Computer cannot find the Arduino Nano 33 IoT
Hello,
First post
I got a new Arduino Nano 33 IoT 33 (Nano 33) and connect it tomy computer with USB cable. However, both of Arduino IDE and Arduino create cannot find the board and the LED is On on the board.
My computer does not have the COM port. Does it make the issue? Or there may be something wrong with the cable?
Regards,
Leo
Have you gone to BOARD MANAGER and installed the core for the nano33 ?
That would be the first thing to do.
It will also install the correct driver which will then give you the COM port.
Please READ THIS POST to help you get the best out of the forum.
Bob.
Hi bob, thanks for your reply
I have installed the core for nano 33 but the Port button is still grey in the IDE. I also installed the Plugin and followed the steps of Arduino create. Arduino create on the web also could not find the connected board.
Hi lzh29823 ,
I have no Nano IoT but some part which helps by the nano BLE is a double click on the reset Button, which will force the chip to wait until you flash it.
But I'm not sure if this helps in this case, but it is missing in the list of bob.
Best regards,
Knowless
Did you install the board cores in the IDE ?
Install cores
I had the same problem with my Arduino nano 33 Iot board.
This solved it for me.
Open the Boards Manager
Scroll down to find this board:
"Arduino SAMD Boards (32-bits ARM Cortec -MO+)" Board.
Click the remove button.
Wait for it to be removed.
Then search again for "nano 33 Iot" in the search box.
Install the board's driver again.
This installs the USB drivers for windows.
Now the "port" link is no longer greyed out in the menu but listed the following
COM19 (Arduino NANO 33 IoT)
Hope this helps someone with the same problem.
