Compilation error: 'lt' was not declared in this scope..... line 78
#include <Servo.h>
const int servoPin = 9; // the pin number for the servo signal
const int trigPin = 11; //ultrasonic
const int echoPin = 12; //ultrasonic
const int servoMinDegrees = 0; // the limits to servo movement
const int servoMaxDegrees = 180;
Servo myservo; // create servo object to control a servo
int servoPosition = 0; // the current angle of the servo - starting at 90.
int servoSlowInterval = 20; // millisecs between servo moves
int servoFastInterval = 20;
int servoInterval = servoSlowInterval; // initial millisecs between servo moves
int servoDegrees = 2; // amount servo moves at each step
// will be changed to negative value for movement in the other direction
unsigned long currentMillis = 0; // stores the value of millis() in each iteration of loop()
unsigned long previousServoMillis = 0; // the time when the servo was last moved
myservo.write(servoPosition); // sets the initial position
myservo.attach(servoPin);
 // Notice that none of the action happens in loop() apart from reading millis()
 //   it just calls the functions that have the action code
currentMillis = millis(); // capture the latest value of millis()
// this is equivalent to noting the time from a clock
// use the same time for all LED flashes to keep them synchronized
                          // establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The sensor is triggered by a HIGH pulse of 10 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the signal from the sensor: a HIGH pulse whose
// duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
//Tell the Arduino to print the measurement in the serial console
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
if (cm > 50) {servoSweep();
else if (cm <= 50) {myservo.write(servoPosition);
// Converts the microseconds reading to Inches
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
//Converts the Microseconds Reading to Centimeters
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
void servoSweep() {
 // this is similar to the servo sweep example except that it uses millis() rather than delay()
 // nothing happens unless the interval has expired
 // the value of currentMillis was set in loop()
if (currentMillis - previousServoMillis >= servoInterval) {
// its time for another move
previousServoMillis += servoInterval;
servoPosition = servoPosition + servoDegrees; // servoDegrees might be negative
if (servoPosition <= servoMinDegrees) {
// when the servo gets to its minimum position change the interval to change the speed
if (servoInterval == servoSlowInterval) {
servoInterval = servoFastInterval;
else {
if ((servoPosition >= servoMaxDegrees) || (servoPosition <= servoMinDegrees)) {
// if the servo is at either extreme change the sign of the degrees to make it move the other way
servoDegrees = - servoDegrees; // reverse direction
// and update the position to ensure it is within range
// make the servo move to the next position
// and record the time when the move happened
What Arduino board are you using?
You will make it easier to help you if you, please. post the code properly. Please read the forum guidelines to see how to properly post code and some information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in a code block.
Please go back and fix your original post.
Please include the entire error message. Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information. If not using the IDE, copy and paste the entire error message.
I agree with @groundFungus that you should make our life a little easier.
I've copied your code (but might have made mistakes when doing so) and it happily compiles without problems.
I was a pain to copy your code, but I did and find that it compiles fine for Uno with no errors, but one warning.
warning: comparison between signed and unsigned integer expressions
The warning is because you are comparing unsigned long data type (previousServoMillis ) to a signed int data type (servoInterval).
You should always use unsigned long for all variables that do millis() or micros() timing.
You should turn on the compiler warnings and when there are warnings, fix them. Warnings will allow compilation to complete, but the program may not work right. Enable compiler warnings in the Files, Preferences menu.
```cpp
#include <Servo.h>
  Serial.print(cm);
  Serial.print("cm");
  if (cm > 50) {
    servoSweep();
  } else if (cm &lt; = 50) {
long microsecondsToInches(long microseconds) {
long microsecondsToCentimeters(long microseconds) {
void servoSweep() {
    if (servoPosition &lt; = servoMinDegrees) {
    if ((servoPosition >= servoMaxDegrees) || (servoPosition &lt; = servoMinDegrees)) {
      servoDegrees = -servoDegrees;  // reverse direction
Thanks for Advise
Using the code that you provided with code tags
You have copied your code from a website.
&lt; is supposed to be <
&gt; is supposed to be '>'
Change the code accordingly (everywhere where you have &lt;
