Hello. I am not sure what did I do wrong that result in this error.
> #include <DHT.h>
> #include "Adafruit_seesaw.h"
> Adafruit_seesaw ss;
> #include <SPI.h>
> #include <Wire.h>
> #include <RTClib.h>
> #include <SD.h>
> #define DHTTYPE DHT20
> #define ECHO_TO_SERIAL 1 //Sends datalogging to serial if 1, nothing if 0
> #define LOG_INTERVAL 360000 //milliseconds between entries (6 minutes = 360000)
> DHT dht(DHTTYPE);
> RTC_DS1307 rtc;
> const int sunlightPin = A2;
> const int chipSelect = 10;
> const int LEDPinGreen = 6;
> const int LEDPinRed = 7;
> const int solenoidPin = 3;
> const int wateringTime = 600000; //Set the watering time (10 min for a start)
> const float wateringThreshold = 25; //Value below which the garden gets watered
> float soilTemp = 0; //Scaled value of soil temp (degrees F)
> float soilMoisture = 0; //Scaled value of volumetric water content in soil (percent)
> float humidity = 0; //Relative humidity (%)
> float airTemp = 0; //Air temp (degrees F)
> float heatIndex = 0; //Heat index (degrees F)
> float sunlight = 0; //Sunlight illumination in lux
> bool watering = false;
> bool wateredToday = false;
> DateTime now;
> File logfile;
> Soil Moisture Reference
> Air = 0%
> Really dry soil = 10%
> Probably as low as you'd want = 20%
> Well watered = 50%
> Cup of water = 100%
> void error(char *str)
> Serial.print("error: ");
> Serial.println(str);
> // red LED indicates error
> digitalWrite(LEDPinRed, HIGH);
> while(1);
> void setup() {
> //Initialize serial connection
> Serial.begin(9600); //Just for testing
> Serial.println("Initializing SD card...");
> pinMode(chipSelect, OUTPUT); //Pin for writing to SD card
> pinMode(LEDPinGreen, OUTPUT); //LED green pint
> pinMode(LEDPinRed, OUTPUT); //LED red pin
> pinMode(solenoidPin, OUTPUT); //solenoid pin
> digitalWrite(solenoidPin, LOW); //Make sure the valve is off
> analogReference(EXTERNAL); //Sets the max voltage from analog inputs to whatever is connected to the Aref pin (should be 3.3v)
> //Establish connection with DHT sensor
> dht.begin();
> //Establish connection with real time clock
> Wire.begin();
> if (!rtc.begin()) {
> logfile.println("RTC failed");
> #if ECHO_TO_SERIAL
> Serial.println("RTC failed");
> #endif //ECHO_TO_SERIAL
> //Set the time and date on the real time clock if necessary
> if (! rtc.isrunning()) {
> // following line sets the RTC to the date & time this sketch was compiled
> rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
> //Check if SD card is present and can be initialized
> if (!SD.begin(chipSelect)) {
> error("Card failed, or not present");
> Serial.println("Card initialized.");
> // create a new file
> char filename[] = "LOGGER00.CSV";
> for (uint8_t i = 0; i < 100; i++) {
> filename[6] = i/10 + '0';
> filename[7] = i%10 + '0';
> if (! SD.exists(filename)) {
> // only open a new file if it doesn't exist
> logfile = SD.open(filename, FILE_WRITE);
> break; // leave the loop!
> if (! logfile) {
> error("couldnt create file");
> Serial.print("Logging to: ");
> Serial.println(filename);
> logfile.println("Unix Time (s),Date,Soil Temp (F),Air Temp (F),Soil Moisture Content (%),Relative Humidity (%),Heat Index (F),Sunlight Illumination (lux),Watering?"); //HEADER
> #if ECHO_TO_SERIAL
> Serial.println("Unix Time (s),Date,Soil Temp (F),Air Temp (F),Soil Moisture Content (%),Relative Humidity (%),Heat Index (F),Sunlight Illumination (lux),Watering?");
> #endif ECHO_TO_SERIAL// attempt to write out the header to the file
> now = rtc.now();
> void loop() {
> //delay software
> delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
> //Three blinks means start of new cycle
> digitalWrite(LEDPinGreen, HIGH);
> delay(150);
> digitalWrite(LEDPinGreen, LOW);
> delay(150);
> delay(150);
> delay(150);
> delay(150);
> //Reset wateredToday variable if it's a new day
> if (!(now.day()==rtc.now().day())) {
> now = rtc.now();
> // log time
> logfile.print(now.unixtime()); // seconds since 2000
> logfile.print(",");
> logfile.print(now.year(), DEC);
> logfile.print("/");
> logfile.print(now.month(), DEC);
> logfile.print("/");
> logfile.print(now.day(), DEC);
> logfile.print(" ");
> logfile.print(now.hour(), DEC);
> logfile.print(":");
> logfile.print(now.minute(), DEC);
> logfile.print(":");
> logfile.print(now.second(), DEC);
> logfile.print(",");
> #if ECHO_TO_SERIAL
> Serial.print(now.unixtime()); // seconds since 2000
> Serial.print(",");
> Serial.print(now.year(), DEC);
> Serial.print("/");
> Serial.print(now.month(), DEC);
> Serial.print("/");
> Serial.print(now.day(), DEC);
> Serial.print(" ");
> Serial.print(now.hour(), DEC);
> Serial.print(":");
> Serial.print(now.minute(), DEC);
> Serial.print(":");
> Serial.print(now.second(), DEC);
> Serial.print(",");
> //Collect Variables
> soilTemp = ss.getTemp();
> delay(20);
> soilMoisture = ss.touchRead(0)*(0.1538)-53.846;
> delay(20);
> humidity = dht.readHumidity();
> delay(20);
> airTemp = dht.readTemperature(true);
> delay(20);
> heatIndex = dht.computeHeatIndex(airTemp,humidity);
> //This is a rough conversion that I tried to calibrate using a flashlight of a "known" brightness
> sunlight = pow(((((150 * 3.3)/(analogRead(sunlightPin)*(3.3/1024))) - 150) / 70000),-1.25);
> delay(20);
> //Log variables
> logfile.print(soilTemp);
> logfile.print(",");
> logfile.print(airTemp);
> logfile.print(",");
> logfile.print(soilMoisture);
> logfile.print(",");
> logfile.print(humidity);
> logfile.print(",");
> logfile.print(heatIndex);
> logfile.print(",");
> logfile.print(sunlight);
> logfile.print(",");
> #if ECHO_TO_SERIAL
> Serial.print(soilTemp);
> Serial.print(",");
> Serial.print(airTemp);
> Serial.print(",");
> Serial.print(soilMoisture);
> Serial.print(",");
> Serial.print(humidity);
> Serial.print(",");
> Serial.print(heatIndex);
> Serial.print(",");
> Serial.print(sunlight);
> Serial.print(",");
> #endif
> if ((soilMoisture < wateringThreshold) && (now.hour() > 19) && (now.hour() < 22) && (wateredToday = false)) {
> //water the garden
> digitalWrite(solenoidPin, HIGH);
> delay(wateringTime);
> //record that we're watering
> logfile.print("TRUE");
> #if ECHO_TO_SERIAL
> Serial.print("TRUE");
> #endif
> wateredToday = true;
> else {
> logfile.print("FALSE");
> #if ECHO_TO_SERIAL
> Serial.print("FALSE");
> #endif
> logfile.println();
> #if ECHO_TO_SERIAL
> Serial.println();
> #endif
> delay(50);
> //Write to SD card
> logfile.flush();
> delay(5000);
> Using library Grove_Temperature_And_Humidity_Sensor at version 1.0.1 in folder: C:\Arduino\libraries\Grove_Temperature_And_Humidity_Sensor
> Using library Wire at version 1.0 in folder: C:\Users\keyge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\Wire
> Using library Adafruit_seesaw_Library at version 1.6.2 in folder: C:\Arduino\libraries\Adafruit_seesaw_Library
> Using library Adafruit_BusIO at version 1.12.0 in folder: C:\Arduino\libraries\Adafruit_BusIO
> Using library SPI at version 1.0 in folder: C:\Users\keyge\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\libraries\SPI
> Using library RTClib at version 2.0.3 in folder: C:\Arduino\libraries\RTClib
> Using library SD at version 1.2.4 in folder: C:\Arduino\libraries\SD
> exit status 1
> Compilation error: 'DHT20' was not declared in this scope
