Bom dia! Estou com problemas no código para que o sensor ultrassônico seja lido apenas uma vez enquanto detectar presença e depois de um tempo volte a detectar.
// INCLUSÃO DE BIBLIOTECAS
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#include <NewPing.h>
// DEFINIÇÕES DE PINOS
#define pinRx 10
#define pinTx 11
define ligat 8// PINO QUE ATIVA INTERRUPÇAO DO ARDUINO 2 MENSAGEM BOAS VINDAS APROXIME
#define TRIGGER_PINT 6 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PINT 9 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCET 100 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
int a = 0;
static unsigned long tempo =0;
// DEFINIÇÕES
#define volumeMP3 30
#define DEBUG
// INSTANCIANDO OBJETOS
SoftwareSerial playerMP3Serial(pinRx, pinTx);
NewPing sonar2(TRIGGER_PINT, ECHO_PINT, MAX_DISTANCET); // NewPing setup of pins and maximum distance.
DFRobotDFPlayerMini playerMP3;
const byte interruptPin = 2;
int dist2 = 0;
void sens2(); //função para leitura sensor
void ruim();
// DECLARAÇÃO DE FUNÇÕES
playerMP3Serial.begin(9600);
pinMode (ligat , OUTPUT);
digitalWrite(ligat, HIGH);
Serial.println(F("Iniciando DFPlayer ... (Espere 3~5 segundos)"));
if (!playerMP3.begin(playerMP3Serial)) { // COMUNICAÇÃO REALIZADA VIA SOFTWARE SERIAL
Serial.println(F("Falha ao iniciar:"));
Serial.println(F("1.Confira as conexões!"));
Serial.println(F("2.Confira o cartão SD!"));
while(true){
delay(0);
#ifdef DEBUG
Serial.println("Fim Setup");
#endif
pinMode(interruptPin, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(interruptPin), ruim, RISING);
sens2();
void sens2()
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
int dist2 = sonar2.ping_cm(); // Send ping, get distance in cm and print result (0 = outside set distance range)
if((dist2 >5) && (dist2< 8))
while(!a==1){
digitalWrite(ligat,LOW);
delay (200);
delay(2300);
delay (100);
delay(100);
playerMP3.playFolder(2, 2);
Serial.println("SENS");
delay(5000);
a=1;
unsigned long tempo = millis();
if (millis()-tempo >= 15000){
a=0;
tempo = millis();
void ruim()
Serial.println("SENS2");
delayMicroseconds(5000000);
O que tem de errado nesse código? Me ajudem por favor.
