Thanks so much for this provision @ptillisch. I so much appreciate your help so far.
I did just exactly as you instructed in you immediate message.
From going to espressif's webpage to copy the stable release link to reinstalling the esp32 by Espressif board Manager. However, i installed version 3.0.0-rc as i also believe that previous version are more stable than later version, which is a common belief. then after intsallation, i attempted compiling the following code:
and i still got the error message below:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\pc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\pc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\pc\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none,ZigbeeMode=default -ide-version=10819 -build-path C:\Users\pc\AppData\Local\Temp\arduino_build_58203 -warnings=none -build-cache C:\Users\pc\AppData\Local\Temp\arduino_cache_469761 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-12.2.0_20230208.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.esp-rv32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.openocd-esp32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20230921.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-12.2.0_20230208.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.mkspiffs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.mklittlefs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-12.2.0_20230208.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.dfu-util.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-442a798083.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -verbose C:\Users\pc\Documents\Arduino archives\teawithGPT\sketch_jun29a\sketch_jun29a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\pc\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\pc\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\pc\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none,ZigbeeMode=default -ide-version=10819 -build-path C:\Users\pc\AppData\Local\Temp\arduino_build_58203 -warnings=none -build-cache C:\Users\pc\AppData\Local\Temp\arduino_cache_469761 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool_py.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.esptool_py-4.6.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.6 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-12.2.0_20230208.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.esp-rv32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.esp-rv32-2302.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp-rv32\2302 -prefs=runtime.tools.openocd-esp32.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.openocd-esp32-v0.12.0-esp32-20230921.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.12.0-esp32-20230921 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-12.2.0_20230208.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.xtensa-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.mkspiffs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.riscv32-esp-elf-gdb-12.1_20231023.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\12.1_20231023 -prefs=runtime.tools.mklittlefs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-12.2.0_20230208.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-12.2.0_20230208 -prefs=runtime.tools.dfu-util.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\pc\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.esp32-arduino-libs.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -prefs=runtime.tools.esp32-arduino-libs-idf-release_v5.1-442a798083.path=C:\Users\pc\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.1-442a798083 -verbose C:\Users\pc\Documents\Arduino archives\teawithGPT\sketch_jun29a\sketch_jun29a.ino
Using board 'esp32' from platform in folder: C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0-rc3
Using core 'esp32' from platform in folder: C:\Users\pc\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.0-rc3
cmd /c if exist "C:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a\\partitions.csv" COPY /y "C:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a\\partitions.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\partitions.csv"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\partitions.csv" if exist "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\variants\\esp32\\partitions.csv" COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\variants\\esp32\\partitions.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\partitions.csv"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\partitions.csv" COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\tools\\partitions\\default.csv" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a\\bootloader.bin" ( COPY /y "C:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a\\bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch_jun29a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\variants\\esp32\\bootloader.bin" ( COPY "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\variants\\esp32\\bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch_jun29a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.6\\esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch_jun29a.ino.bootloader.bin" "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.6
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
cmd /c if exist "C:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a\\build_opt.h" COPY /y "C:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a\\build_opt.h" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\build_opt.h"
cmd /c if not exist "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\build_opt.h" type nul > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\build_opt.h"
cmd /c type nul > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/file_opts"
Detecting libraries used...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-12.2.0_20230208/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/defines" "-IC:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\variants\\esp32" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch\\sketch_jun29a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-12.2.0_20230208/bin/xtensa-esp32-elf-g++" -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/cpp_flags" -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/defines" "-IC:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\variants\\esp32" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch\\sketch_jun29a.ino.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-12.2.0_20230208/bin/xtensa-esp32-elf-g++" -MMD -c "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/cpp_flags" -w -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:JTAGAdapter=default,PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,LoopCore=1,EventsCore=1,DebugLevel=none,EraseFlash=none,ZigbeeMode=default\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/defines" "-IC:\\Users\\pc\\Documents\\Arduino archives\\teawithGPT\\sketch_jun29a" -iprefix "C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/include/" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/includes" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/qio_qspi/include" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\cores\\esp32" "-IC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.0-rc3\\variants\\esp32" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/build_opt.h" "@C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/file_opts" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch\\sketch_jun29a.ino.cpp" -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch\\sketch_jun29a.ino.cpp.o"
Compiling libraries...
Compiling core...
cmd /c echo -DARDUINO_CORE_BUILD > "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/file_opts"
Using precompiled core: C:\Users\pc\AppData\Local\Temp\arduino_cache_469761\core\core_d9f4370ad8f4eb3ad6ab3c59921fd958.a
Linking everything together...
"C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\esp-12.2.0_20230208/bin/xtensa-esp32-elf-g++" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/ld_flags" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/ld_scripts" "-Wl,--Map=C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/sketch_jun29a.ino.map" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/lib" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/ld" "-LC:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/qio_qspi" -Wl,--wrap=esp_panic_handler -Wl,--start-group "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203\\sketch\\sketch_jun29a.ino.cpp.o" "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_cache_469761\\core\\core_d9f4370ad8f4eb3ad6ab3c59921fd958.a" "@C:\\Users\\pc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32-arduino-libs\\idf-release_v5.1-442a798083/esp32/flags/ld_libs" -Wl,--end-group -Wl,-EL -o "C:\\Users\\pc\\AppData\\Local\\Temp\\arduino_build_58203/sketch_jun29a.ino.elf"
exit status 1
Error compiling for board ESP32 Dev Module.
Honestly Sir/Ma'am, I'm really sorry that i'm stressing you out so much like this.... But I'll be more than happy if this goes well.
I've seen others who just intalled it once and first compilation went through, I just don't know why it's happening ...
Please, I also so much appreciate your help so far
