Hi, guys!
I'm in the process of building a microcontroller circuit with the Atmega 328, which is supposed to control a few 24V valves.
My plan is having the power supply inside the same box as the controller circuit will be in, and a power cable hanging out that can be connected directly into a 230V socket.
I'm unsure of which isolation transformer to choose, as there is a lot to choose from. The circuit will probably not draw more than 1.5A at max. I'm thinking a 230V AC to 24V AC transformer, a fuse according to datasheet of transformer, then a rectifier bridge, an electrolytic capacitor of 2200uF, and finally a 7805 regulator for supply to the microcontroller, and a 7824 regulator for the 24V circuit.
Then the plan is using a couple of logic level MOSFETs, to control the 24V circuit with the 5V digital outputs from the microcontroller.
I'm asking for guidance in choosing the components for the power supply for this project, especially the transformer, as I have no experience with these components. Not some cheap ebay stuff. It should be built to last as long as possible. ![]()
I found two transformers: Link 1, Link 2. Is this something I could use, or would you recommend something else?
Thanks! Any help I can get is appreciated.
