Command Queue Not Working Properly
I am using a example program given from the kit's website where everything works fine execpt the command queueing system. Currently, when I start the program with a button press, the robot turns right indefinitely even though I've added other commands to my command queue. I am using an arduino uno rev 3, L298N motor driver, breadboard mini, and two DC motors 45-to-1 with encoders. My IDE software version is 2.3.2. Appreciate the help, please let me know if you need anymore information.
#include <Arduino.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>    // this library is needed for the 20x4 display
#define VERSION           "1"
#define DISPLAY_PRESENT        1  // set to 1 if the 20x4 I2C Display is present
//  Board: Ardunio Uno
//  DEFINE ALL I/O PIN CONNECTIONS
//    *** DO NOT CHANGE ***
#define PIN_MTR1_ENCA          2
#define PIN_MTR2_ENCA          3
#define PIN_PB_START           4
#define PIN_MTR1_DIR_FWD       5
#define PIN_MTR1_DIR_REV       6
#define PIN_MTR2_DIR_FWD       7
#define PIN_MTR2_DIR_REV       8
#define PIN_MTR1_PWM           9
#define PIN_MTR2_PWM          10
#define PIN_SONIC_PULSE       11
#define PIN_SONIC_TRIGGER     12
#define PIN_LED               13
//************************* ADJUST THE FOLLOWING TO MATCH YOUR ROBOT ****************************
#define ENCODER_COUNTS_PER_REV  540   // Set to the number of encoder pulses per wheel revolution
#define MM_PER_REV              235   // Set to the number of mm per wheel revolution (Hence : Diameter * Pi)
#define ENCODER_COUNTS_90_DEG   200   // Set to the number of encoder pulses to make a 90 degree turn
#define SPEED_MIN               120    // Minimum speed (pulses/second) use at the end of individual moves
LiquidCrystal_I2C display(0x27,20,4);  // set the LCD address to 0x27 for a 20 chars and 4 line display
unsigned long usLast;
long usecElapsed;
long usScanLong;
int  usLongResetCount;
long usScanAvg;
long timerusScan;
int scanCount;
long timerRunTime;
int speedFwd;
int speedTurn;
int flagTimeRun;
int flagLastMoveFwd;
int flagLED;
float sonicDistance;
int printStep;
int printLastCmd;
unsigned long msTimerPrint;
unsigned long msTimerMPU;
unsigned long timerSonicRange;
unsigned long timerPBStartOn;
unsigned long timerPBStartOff;
unsigned long timerDelay;
#define MAX_COMMANDS    60        // Maximum number of motion commands allowed
// Command object is used to hold a list of commands to be executed
class Command
  private:
    int start;
    int end;
    int last_cmd;
    int list[MAX_COMMANDS];
    int p1[MAX_COMMANDS];
    int flagFirstScan;
  public:
    inline int   current()  { return list[start]; };
    inline int   getParameter1() { return p1[start]; };
    inline int   empty()    { if (start==end) return 127; else return 0; };
    inline int   last()     { return last_cmd; };
    inline int   firstScan() { int flag = flagFirstScan; flagFirstScan = 0; return flag; }
    Command() {
      clear();
    void clear() {
      start = 0;
      end = 0;
      last_cmd = 0;
      flagFirstScan = 0;
      int n = 0;
      for (n=0;n<MAX_COMMANDS;n++) { list[n] = 0;  p1[n] = 0; }
    void add(int cmd) {
      add(cmd,0);
    void add(int cmd,int par1) {
      list[end] = cmd;
      p1[end] = par1;
      end++;
      if (end >= MAX_COMMANDS) end = 0;
    int next() {
      flagFirstScan = 127;
      if (empty()) return 0;
      last_cmd = list[start];   // save last command
      start++;
      if (start >= MAX_COMMANDS) start = 0;
      return list[start];
Command cmdQueue;
//  List of possible vehicle motion commands
//   -- Additional motion commands can be added which will require code to execute
#define VEHICLE_START_WAIT      1       // Wait for the start button to be pressed
#define VEHICLE_START           2       // First motion command after button press
#define VEHICLE_FORWARD         10
#define VEHICLE_TURN_RIGHT      40
#define VEHICLE_TURN_LEFT       50
#define VEHICLE_SET_MOVE_SPEED  101
#define VEHICLE_SET_TURN_SPEED  102
#define VEHICLE_SET_ACCEL       105
#define VEHICLE_FINISHED        900     // Must be at the end of the command list
#define VEHICLE_STOP            1000
#define VEHICLE_ABORT           2000    // Used to abort the current movement list and stop the robot
// Loads the command queue with the robots commands to be executed during a run
void loadCommandQueue() {
  cmdQueue.clear();
  cmdQueue.add(VEHICLE_START_WAIT);     // do not change this line - waits for start pushbutton
  cmdQueue.add(VEHICLE_START);          // do not change this line
  // Define robot movement speeds
  // Speed is encoder pulses per second.
  // There is a maximum speed.  Testing will be required to learn this speed.
  //    SETTING THE SPEEDS ABOVE THE MOTOR'S MAXIMUM SPEED WILL CAUSE STRANGE RESULTS
      cmdQueue.add(VEHICLE_SET_MOVE_SPEED,500);     // Speed used for forward movements
      cmdQueue.add(VEHICLE_SET_TURN_SPEED,300);     // Speed used for left or right turns
      cmdQueue.add(VEHICLE_SET_ACCEL,400);         // smaller is softer   larger is quicker and less accurate moves
        // Example list of robot movements
        // This block is modified for each tournament
      cmdQueue.add(VEHICLE_TURN_RIGHT);
      cmdQueue.add(VEHICLE_FORWARD,500);
      cmdQueue.add(VEHICLE_TURN_LEFT);
          // This MUST be the last command.
      cmdQueue.add(VEHICLE_FINISHED);
// Motion object (like a library) that calculates the acceleration used for motor speed
// control.
// Distance is encoder pulses
// Accel is encoder pulses per second^2
class MotionLogic
  private:
    long timeAccel;
    long timeAtSpeed;
    long timeDecel;
    long timeRunning;
    long timeRunningLast;
    long timerUpdate;
    int pinPWM;
    int outputPWM;
    int outputFwd;
    int outputRev;
    int running;
    int flagStopped;
    int counterStopped;
    int pwmLoopI;
    int pwmLoopP;
    int debugPrint;
  public:
    long accelRate;
    long decelRate;
    long position;
    long posProfile;
    int speedTarget;
    int speedProfile;
    int speedActual;
    int speedMinimum;
    int speedAtDecel;
    long countEncoder;
    long countEncoderLast;
    inline int getOutputPWM() { return outputPWM; };
    inline int getOutputFwd() { return outputFwd; };
    inline int getOutputRev() { return outputRev; };
    inline void incrEncoder() { countEncoder++; };
    inline void debugOn() { debugPrint = 1; };   // used this function to turn on debug print statements
                                                 // recommended to only turn on debug for left or right motor.  NOT both.
    inline int debugState() { return debugPrint; };
    MotionLogic() {
      outputPWM = 0;
      outputFwd = 0;
      outputRev = 0;
      countEncoder = 0;
      countEncoderLast = 0;
      debugPrint = 0;
      accelRate = 200;
      decelRate = 200;
      posProfile = 0;
      speedActual = 0;
      speedTarget = 0;
      speedAtDecel = -10000;
      timeRunning = 0;
      timeRunningLast = 0;
      flagStopped = 0;
      counterStopped = 0;
      running = 0;
    int isStopped() {
      if (flagStopped) return 1;
      return 0;
    void setParams(long accel,int spdMin,int pPWM) {
      accelRate = accel;
      decelRate = accel;
      speedMinimum = spdMin;
      pinPWM = pPWM;
    // This object uses the same value for accelerate and decelerate rate
    void setAccel(long accel) {
      accelRate = accel;
      decelRate = accel;
    // This function must be called to start a motion
    void startMove(int pos, int spd) {
      if (spd > 0) {
        outputFwd = 1;
        outputRev = 0;
        outputFwd = 0;
        outputRev = 1;
      speedTarget = abs(spd);
      position = abs(pos);
      if (debugPrint) { Serial.print(F("Motion - speed       = ")); Serial.println(speedTarget); }
      if (debugPrint) { Serial.print(F("Motion - position    = ")); Serial.println(position); }
      float tAccel = (float) speedTarget / (float) accelRate;
      float tDecel = (float) speedTarget / (float) decelRate;
      float distAccel = (float) speedTarget / 2.0 * tAccel;
      float distDecel = (float) speedTarget / 2.0 * tDecel;
      float distAtSpeed = (float) position - distAccel - distDecel;
      if (distAtSpeed < 0.0) {  // current written as accel and decel same
        // Serial.println("Motion - Short move logic");
        distAccel = (float) position / 2.0;
        distDecel = (float) position / 2.0;
        distAtSpeed = 0.0;
        tAccel = sqrt(distAccel * 2.0 / (float) accelRate);
        tDecel = sqrt(distDecel * 2.0 / (float) decelRate);
      float tAtSpeed = distAtSpeed / (float) speedTarget;
        // times are in microseconds
      timeAccel = 0;
      timeAtSpeed = tAccel * 1000000;
      timeDecel = timeAtSpeed + tAtSpeed * 1000000;
      pwmLoopI = 0;
      pwmLoopP = 0;
      countEncoder = 0;
      posProfile = 0;
      timeRunning = 0;
      timerUpdate = 0;
      flagStopped = 0;
      counterStopped = 0;
      running = 1;
    void stop() {
      outputPWM = 0;
      outputFwd = 0;
      outputRev = 0;
      analogWrite(pinPWM,outputPWM);
      running = 0;
      posProfile = 0;
      speedProfile = 0;
      speedTarget = 0;
    void updateMotion(long usecElapsed) {
      int flagUpdate = 0;
      timerUpdate += usecElapsed;
      if (timerUpdate >= 30000) {
        long delta = countEncoder - countEncoderLast;
        speedActual = delta * 1000000L / timerUpdate;
        countEncoderLast = countEncoder;
        timerUpdate = 0;
        flagUpdate = 1;
        if (running == 0 && speedActual < 4) {
          if (!flagStopped) counterStopped++;
          if (counterStopped > 2) flagStopped = 1;
      if (running == 0) {
        outputPWM = 0;
        outputFwd = 0;
        outputRev = 0;
        pwmLoopP = 0;
        pwmLoopI = 0;
        return;
      if (countEncoder >= (position - 2)) {
        if (debugPrint) {
          Serial.print("STOPPED,");
          Serial.print("timeRunning:");
          Serial.print(timeRunning);
          Serial.print(",encoder:");
          Serial.print(countEncoder);
          Serial.print(",speedActual:");
          Serial.print(speedActual);
          Serial.print(",pwm:");
          Serial.println(outputPWM);
        stop();
        return;
      timeRunning += usecElapsed;
      if (flagUpdate == 0) return;
      float speed;
      if (timeRunning < timeAtSpeed) {
        speed = (float) timeRunning / 1000000.0 * (float) accelRate;
        speedProfile = (int) speed;
        //if (debugPrint) { Serial.print(" - Accel speedProfile = "); Serial.println(speedProfile); }
      } else if (timeRunning < timeDecel) {
        speedProfile = speedTarget;
        //if (debugPrint) { Serial.print(" - At Speed speedProfile = "); Serial.println(speedProfile); }
        if (speedAtDecel <= -10000) speedAtDecel = speedProfile;
        speed = (float) (timeRunning - timeDecel) / 1000000.0 * (float) decelRate;
        speedProfile = speedAtDecel - (int) speed;
        if (speedProfile < speedMinimum) speedProfile = speedMinimum;
        //if (debugPrint) { Serial.print(" - Decel speedProfile = "); Serial.println(speedProfile); }
      posProfile += (speedProfile * (timeRunning - timeRunningLast)) / 1000000;
      timeRunningLast = timeRunning;
      long perror = posProfile - countEncoder;
      int serror = speedProfile - speedActual;
          // This program uses a PI loop to control speed
          // This loop is NOT tuned.  Meaning testing is required to tune the loop
          // which will provide the best preformance
      pwmLoopI += serror / 4;
      pwmLoopP = serror / 2;
      outputPWM = pwmLoopP + pwmLoopI;
      if (outputPWM < 0) outputPWM = 0;
      if (outputPWM > 254) outputPWM = 254;
      if (debugPrint) {
        Serial.print(",speedProfile:");
        Serial.print(speedProfile);
        Serial.print(",pos_error:");
        Serial.print(perror);
        Serial.print(",speed_error:");
        Serial.print(serror);
        Serial.print(",loopI:");
        Serial.print(pwmLoopI);
        Serial.print(",loopP:");
        Serial.print(pwmLoopP);
MotionLogic mtrLeft;
MotionLogic mtrRight;
// Interupt function for counting left motor encoder pulses
void encoderIntLeft()  {
  mtrLeft.incrEncoder();
// Interupt function for counting right motor encoder pulses
void encoderIntRight()  {
  mtrRight.incrEncoder();
void setMotorOutputs() {
  if (mtrLeft.getOutputFwd()) digitalWrite(PIN_MTR1_DIR_FWD, HIGH);
  else                        digitalWrite(PIN_MTR1_DIR_FWD, LOW);
  if (mtrLeft.getOutputRev()) digitalWrite(PIN_MTR1_DIR_REV, HIGH);
  else                        digitalWrite(PIN_MTR1_DIR_REV, LOW);
  if (mtrRight.getOutputFwd()) digitalWrite(PIN_MTR2_DIR_FWD, HIGH);
  else                         digitalWrite(PIN_MTR2_DIR_FWD, LOW);
  if (mtrRight.getOutputRev()) digitalWrite(PIN_MTR2_DIR_REV, HIGH);
  else                         digitalWrite(PIN_MTR2_DIR_REV, LOW);
// Trigger Sonic range finder
void triggerRangeFinder() {
    digitalWrite(PIN_SONIC_TRIGGER, LOW);
    delayMicroseconds(20);
    digitalWrite(PIN_SONIC_TRIGGER, HIGH);
    delayMicroseconds(10);
    int pcount = pulseIn(PIN_SONIC_PULSE, HIGH);
    sonicDistance = float(pcount) * 0.34 / 2.0;
    //Serial.print(F("Sonic pcount = "));
    //Serial.print(pcount);
    //Serial.print(F("  mm = "));
    //Serial.println(sonicDistance);
// Used to display fault codes on the built-in LED
void faultCodeLED(int count) {
  int i = -1;
  flagLED = true;
  toggleLED();
  while (-1) {
    i = count;
    delay(2000);
    while (i > 0) {
      toggleLED();
      delay(300);
      toggleLED();
      delay(300);
      i--;
// Toggle the Ardunio built in LED each time this function is executed
void toggleLED() {
  if (flagLED) {
    digitalWrite(PIN_LED,LOW);
    flagLED = false;
    digitalWrite(PIN_LED,HIGH);
    flagLED = true;
//  This function is called to update the variable information on the display.
//  Only limited information is updated at a time since the write commands are slow
void initDisplay() {
  // Display is 20 characters wide by 4 lines
  // 01234567890123456789
  // Cmd:
  // Rng: xxxx.x cm
  // Time: xx.xxx  v.v.vv
  display.clear();
  display.setCursor(0,0);
  display.print(F("Cmd:"));
  display.setCursor(0,2);
  display.print(F("Rng:"));
  display.setCursor(0,3);
  display.print(F("Time:"));
void updateDisplay() {
  int cmd;
  char buff[12];
  int i;
  int itmp;
  float f;
  switch (printStep) {
    case 0 :
        cmd = cmdQueue.current();
        if (printLastCmd != cmd) {
          display.setCursor(4,0);
          switch (cmd) {
            case VEHICLE_START_WAIT :
                            // 4567890123456789
              display.print(F("WAIT START     "));
            case VEHICLE_START :
              display.print(F("WAIT RELEASE   "));
            case VEHICLE_FORWARD :
              display.print(F("FORWARD        "));
            case VEHICLE_TURN_RIGHT :
              display.print(F("TURN RIGHT     "));
            case VEHICLE_TURN_LEFT :
              display.print(F("TURN LEFT      "));
            case VEHICLE_FINISHED :
              display.print(F("FINISHED       "));
            case VEHICLE_STOP :
              display.print(F("STOP           "));
            case VEHICLE_ABORT :
              display.print(F("ABORT          "));
            default :
              display.print(F("***unknown**"));
          printLastCmd = cmd;
    case 1 :
    case 2 :
    case 3 :
        display.setCursor(4,2);
        display.print(sonicDistance,1);
        display.print("cm  ");
    case 4 :
        display.setCursor(6,3);
        f = (float) timerRunTime / 1000000.0;
        display.print(f,3);
    default :
        printStep = -1;
  printStep++;  // increment the print step value to the next sequence step
  toggleLED();
// The setup() is called once at the power up of the Arduino
  pinMode(PIN_LED, OUTPUT);
  flagLED = false;
  // Only uncomment one motor at a time to use the Serial Plotter function to tune the PID loop
  //mtrLeft.debugOn();
  //mtrRight.debugOn();
  if (mtrLeft.debugState() || mtrRight.debugState()) {
    Serial.println(F("Setup()..."));
  if (DISPLAY_PRESENT) {
    //Serial.println(F("Display init()"));
    display.init();  //initialize the lcd
    display.backlight();  //open the backlight
    display.clear();
    display.print(F("Start Up....."));
  pinMode(PIN_SONIC_TRIGGER,OUTPUT);
  pinMode(PIN_SONIC_PULSE,INPUT);
  pinMode(PIN_PB_START, INPUT_PULLUP);
  pinMode(PIN_MTR1_PWM,OUTPUT);
  pinMode(PIN_MTR2_PWM,OUTPUT);
  pinMode(PIN_MTR1_ENCA, INPUT_PULLUP);
  pinMode(PIN_MTR2_ENCA, INPUT_PULLUP);
  sonicDistance = 0.0;
  timerSonicRange = 0;
  timerDelay = 0;
  attachInterrupt(digitalPinToInterrupt(PIN_MTR1_ENCA), encoderIntLeft, RISING);
  attachInterrupt(digitalPinToInterrupt(PIN_MTR2_ENCA), encoderIntRight, RISING);
  pinMode(PIN_MTR1_DIR_FWD,OUTPUT);
  pinMode(PIN_MTR1_DIR_REV,OUTPUT);
  pinMode(PIN_MTR2_DIR_FWD,OUTPUT);
  pinMode(PIN_MTR2_DIR_REV,OUTPUT);
  speedFwd = 100;
  speedTurn = 100;
  int speedAccel = 100;
  int speedMin  = SPEED_MIN;
  mtrLeft.setParams(speedAccel, speedMin, PIN_MTR1_PWM);
  mtrRight.setParams(speedAccel, speedMin, PIN_MTR2_PWM);
  //Serial.println(F("Initialize Display with background text"));
  if (DISPLAY_PRESENT) { initDisplay(); }
  printStep = 0;
  loadCommandQueue();
  usScanLong = 0;
  usScanAvg = 0;
  timerusScan = 0;
  scanCount = 0;
  usLongResetCount = 0;
  //Serial.println(F("....End Setup"));
  usLast = micros();
// The following function will execute then exit.  The Ardunio will constantly call this
// function.  The function should not have delays as this will effect the motor's speed.
long distance;
  int speed;
  float fspd;
  long ldelta;
  long delayWait;
  int itmp;
  unsigned long current = micros();
  usecElapsed = current - usLast;
  usLast = current;
  if (usecElapsed > usScanLong) usScanLong = usecElapsed;
  timerusScan += usecElapsed;
  scanCount++;
  if (timerusScan > 1000000) {
    usScanAvg = timerusScan / scanCount;
    timerusScan = 0;
    scanCount = 0;
    usLongResetCount++;
    if (usLongResetCount > 10) {
      usScanLong = 0;
  mtrLeft.updateMotion(usecElapsed);
  mtrRight.updateMotion(usecElapsed);
  if (msTimerPrint > 200000) {
    if (DISPLAY_PRESENT) { updateDisplay(); }
    msTimerPrint = 0;
  msTimerPrint += usecElapsed;
  int newCmd = false;
  if (cmdQueue.firstScan()) {
    newCmd = true;
  int pbStart = !digitalRead(PIN_PB_START);
  if (pbStart) {
    timerPBStartOn  += usecElapsed;
    timerPBStartOff = 0;
    timerPBStartOn = 0;
    timerPBStartOff += usecElapsed;
  if (cmdQueue.current() > VEHICLE_START && cmdQueue.current() < VEHICLE_ABORT) {
    if (timerPBStartOn > 100000) {
      cmdQueue.clear();
      cmdQueue.add(VEHICLE_ABORT);
      mtrLeft.stop();
      mtrRight.stop();
      setMotorOutputs();
  if (flagTimeRun) timerRunTime += usecElapsed;
  switch (cmdQueue.current()) {
        cmdQueue.next();
      timerSonicRange += usecElapsed;
      if (timerSonicRange > 1500000) {
        triggerRangeFinder();
      timerRunTime = 0;
      if (timerPBStartOff > 100000) {
        cmdQueue.next();
        flagTimeRun = 1;
        flagLastMoveFwd = 0;
      if (newCmd) {
        distance = ((long) cmdQueue.getParameter1() * (long) ENCODER_COUNTS_PER_REV / (long) MM_PER_REV);
        speed = speedFwd;
        mtrLeft.startMove(distance,speed);
        mtrRight.startMove(distance,speed);
        setMotorOutputs();
      if (mtrLeft.isStopped() && mtrRight.isStopped()) {
        setMotorOutputs();
        cmdQueue.next();
      if (newCmd) {
        distance = ENCODER_COUNTS_90_DEG;
        speed = speedTurn;
        mtrRight.startMove(distance,speed * -1);
        setMotorOutputs();
        setMotorOutputs();
        cmdQueue.next();
      if (newCmd) {
        speed = speedTurn;
        mtrLeft.startMove(distance,speed * -1);
        setMotorOutputs();
        setMotorOutputs();
        cmdQueue.next();
    case VEHICLE_SET_MOVE_SPEED :
      speedFwd = cmdQueue.getParameter1();
      cmdQueue.next();
    case VEHICLE_SET_TURN_SPEED :
      speedTurn = cmdQueue.getParameter1();
      cmdQueue.next();
    case VEHICLE_SET_ACCEL :
      mtrLeft.setAccel(cmdQueue.getParameter1());
      mtrRight.setAccel(cmdQueue.getParameter1());
      cmdQueue.next();
    default :
      if (newCmd) {
        mtrLeft.stop();
        mtrRight.stop();
        setMotorOutputs();
      flagTimeRun = 0;
      mtrLeft.stop();
      mtrRight.stop();
      setMotorOutputs();
      flagTimeRun = 0;
      if (timerPBStartOff > 200000) {
        loadCommandQueue();
Kit: Welcome to Top Finish Kits - Vehicle kits for Science Olympiad
There is a set of queues in which you can add to. It's intention is to execute a series of motions that follow the queue. For example, I've added cmdQueue.add(VEHICLE_TURN_RIGHT); as well as cmdQueue.add(VEHICLE_FORWARD,500);. In theory, the void loop() should execute each line in order? I am completely new to this, but I've tried to understand what's going on. I have a feeling that it has to do with this line here, if (mtrLeft.isStopped() && mtrRight.isStopped()).
On my end, the robot continuously turns right for about 30 seconds, delays for another 25 seconds? Then turns right for another 30 seconds. It goes on and on until the motors start stuttering.
Well, it isn't really suppose to be a kit. It only gives you diagrams and some CAD files to work off of. The websites main purpose is to nudge you in the right direction for teams that don't have access to coaching. The website purposefully didn't provide contact information.
I am currently using 6 double AA batteries, which provide a little under 9v.
Here is my current setup. Sorry for the wiring.
The website linked above has detailed diagrams on the specific wirings and parts.
@prolongedpost - There are very few differences in your posted sketch compared to either of the versions from the kit website.
Did either original unmodified sketch work?
Can you try it without the LCD?
# define DISPLAY_PRESENT        0  // 20x4 I2C Display not present
The only significant difference I can see is that your queue starts movement with a turn.
Try just placing a motion command as first, like
TIA and HTH
a7
