Completely lost and confused on should be simple project
I have rebuilt this circuit and rewrote the program multiple times and I cannot figure out what is wrong. I am fairly new to arduino and i am attempting to program this joystick to control four LEDs. For some reason all lights are just on unless I connect GND then they all just turn off. I will attach photos of my circuit. Here is the code: please help however you can thank you!
`// joystick pins
const int LRpin = A0;
const int UDpin = A1;
// variables for analog readings
int LR;
int UD;
// neutral readings for calibration
int LR_neutral;
int UD_neutral;
// red, yellow, green, blue LED pins
const int Rpin = 11;
const int Ypin = 10;
const int Gpin = 6;
const int Bpin = 9;
// LED brightnesses
int R;
int Y;
int G;
int B;
const int deadzone=10;
  // Initialize serial communication
  // get neutral readings for calibration
  // make sure you are not touching the joystick when
  // the program starts!
  LR_neutral = analogRead(LRpin);
  UD_neutral = analogRead(UDpin);
  // read analog pins
  LR = analogRead(LRpin);
  UD = analogRead(UDpin);
  if(UD>=UD_neutral+deadzone){ // joystick is up
    B = 0;  // blue LED off
    R = map(UD,UD_neutral,1023,0,255);
  else if(UD<=UD_neutral-deadzone){
    R = 0; // red LED off
    B = map(UD,UD_neutral,0,0,255);
  else{
    R = 0;
    B = 0;
  if(LR>=LR_neutral+deadzone){ // joystick is up
    Y = 0;  // blue LED off
    G = map(LR,LR_neutral,1023,0,255);
  else if(LR<=LR_neutral-deadzone){
    G = 0; // red LED off
    Y = map(LR,LR_neutral,0,0,255);
  else{
    G = 0;
    Y = 0;
  analogWrite(Rpin,R);
  analogWrite(Ypin,Y);
  analogWrite(Bpin,B);
  analogWrite(Gpin,G);
Welcome to the forum
It is impossible to see how things are connected and powered from your 'photos
Please draw the schematic, take a clear 'photo of that and post it
Add:
Serial.println(LR);
After reading the pin...
won't the above result in values for R that are always > 255/2 and for B < 255/2.
you may find very little difference in light intensity except near the extremes.
why not just drive the LEDs On or Off using the joystick. You might also turn each LED On for half a second then Off in setup to verify that they are all wired correctly
I don't think this is the only wiring change you are making between the photos.
In this photo we see that one of the blue LED's pins isn't connected to anything.
But in this photo the blue led is lit, so both it's pins must be connected.
I also noticed that a red wire and a black wire are connected together here. Is that a mistake?
Hi everybody thank you for all of the help so far. I attempted to make a schematic of my circuit to make it easier to see, this is my first time making a schematic so i apologize if its not perfect. Thanks again!
the blue wire did come unhooked in that photo. my mistake. the red and black wires in the other photo are actually wired to different places (GND and PWR) see schematic I just uploaded for details thank you!
see edit^
where?
After:
Serialprint is an excellent tool for debugging.
With this print you can test the reading of your joystick. So you can isolate the problem: is it the joystick, or the led connections...
In your schematic the leds are reversed...
Try to mae as little wire crossings as possible...
Move the board up... above the leds...
Usually inputs (your pots) are on the left. Outputs (your leds) are on the right... mcu in the middle...
Good use of colors in your fritzy!
ALSO cannot figure out why my GND connection causes it to short circuit; pls help!
What is 'it'?
is this correct?
No, nothing changed, your leds are reversed.
The arrow in the diode should point to gnd...
How is your joystick wired?
Can you make a picture of the print?
My guess is that both pots share + and -. So you need only 4 wires to connect them.
You might have connected one plus to plus and one plus to minus (=short circuit).
like this?
im sorry i dont understand what you are asking about the joystick
Yes, but rather without the crossing lines.
This is very difficult to follow (even though the circuit is quite easy)...
You have 4 leds. 3 to the left 1 to the right... that is just not communicating they are all connected in the same way...
The joystick is soldered on a blue print (post #1). The print has copper tracks (at the bottom side). Follow the tracks. Make a picture, so we can follow the tracks...
