Compilation error: Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: read ECONNRESET
Hi!
I'm getting Compilation error: Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: read ECONNRESET with the beta. I tried beta 10 and now 11, same thing.
It's the same issue discussed in this closed topic:
My setup: I don't have any board connected. I sometimes code for my friend that has a board, but I selected the Uno board when I had to select something. Can lacking a board cause issues with IDE 2.0 ?
Nothing should be blocking local ports on my Windows 10 machine either.
Any ideas?
Best regards,
Ted Lyngmo
It should not. You can compile for any board you like because this process only occurs on the computer. It's only the upload process that requires the board to be connected.
Please do this:
  1. Start File Explorer (AKA "Windows Explorer").
  2. Open the Arduino IDE's installation folder (usually C:\Program Files\Arduino IDE or C:\Users\<user name>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here". PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type & ".\Arduino IDE".
  6. Press Enter. Debug output should now be printed to the PowerShell window as the Arduino IDE starts (or fails to start).
  7. Wait for the Arduino IDE to finish starting.
  8. Compile a sketch.
  9. Wait for the error to occur.
  10. Switch back to the PowerShell window.
  11. Right click on the title bar of the PowerShell window.
  12. Click Edit > Select All. This will select all the text in the PowerShell window.
  13. Press Ctrl+C. This will copy the contents of the PowerShell window to the clipboard.
  14. In this Arduino forum thread, click on the reply field.
  15. Click the </> button on the forum toolbar. This will add the forum's code tags markup (```) to your reply, making it easier for us to read.
  16. Press Ctrl+V. This will paste the output between the code tags.
  17. Move the cursor outside of the code tags before you add any additional text to your reply.
  18. Click the "Reply" button.
Hopefully that will contain some additional output that will give us some information we can use to help you with the problem.
Hi and thanks for helping me to debug this.
Here's the PS output. Note that it succeeds compiling the first time I press Verify/Compile and it fails the second time (and every time after that).
PS C:\Users\Ted\AppData\Local\Programs\Arduino IDE> & "./Arduino IDE"
Starting backend process. PID: 22524
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root WARN please install @theia/electron@1.12.0-next.1a1d7afc as a runtime dependency
root INFO Configuration directory URI: 'file:///c%3A/Users/Ted/.theia'
root INFO Theia app listening on http://localhost:52174.
root WARN The local plugin referenced by local-dir:/c%3A/Users/Ted/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/Ted/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\Ted\.arduinoProIDE\plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.1-beta.1" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Deploying backend plugin "cortex-debug@0.3.10" from "C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension"
root INFO Deploying backend plugin "vscode-arduino-tools@0.0.1-beta.1" from "C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle"
root INFO Deploying backend plugin "cpp@1.52.1" from "C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension"
root INFO Deploying backend plugin "json@1.46.1" from "C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension"
root INFO Deploying backend plugin "json-language-features@1.46.1" from "C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain"
root INFO Deploy plugins list took: 54.5 ms
root WARN Backend ConfigServiceImpl.onStart is slow, took: 138.2 ms
daemon INFO Starting daemon from C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
daemon INFO Using config file: c:\Users\Ted\.arduinoIDE\arduino-cli.yaml
daemon INFO arduino-cli.exe version 0.18.3
daemon INFO Setting up Prometheus metrics on :9090/metrics
daemon INFO Starting daemon on TCP address 127.0.0.1:50051
daemon INFO Daemon is now listening on 127.0.0.1:50051...
daemon INFO Daemon is running.
daemon INFO Checking signature [index: C:\Users\Ted\AppData\Local\Arduino15\package_index.json, signaturefile: C:\Users\Ted\AppData\Local\Arduino15\package_index.json.sig, trusted: true]
daemon INFO Checking if CLI is Bundled into the IDE
daemon INFO Loading hardware from: C:\Users\Ted\AppData\Local\Arduino15\packages
daemon INFO Loading package arduino from: C:\Users\Ted\AppData\Local\Arduino15\packages\arduino\hardware
daemon INFO Checking signature [error: opening signature file: open C:\Users\Ted\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\installed.json.sig: The system cannot find the file specified., index: C:\Users\Ted\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\installed.json, signaturefile: C:\Users\Ted\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\installed.json.sig]
daemon INFO Loaded platform [platform: {ID:"arduino:avr",Installed:"1.8.3",Latest:"1.8.3",Name:"Arduino AVR Boards"}]
daemon INFO Checking existence of 'tools' path: C:\Users\Ted\AppData\Local\Arduino15\packages\arduino\tools
daemon INFO Loading tools from dir: C:\Users\Ted\AppData\Local\Arduino15\packages\arduino\tools
daemon INFO Loaded tool [tool: Version: 1.3.0 Systems: [OS: i686-linux-gnu, OS: x86_64-linux-gnu, OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: i386-apple-darwin11, OS: i686-mingw32]]
daemon INFO Loaded tool [tool: Version: 7.3.0-atmel3.6.1-arduino7 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin14, OS: i686-mingw32, OS: i686-linux-gnu, OS: x86_64-linux-gnu]]
daemon INFO Loaded tool [tool: Version: 6.3.0-arduino17 Systems: [OS: arm-linux-gnueabihf, OS: aarch64-linux-gnu, OS: x86_64-apple-darwin12, OS: x86_64-linux-gnu, OS: i686-linux-gnu, OS: i686-mingw32]]
daemon INFO Loading package builtin from: C:\Users\Ted\AppData\Local\Arduino15\packages\builtin
daemon INFO Checking existence of 'tools' path: C:\Users\Ted\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loading tools from dir: C:\Users\Ted\AppData\Local\Arduino15\packages\builtin\tools
daemon INFO Loaded tool [tool: Version: 5.8-arduino11]
daemon INFO Loaded tool [tool: Version: 1.2.1]
daemon INFO Adding libraries dir [dir: C:\Users\Ted\Documents\Arduino\libraries, location: user]
daemon INFO Adding libraries dir [dir: C:\Users\Ted\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries, location: platform]
root INFO Git askpass helper is listening on http://127.0.0.1:52181.
root WARN Frontend CommonFrontendContribution.configure is slow, took: 414.7 ms
root WARN Failed to resolve module: @types/body-parser
root WARN Failed to resolve module: @types/cookie
root WARN Failed to resolve module: @types/express
root WARN Failed to resolve module: @types/fs-extra
root WARN Failed to resolve module: @types/lodash.debounce
root WARN Failed to resolve module: @types/lodash.throttle
root WARN Failed to resolve module: @types/react
root WARN Failed to resolve module: @types/react-dom
root WARN Failed to resolve module: @types/react-virtualized
root WARN Failed to resolve module: @types/route-parser
root WARN Failed to resolve module: @types/safer-buffer
root WARN Failed to resolve module: @types/ws
root WARN Failed to resolve module: @types/yargs
root WARN Failed to resolve module: @theia/monaco
root WARN Failed to resolve module: @theia/editor
root WARN Failed to resolve module: @types/rimraf
root WARN Failed to resolve module: @types/tar-fs
root WARN Failed to resolve module: @types/uuid
root WARN Failed to resolve module: @theia/navigator
root WARN Failed to resolve module: @types/p-queue
root WARN Failed to resolve module: @theia/preferences
root WARN Failed to resolve module: @theia/electron
root WARN Failed to resolve module: @theia/keymaps
root WARN Failed to resolve module: @theia/messages
root WARN Failed to resolve module: @types/diff
root WARN Failed to resolve module: @types/dompurify
root WARN Failed to resolve module: @types/mime
root WARN Failed to resolve module: @types/request
root WARN Failed to resolve module: @types/atob
root WARN Failed to resolve module: @types/auth0-js
root WARN Failed to resolve module: @types/btoa
root WARN Failed to resolve module: @types/dateformat
root WARN Failed to resolve module: @types/deepmerge
root WARN Failed to resolve module: @types/glob
root WARN Failed to resolve module: @types/google-protobuf
root WARN Failed to resolve module: @types/js-yaml
root WARN Failed to resolve module: @types/keytar
root WARN Failed to resolve module: @types/ncp
root WARN Failed to resolve module: @types/node-fetch
root WARN Failed to resolve module: @types/ps-tree
root WARN Failed to resolve module: @types/react-select
root WARN Failed to resolve module: @types/react-tabs
root WARN Failed to resolve module: @types/sinon
root WARN Failed to resolve module: @types/temp
root WARN Failed to resolve module: @types/which
root WARN Failed to resolve module: temp
root ERROR Error: Git installation not found.
    at C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\find-git-exec\lib\find-git-exec.js:69:69
daemon INFO URL: https://downloads.arduino.cc/packages/package_index.json
daemon INFO Updating index [url: https://downloads.arduino.cc/packages/package_index.json]
root INFO Updating index: package_index.json completed.
root INFO Updating index: package_index.json.sig completed.
daemon INFO Checking signature [error: opening signature file: open C:\Users\Ted\AppData\Local\Temp\000230943.sig: The system cannot find the file specified., index: C:\Users\Ted\AppData\Local\Temp\000230943, signaturefile: C:\Users\Ted\AppData\Local\Temp\000230943.sig]
daemon INFO Updating libraries index
root INFO Updating index: library_index.json completed.
root ERROR Request repositories failed with error: Git could not be found at the expected path: 'C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\dugite-no-gpl\git\cmd\git.exe'. This might be a problem with how the application is packaged, so confirm this folder hasn't been removed when packaging.
root WARN Frontend EditorNavigationContribution.onStart is slow, took: 1814.4 ms
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO <<< Nothing to restore.
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880) starting instance
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133] Sync of 5 plugins took: 328.6 ms
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][marus25.cortex-debug]: Loaded contributions.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][vscode.cpp]: Loaded contributions.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][vscode.json]: Loaded contributions.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][vscode.json-language-features]: Loaded contributions.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133] Load contributions of 5 plugins took: 28.8 ms
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): initializing(cortex-debug@0.3.10 with C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 24880] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): initializing(vscode-arduino-tools@0.0.1-beta.1 with C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): initializing(cpp@1.52.1 with C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): initializing(json@1.46.1 with C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): initializing(json-language-features@1.46.1 with C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node/plugin-vscode-init.js)
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): PluginManagerExtImpl/loadPlugin(C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][marus25.cortex-debug]: Started plugin.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][arduino.vscode-arduino-tools]: Started plugin.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][vscode.cpp]: Started plugin.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][vscode.json]: Started plugin.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133][vscode.json-language-features]: Started plugin.
root INFO [fcdc84f1-094c-41cf-bf0d-a7bfb936f133] Start of 5 plugins took: 1183.0 ms
daemon INFO inventory.Store.ConfigFileUsed() C:\Users\Ted\AppData\Local\Arduino15\inventory.yaml
root ERROR Request compile failed with error: 2 UNKNOWN: no FQBN provided
root INFO Board config changed:
root INFO Starting language server: arduino:avr:uno
root INFO [hosted-plugin: 24880] PLUGIN_HOST(24880): PluginManagerExtImpl/loadPlugin(C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
daemon INFO Searching tools required for board arduino:avr:uno
daemon INFO Required tool [tool: {ToolName:"arduinoOTA",ToolVersion:"1.3.0",ToolPackager:"arduino"}]
daemon INFO Required tool [tool: {ToolName:"avr-gcc",ToolVersion:"7.3.0-atmel3.6.1-arduino7",ToolPackager:"arduino"}]
daemon INFO Required tool [tool: {ToolName:"avrdude",ToolVersion:"6.3.0-arduino17",ToolPackager:"arduino"}]
daemon INFO Adding libraries dir [dir: C:\Program Files (x86)\Arduino\libraries, location: ide]
root ERROR Uncaught Exception:
root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: read ECONNRESET
    at Object.callErrorFromStatus (C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26)
    at Object.onReceiveStatus (C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:387:49)
    at Object.onReceiveStatus (C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:299:181)
    at C:\Users\Ted\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:145:78
    at processTicksAndRejections (internal/process/task_queues.js:76:11)
root ERROR Request compile failed with error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: read ECONNRESET
daemon INFO Daemon exited with exit code: 3221226505.
