#include "Nextion.h"
// #include <Robojax_AllegroACS_Current_Sensor.h>
#include <SPI.h>
// #include <loraid.h>
#define MODE_LONG_RANGE_MODE 0x80
long interval = 5000; // 10 s interval to send message
long previousMillis = 0; // will store last time message sent
unsigned int counter = 0; // message counter
uint32_t next, myInt = 0;
int currentpage;
///////12 VOLT 1
const int voltageSensorPin = A2; // sensor pin
float vIn; // measured voltage (3.3V = max. 16.5V, 5V = max 25V)
float vOut;
float voltageSensorVal; // value on pin A3 (0 - 1023)
const float factor = 3.35; // reduction factor of the Voltage Sensor shield
const float vCC = 5.0; // Arduino input voltage (measurable by voltmeter)
int bat_percentage;
int prevbat_percent = 0;
int millisBegin = 0;
int millisNow;
int millisBorder = 1000;
///////60 VOLT
float correctionfactor = .5;
int analogInput = A0;
float vout60 = 0.0;
float vin60 = 0.0;
float R1 = 30000 + 68000;
float R2 = 7500;
int value = 0;
int bat_percent3;
///////12 VOLT 2
// const int voltageSensorPin2 = A1; // sensor pin
float vIn2; // measured voltage (3.3V = max. 16.5V, 5V = max 25V)
float vOut2;
float voltageSensorVal2; // value on pin A3 (0 - 1023)
const float factor2 = 4.92; // reduction factor of the Voltage Sensor shield
const float vCC2 = 5.00; // Arduino input voltage (measurable by voltmeter)
int bat_percentage2;
////ACS758
const int VIN = A3; // define the Arduino pin A0 as voltage input (V in)
const float VCC = 5.04;// supply voltage
const int MODEL = 5; // enter the model
// Robojax_AllegroACS_Current_Sensor robojax(MODEL,VIN);
float curr1;
NexPage p0 = NexPage(0,0,"page0");
NexPage p1 = NexPage(1,0,"page1");
NexPage p2 = NexPage(2,0,"page2");
NexPage p3 = NexPage(3,0,"page3");
NexPage p4 = NexPage(4,0,"page4");
NexPicture p0_p1 = NexPicture(0,1,"p0");
NexPicture p0_p2 = NexPicture(0,2,"p0");
NexPicture p0_p3 = NexPicture(0,3,"p0");
NexButton p0_b0 = NexButton(0,6,"b0");
NexButton p1_b0 = NexButton(1,6,"b0");
NexButton p2_b0 = NexButton(2,6,"b0");
NexButton p3_b1 = NexButton(3,2,"b1");
NexButton p3_b2 = NexButton(3,3,"b2");
NexButton p4_b1 = NexButton(4,2,"b1");
NexButton p4_b3 = NexButton(4,3,"b3");
NexTouch *nex_listen_list[] = {
&p0,
&p1,
&p2,
&p3,
&p4,
&p0_p1,
&p0_p2,
&p0_p3,
&p0_b0,
&p1_b0,
&p2_b0,
&p3_b1,
&p3_b2,
&p4_b1,
&p4_b3,
NULL
void p0PopCallback(void *ptr)
p0.show();
void p1PopCallback(void *ptr)
p1.show();
void p2PopCallback(void *ptr)
p2.show();
void p3PopCallback(void *ptr)
p3.show();
void p4PopCallback(void *ptr)
p4.show();
void p0_p1PopCallback(void *ptr)
uint32_t number = 0;
p0_p1.getPic(&number);
if (number == 1)
number = 2;
number = 1;
p0_p1.setPic(number);
void p0_p2PopCallback(void *ptr)
p0_p2.getPic(&number);
if (number == 1)
number = 2;
number = 1;
p0_p2.setPic(number);
void p0_p3PopCallback(void *ptr)
if (number == 1)
number = 2;
number = 1;
p0_p3.setPic(number);
void p0_b0_Release(void *ptr) {
p3.show();
currentpage=3;
void p1_b0_Release(void *ptr) {
p3.show();
currentpage=3;
void p2_b0_Release(void *ptr) {
p3.show();
currentpage=3;
void p3_b1_Release(void *ptr) {
p0.show();
currentpage=0;
void p3_b2_Release(void *ptr) {
p4.show();
currentpage=4;
void p4_b1_Release(void *ptr) {
p3.show();
currentpage=3;
void p4_b3_Release(void *ptr) {
p3.show();
currentpage=3;
//void do_every_so_often() {
// myInt = (myInt + 1) % 101;
// p0_n0.setValue(myInt);
pinMode(voltageSensorPin, INPUT);
pinMode(voltageSensorPin2, INPUT);
pinMode(analogInput, INPUT);
nexInit();
p0_p1.attachPop(p0_p1PopCallback);
p0_p2.attachPop(p0_p2PopCallback);
p0_p3.attachPop(p0_p3PopCallback);
p0_b0.attachPop(p0_b0_Release, &p0_b0);
p1_b0.attachPop(p1_b0_Release, &p1_b0);
p2_b0.attachPop(p2_b0_Release, &p2_b0);
p3_b1.attachPop(p3_b1_Release, &p3_b1);
p3_b2.attachPop(p3_b2_Release, &p3_b2);
p4_b1.attachPop(p4_b1_Release, &p4_b1);
p4_b3.attachPop(p4_b3_Release, &p4_b3);
Serial2.begin(9600);
//dbSerial.begin(9600);
uint8_t active_page = 0;
int currentpage = 0;
lora.init();
lora.setDeviceClass(CLASS_A);
lora.setDataRate(2);
lora.setAccessKey("aa5531c60d6c9e1d:11aee152dcec42ee");
lora.setDeviceId("7a2b62ef");
/////MAPFLOAT
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
float mapfloat2(float x2, float in_min2, float in_max2, float out_min2, float out_max2)
return (x2 - in_min2) * (out_max2 - out_min2) / (in_max2 - in_min2) + out_min2;
float mapfloat3(float x3, float in_min3, float in_max3, float out_min3, float out_max3)
return (x3 - in_min3) * (out_max3 - out_min3) / (in_max3 - in_min3) + out_min3;
void HMICommandEnd() {
Serial2.write(0xff);
char myStr2[175];
char x[6], y[6], v[6], z[6], u[6], r[6];
char outStr[200];
int recvStatus = 0;
nexLoop(nex_listen_list);
if(millis() >= next) {
next = millis()+500;
//do_every_so_often();
//////////ACS712 20A1
int adc = analogRead(A4);
float voltage2 = adc * 5 / 1023.0;
float current2 = (voltage2 - 2.5) / 0.100;
//////////ACS712 5A
int adc2 = analogRead(A5);
float voltage3 = adc * 5 / 1023.0;
float current3 = (voltage3 - 2.5) / 0.185;
///////////POWER 1
float power1 = vin60 * robojax.getCurrent();
///////////POWER 2
float power2 = vIn * current2;
///////////POWER 3
float power3 = vIn2 * current3;
if (currentMillis - previousMillis > interval) {
/////12 VOLT1
voltageSensorVal = analogRead(voltageSensorPin); // read the current sensor value (0 - 1023)
vOut = (voltageSensorVal / 1024) * vCC; // convert the value to the real voltage on the analog pin
vIn = vOut * factor; // convert the voltage on the source by multiplying with the factor
bat_percentage = mapfloat(vIn, 11.5, 12.65, 0, 100);
if (bat_percentage >=100)
bat_percentage = 100;
if (bat_percentage <= 0)
bat_percentage = 1;
//////12 VOLT1
///////60 VOLt
value= analogRead(analogInput);
vout60 = (value*4.9735)/1023.0;
vin60 = vout60/(R2/(R1+R2));
vin60 = vin60 - correctionfactor;
bat_percent3 = mapfloat3(vin60, 52.50, 65.00, 0, 100);
if (bat_percent3 >=100)
bat_percent3 = 100;
if (bat_percent3 <= 0)
bat_percent3 = 1;
//////////12 VOLT2
voltageSensorVal2 = analogRead(voltageSensorPin2); // read the current sensor value (0 - 1023)
vOut2 = (voltageSensorVal2 / 1024) * vCC2; // convert the value to the real voltage on the analog pin
vIn2 = vOut2 * factor2; // convert the voltage on the source by multiplying with the factor
bat_percentage2 = mapfloat2(vIn2, 11.5, 12.65, 0, 100);
if (bat_percentage2 >=100)
bat_percentage2 = 100;
if (bat_percentage2 <= 0)
bat_percentage2 = 1;
/////////CURRENT1
curr1 = float(robojax.getCurrent(),2);
Serial.print("Current: ");
Serial.print(robojax.getCurrent(),2); // print the current with 3 decimal places
Serial.println("A");
Serial.print("\n");
//robojax.debug();
//////////CURRENT2
Serial.print("Current2: ");
Serial.print(current2,2);
Serial.print("\n");
//////////CURRENT3
Serial.print("Current3: ");
Serial.print(current3,2);
Serial.print("\n");
///////////POWER 1
Serial.print("Power1: ");
Serial.print(power1);
Serial.println("W");
Serial.print("\n");
///////////POWER 2
Serial.print("Power2: ");
Serial.print(power2);
Serial.print("\n");
///////////POWER 3
Serial.print("Power3: ");
Serial.print(power3);
Serial.print("\n");
Serial.print("60Batt V= ");
Serial.println(vin60,2);
Serial.print("Percentage= ");
Serial.print(bat_percent3);
Serial.println(" %");
Serial.print("\n ");
Serial.print("12Batt1 V: ");
Serial.print(vIn);
Serial.println(" V");
Serial.print(bat_percentage);
Serial.print("12Batt2 V: ");
Serial.print(vIn2);
Serial.print(bat_percentage2);
Serial.print("\n");
dtostrf(vIn, 2, 1, x);
dtostrf(bat_percentage, 2, 0, y);
dtostrf(vIn2, 2, 1, v);
//dtostrf(bat_percentage2, 2, 0, w);
dtostrf(vin60, 2, 1, z);
//dtostrf(bat_percent3, 2, 0, t);
dtostrf(curr1, 2, 1, u);
dtostrf(current2, 2, 1, r);
sprintf(myStr2, "{\"1\":%s, \"2\":%s, \"3\":%s, \"4\":%s, \"5\":%s, \"6\":%s}",
x, y, v, z, u, r, counter);
Serial.println(myStr2);
lora.sendToAntares((unsigned char *)myStr2, strlen(myStr2), 0);
recvStatus = lora.readData(outStr);
if (recvStatus) {
Serial.println(outStr);
lora.update();
/////NEXTION
if(currentpage==0){
int newbat = bat_percentage;
if (newbat > prevbat_percent + 2){
Serial.println("Charging");
prevbat_percent = newbat;
millisNow = millis();
p0_p2.setPic(7);
currentpage=0;
else {
p0_p1.setPic(6);
if(millis() - newbat > 3000){
newbat = millis();
if (bat_percentage<=20){
Serial.println("Low");
// p2.show();
//currentpage=2;
p0_p3.setPic(8);
else {
p0_p1.setPic(6);
Serial.print("\n");
//String voltin = "n1.val=\""+String(vIn,4)+"\"";
//Serial2.print(voltin);
Serial2.print("t1.txt=\"");
Serial2.print(vIn);
Serial2.print("\"");
nexSerial.write(0xff);
Serial2.print("t2.txt=\"");
Serial2.print(vIn2);
Serial2.print("t3.txt=\"");
Serial2.print(vin60);
Serial2.print("t0.txt=\"");
Serial2.print(bat_percentage);
Serial2.print("t4.txt=\"");
Serial2.print(bat_percentage2);
Serial2.print("t5.txt=\"");
Serial2.print(bat_percent3);
Serial2.print("t6.txt=\"");
Serial2.print(curr1);
Serial2.print("t7.txt=\"");
Serial2.print(power1);
Serial2.print("t8.txt=\"");
Serial2.print(current2);
Serial2.print("t9.txt=\"");
Serial2.print(power2);
Serial2.print("t10.txt=\"");
Serial2.print(current3);
Serial2.print("t11.txt=\"");
Serial2.print(power3);
HMICommandEnd();
if(currentpage==1){
Serial2.print(vIn);
HMICommandEnd();
if(currentpage==2){
Serial2.print(vIn);
HMICommandEnd();
if(currentpage==3){
Serial2.print(vIn);
HMICommandEnd();
if(currentpage==4){
HMICommandEnd();
delay(5000);
why the nexPage, Nexbutton etc. always error ? althought the nextion libraries has installed. I hope in this forum guys for my final project.
