what is with "L" LED? is it blinking when coins jumping out?
yes
can i add this skitch of yours to my skitch sir?
what should your sketch do?
coin counter sir
`#include <Wire.h>
#define ADD_BUTTON_PIN 5 // Pin for Add button
#define SUBTRACT_BUTTON_PIN 6 // Pin for Subtract button
#define START_BUTTON_PIN 7 // Pin for Start button
#define RELAY_PIN A0 // Pin for relay control
#define COIN_HOPPER_PIN 8 // Pin for coin hopper pulse
int coinCount = 0; // Coin count
int stopCount = 0; // Stop count (Starts from 0)
bool counting = false; // State of the counter (counting or not)
// LCD setup (16x2 display with I2C address 0x27)
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Debounce variables
unsigned long lastAddButtonTime = 0;
unsigned long lastSubtractButtonTime = 0;
unsigned long lastStartButtonTime = 0;
unsigned long debounceDelay = 200; // 200 ms debounce delay
// Initialize the LCD
lcd.init();
lcd.backlight();
// Initialize button and relay pins
pinMode(ADD_BUTTON_PIN, INPUT_PULLUP);
pinMode(SUBTRACT_BUTTON_PIN, INPUT_PULLUP);
pinMode(START_BUTTON_PIN, INPUT_PULLUP);
pinMode(RELAY_PIN, OUTPUT);
pinMode(COIN_HOPPER_PIN, INPUT_PULLUP);
// Start with the relay off
digitalWrite(RELAY_PIN, LOW);
// Initialize LCD display
displayLCD();
// Button handling
handleButtons();
// Check if the counting has started
if (counting) {
// Check for coin pulses from the coin hopper
if (digitalRead(COIN_HOPPER_PIN) == LOW) {
delay(50); // Debounce the coin hopper signal
coinCount++;
displayLCD();
// Stop counting when the desired count is reached
if (coinCount >= stopCount) {
counting = false;
digitalWrite(RELAY_PIN, LOW); // Turn off the relay
// Function to handle button presses for adding, subtracting, and starting
void handleButtons() {
// Add button
if (digitalRead(ADD_BUTTON_PIN) == LOW && (currentMillis - lastAddButtonTime) > debounceDelay) {
lastAddButtonTime = currentMillis;
stopCount++; // Increase stopCount by 1
displayLCD();
// Subtract button
if (digitalRead(SUBTRACT_BUTTON_PIN) == LOW && (currentMillis - lastSubtractButtonTime) > debounceDelay) {
lastSubtractButtonTime = currentMillis;
if (stopCount > 0) stopCount--; // Decrease stopCount but never below 0
displayLCD();
// Start button
if (digitalRead(START_BUTTON_PIN) == LOW && (currentMillis - lastStartButtonTime) > debounceDelay) {
lastStartButtonTime = currentMillis;
startCounting();
// Function to start the counting process
void startCounting() {
counting = true;
coinCount = 0; // Reset coin count
digitalWrite(RELAY_PIN, HIGH); // Turn on the relay
displayLCD();
// Function to display the information on the LCD
void displayLCD() {
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Counter : ");
lcd.print(coinCount); // Display current coin count
lcd.setCursor(0, 1);
lcd.print("Stop Cnt: ");
lcd.print(stopCount); // Display the stop count (starts from 0)
here`s my code sir
when i change this line to high the relay is still on
why it counting only to given amount?
lcd.init();
lcd.backlight();
displayLCD();
if (counting) {
coinCount++;
displayLCD();
while (digitalRead(COIN_HOPPER_PIN) == LOW); // waiting until pulse ends
counting = false;
} else handleButtons();
// Add button
displayLCD();
// Subtract button
if (stopCount > 0) {
displayLCD();
// Start button
counting = true;
displayLCD();
void displayLCD() {
lcd.clear();
yes sir..counting by pieces
did you change anything in the sketch sir?
maybe
where? i only see the messing in the original sketch in the include wire.h
messing?
missing
if you replace your sketch in post #46 with mine and click
symbol, then it shows comparison window and any changes will be marked
i try the code sir..the problem is in first attempt the counting is working well but when i press again the start button the lcd will go off and on again the hopper starts then stop
i need to reboot the arduino to back to normal and the L led in the arduino is not blinking when there is coin passing the coin hopper sensor
in code it is not present, so your problem is for sure electrical nature. how do you powering your project? make new diagram
