Compilation error: expected primary-expression before ')' token
I'm having the mentioned in the title compilation error and this is not the first time I encounter it and I don't know how to fix it, what should I do?
#include <Servo.h>
class buttonType {
  private:
    byte Pin;
    byte State = HIGH;
    byte lastState = HIGH;
    unsigned long lastChange = 0;
    unsigned long lastLow = 0;
    unsigned long pressTime = 0;
  public:
    void init(byte pinNo){Pin = pinNo; pinMode(Pin, INPUT_PULLUP);}
    boolean released();
    unsigned long getPressTime() {return pressTime;}
boolean buttonType::released(){
  byte actState = digitalRead(Pin);
  if (actState != lastState){
    lastChange = millis();
    lastState = actState;
  if (State != lastState && millis()-lastChange > 30){
    State = lastState;
    if (State == HIGH) {
       pressTime = millis()-lastLow;
       return true;
       lastLow = millis();
  return false;
enum Mode {SetTime, Flying, Determalisated};
int TargetHeading;
int CurrentHeading = 90;
int Deviation;
int Variation;
int setFlightTime;
int Counter = 0;
constexpr int maxCounter = 6;
constexpr byte buttonPin = 10;
buttonType button;
bool shortPress = false;
bool longPress = false;
Servo EP;
unsigned long FlyTime;
void Button(){
   if (button.released()){
     if (button.getPressTime() < 200){
       shortPress = true;
       longPress = true;
void Timer() {
    Counter++;
    if (Counter > maxCounter) {
      Counter = 1;
void AcquireTargetHeading() {
  TargetHeading = analogRead(A0);
  TargetHeading = map(TargetHeading, 0, 1023, 0, 360);
  Serial.println(TargetHeading);
void GuidanceSystem() {
  Deviation = TargetHeading - CurrentHeading;
  Variation = 90 + Deviation;
  constrain(Variation, 80, 110);
  EP.write(Variation);
  if (millis() - FlyTime > setFlightTime * 60000UL) {
    EP.write(90);
    Mode(Determalisated);
  else if (longPress) {
    EP.write(90);
void Modes() {
  switch(Mode) {
    case SetTime:
      if (shortPress) {
      Timer();
      if (longPress) {
        setFlightTime = Counter;
        FlyTime = millis();
        Mode(Flying);
    case Flying:
      AcquireTargetHeading();
      GuidanceSystem();
    case Determalisated:
      if (longPress) {
        Mode(SetTime);
  pinMode(A0, OUTPUT);
  EP.attach(9);
  Button();
  Modes();
Error message:
C:\Users\Cristy\Desktop\Ceas_electronic_F1E_1_buton_2\Ceas_electronic_F1E_1_buton_2.ino: In function 'void Modes()':
C:\Users\Cristy\Desktop\Ceas_electronic_F1E_1_buton_2\Ceas_electronic_F1E_1_buton_2.ino:102:14: error: expected primary-expression before ')' token
switch(Mode) {
Multiple libraries were found for "Servo.h"
Used: C:\Users\Cristy\Documents\Arduino\libraries\Servo
Not used: C:\Users\Cristy\AppData\Local\Arduino15\libraries\Servo
exit status 1
Your code calls a function named Mode() that does not exist in the sketch
but you do have an enum of that name, hence the error
How do I correct that?Isn't 'Mode(Determalisated)' supposed to switch to case 'Determalisated'?
Your switch/case uses the Mode variable to determine which case, if any, to execute. However, you don't have a variable named Mode, you have an enum of that name
Add a new variable named currentMode of data type byte, use that as the switch variable and when you want to change modes do
currentMode = SetTime;
or whatever mode you want to change to
Sorry for the reply, it's a long time since I checked, but I still don't understand I tried to use currentMode as a byte but it doesn't work, can you show me how the code should look?
I have taken your code and added a new global variable named currentState. You should be able to guess what its purpose is from its name. I have also made some other changes.
The sketch compiles but I have no idea whether it does what you want or even what it is supposed to do. Where did you get the skerch from as I am certain that you did not write it
#include <Servo.h>
class buttonType
  private:
    byte Pin;
    byte State = HIGH;
  public:
        Pin = pinNo;
    boolean released();
        return pressTime;
    if (State != lastState && millis() - lastChange > 30)
        State = lastState;
        if (State == HIGH)
            pressTime = millis() - lastLow;
            return true;
            lastLow = millis();
    return false;
enum Mode
    SetTime,
    Flying,
    Determalisated
Mode currentMode = SetTime;
int TargetHeading;
int Deviation;
int Variation;
int setFlightTime;
int Counter = 0;
buttonType button;
Servo EP;
void Button()
            shortPress = true;
            longPress = true;
void Timer()
    Counter++;
        Counter = 1;
        EP.write(90);
        currentMode = Determalisated;
    else if (longPress)
        EP.write(90);
void Modes()
    switch (currentMode)
        case SetTime:
            if (shortPress)
                Timer();
            if (longPress)
                FlyTime = millis();
                currentMode = Flying;
        case Flying:
            GuidanceSystem();
            if (longPress)
    EP.attach(9);
    Button();
    Modes();
The thing with the button I took from another project that I found, that's the only thing I took from somewhere else...
What is the sketch meant to do ?
Around the same thing but it includes another servo that after the set time it just swings 90 degrees. I tried the sketch in Wokwi but the Counter stays to 0, no short press is detected either a long one .Should I give you the link to the other sketch?
Is the other sketch that you are referring to in another topic ?
It should, but here's the link EPilot - Wokwi ESP32, STM32, Arduino Simulator, and if you want the topic it's here Servo not respecting code
