosition = 180;
byte counter1                   = 0;
byte counter2                   = 0;
//TIMER stuff
unsigned long servoMillis;
const unsigned long servoTime   = 5 * 1000ul;  //5 seconds
//const unsigned long servoTime   = 24 * 60 * 60 * 1000ul;  //24 hours
  for (byte x = 0; x < sizeof(leds1); x++)
    pinMode(leds1[x], OUTPUT);
    digitalWrite(leds1[x], LOW);
  pinMode(servoPin, OUTPUT);
  myServo.attach(servoPin);
  myServo.write(servoHomePosition);
} //END of   setup()
  //toggle the heartbeat LED every 500ms
    //toggle the LED
  } //END of   this TIMER
    checkSwitches();
  //**********************************                   s e r v o   T I M E R
  //if enable, is it time to reset the servo ?
  if (servoFlag == ENABLED && millis() - servoMillis >= servoTime)
    //disable this TIMER
    //turn off all LEDs
      digitalWrite(leds1[x], LEDoff);
      digitalWrite(leds2[x], LEDoff);
    //get ready for the next sequence
    counter1 = 0;
    counter2 = 0;
    //return the servo to the home position
  //other non-blocking code goes here
} //END of   loop()
  byte state;
  //was there a change in switch state ?
    //if we are not timing the servo, is the switch pushed ?
    if (servoFlag == DISABLED && state == switchPushed)
      //don't go over the number of LEDs
      if (counter1 >= sizeof(leds1))
        counter1 = sizeof(leds1) - 1;
      digitalWrite(leds1[counter1], LEDon);
      counter1++;
      //if all LEDs are ON, it's time to operate the servo ?
      if (counter1 == sizeof(leds1) && counter2 == sizeof(leds2))
        //move the servo to the maximum position
        myServo.write(servoMaximumPosition);
        //enable the servo TIMER
        servoFlag = ENABLED;
        //start the TIMER
        servoMillis = millis();
    } //END of   if (servoFlag == DISABLED && state == switchPushed)
  } //END of   switch 1
      if (counter2 >= sizeof(leds2))
        //do not go over the size of the array
        counter2 = sizeof(leds2) - 1;
      counter2++;
        //start the TIMER
  } //END of   switch 2
Whew ... a task master, huh? Well five should be no problem. Here goes:
  1. Is there a reason you started with the two servo statements?
  2. I don't see the int pos = 0; // variable to store the servo position. Not necessary?
  3. What is the function of "bool servoFlag = DISABLED;
  4. Why the 5 second "const unsigned long servoTime"? Is the servo being "turned off or back to its original position after 5 second (and are the LEDs being turned off)?
  5. What other "non-blocking code" is the "locator" talking about?
  6. Is the checkSwitches() a way to run the void checkSwitches "sub-program"?
So question 4 was partially answered when I tried it, but is that line of code doing that after something else is checked?
A few of the questions asked were a bit lazy, you have to ask 2 more questions as a penalty.
Please reword, don't understand what you are asking ?
You do know that we are setting how long we want the servo TIMER to run for ?
const unsigned long servoTime   = 10 * 24 * 60 * 60 * 1000ul;  //10 days
Okay, I'll try and not be lazy, but I've already run the snowblower for 2.5 hours and shoveled for another .5 so I'm feeling a little lazy. Here goes:
  1. The void thing has me confused. What I've read says it means no information is being returned. What good is that if there is no info?
  2. I don't get the whole "PULLUP" thing. What I've read implies that it changes the status of a momentary switch. If that is true, why do that?
    Forget my confusing comment about the previous question 4.
void means the function checkSwitches does not return anything when you ‘call’ it.
This this function can still, however, change variables in the sketch such as flags, counters etc.
The following function returns an integer.
int addTwoNumbers( int A, int B)
return A + B;
int says the function addTwoNumbers returns an integer.
You ‘call’ it like this:
myAnswer = addTwoNumbers( 3, 4);
myAnswer becomes 7, notice the equals sign.
A floating input (nothing connected to the pin) on the Arduino has a resistance (impedance) of infinity (well ~100 million ohms.)
When you put a LOW (0V) on the pin, the pin will read LOW.
When you take that LOW away from the pin, it will still read a LOW.
When you put a HIGH (5V) on the pin, the pin will read HIGH.
When you take that HIGH away from the pin, it will still read a HIGH.
This phenomena is all do to the high input resistance of the pin.
We must somehow make the pin go to a HIGH when we remove the LOW from that pin (and vice versa).
We do this by adding an external resistor (usually < 100k) to the pin then going to 5V.
However, we can use a built in pull-up resistor inside the controller to do the same, saving on one component.
Each I/O pin has its own pull-up resistor that we can turn on using software.
Watch these:
For all the whole enchilada.
Why is servoFlag == DISABLED && needed ?
Calgary Canada here, where are you ?
Mid-state Maine.
Luxury, I've just been out, started the car, opened all the car windows, gone and got some KFC, come home, eaten lunch, now putting feet up.
Watching Winter Olympics on Tablet.
You northerners don't know how to live.
Tom...(Aussie.. Sunny, 22C) :grinning: :+1: :coffee: :australia:
@danq84
Did you missed post #34 and #35.
