// Tiny OS Bluetooth Bee Shield Test Sketch - Sending AT Commands
// Ensure the UART/DLine switch is in the DLine position as AT Commands will be sent via software serial
// Connect RX from the Bluetooth Bee to pin 2 on the Arduino.
// Connect TX from the Bluetooth Bee to pin 3 on the Arduino
// In normal use both the switches on the switch block are moved to the left
// to send AT commands remove all power and move the top switch to the right
// Switch the power on, the green STATE led will flash on and off slowly
// Open up the Serial Port Monitor
// Type in AT and click on the SEND button, OK will be printed in the monitor
// showing the module is receiving commands.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(0, 1); // RX, TX
String buildString = ""; // Stores response of bluetooth device
// which simply allows \n between each response.
// Hardware Serial port set to 9600
Serial.println("Ensure that both NL and CR are selected");
Serial.println("Enter AT commands");
// SoftwareSerial "com port" data rate. 38400.
mySerial.begin(38400); // default speed in AT mode
mySerial.print("\r\n+STWMOD=0\r\n");
mySerial.print("\r\n+STNA=SeeeduinoBluetooth\r\n");
mySerial.print("\r\n+STAUTO=0\r\n");
//bluetooth.print("\r\n+STOAUT=0\r\n");
mySerial.print("\r\n +STPIN=0000\r\n");
//blueToothSerial.print("\r\n +STCHO\r\n");
//bluetooth.print("\r\n+RTADDR\r\n");
delay(2000); // This delay is required.
mySerial.print("\r\n+INQ=1\r\n");
// Read device output if available.
if (mySerial.available()) {
while(mySerial.available()) { // While there is more to be read, keep reading.
buildString += (char)mySerial.read();
Serial.println(buildString);
buildString = ""; // reset string
// Read user input if available.
if (Serial.available()){
delay(10);
mySerial.write(Serial.read());
Commands AT not function with bluetooth Bee 1.2, How do i do??
