Compilation Error: multiple definition of `__vector_1'
I'm writing a code where I use a PIR motion sensor to put the AVR to sleep. I'm building a math game, so the idea is, if the user steps away from the game, I put AVR to sleep until the user comes back (motion is sensed). The error that I'm getting is this:
WInterrupts.c.o (symbol from plugin): In function attachInterrupt': (.text+0x0): multiple definition of __vector_1'
sketch/simple_calculator.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
This is my code. I took out all the non relevant thing to the error to keep it simple. I guess it is worth to mention that i have an ISR in my code as well but it uses INT1. I don't think this has to do with the problem so I won't include the ISR in the following code.
#include <avr/sleep.h>
//Motion Detector Sensor
int motionDetectorPin = 3;
void go_to_sleep() {
  sleep_enable(); //Enable sleep mode
  attachInterrupt(digitalPinToInterrupt(motionDetectorPin), wakeup, HIGH); //System wakes up when motion is detected
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Setting sleep mode - full sleep - saves more power
  sleep_cpu(); // activate sleep mode - won't read coming lines until it wakes up
void wakeup() {
  sleep_disable();
  detachInterrupt(digitalPinToInterrupt(motionDetectorPin));
void setup(){
  //Motion Detection sensor configuration
  pinMode(motionDetectorPin, INPUT);
void loop(){
int detectorValue = digitalRead(motionDetectorPin);
  unsigned long lastMotion;
  if (detectorValue == LOW ) {
    Serial.println("Motion detected");
    lastMotion = micros();
  if (micros() - lastMotion > 20000) { //AVR and LCD sleep if player steps away for 20 seconds
    go_to_sleep();
Edit: I'm actually using INT1 somewhere else in my code but this post is about INT0
Have you checked what AVR vector_1 is?
No, I couldn't find what it means.
That's OK, I didn't mention that I left out parts of my answer that I didn't think were relevant.
The code you posted compiles without error, so you will have to post the actual code which gives the error if you want assistance.
computerpolice:
Download the datasheet of the processor that's on your board. Vectors in your error message refer to interrupts, __vector_1 refers to the INT0 interrupt.
TheMemberFormerlyKnownAsAWOL:
Turns out I had a typo in my post. I'm using INT1 somewhere else in my code and not INT0. So I'm not using the interrupt twice. Also, your attitude isn't necessary.
cattledog:
The code that I'm working on uses 4 different components and requires time to connect them all. Last time I tried to post it here I got told off that I shouldn't be posting code that long.
OK
So create a minimal example that results in the linker (compiler) error.
I did a little digging; by the looks of it, using attachInterrupt / detachInterrupt will result in all ISRs for external interrupts being defined. And hence the conflict with your ISR.
So I think that you either use attachInterrupt for all external interrupts or code your ISRs for external interrupts yourself; the latter will included enabling/disabling interrupts.
This could be it! I did program INT1 by sitting the registers and writing an ISR function. For INT0, I just called attachInterrupt. I will try and set INT0 using registers. I will post on how does that go later.
computerpolice:
Was that in your original post?
I can't see it.
computerpolice:
All interrupts are now done through the SW (attachInterrupt) and the error is gone.
You have:
    go_to_sleep();
I believe from your comments you should be using milis() not micros() or your comment should be refering to milliseconds not seconds :slight_smile: Being away for only 20 milliseconds might be tad on the short side.
