Hello!
I'd be happy to help you configure the TFT_eSPI library for your NUCLEO-L452RE-P development board and GFX01M2 LCD screen. Below is a step-by-step guide on how to set up the library parameters.
Step-by-Step Configuration for TFT_eSPI Library
- Install the TFT_eSPI Library: Make sure you have installed the TFT_eSPI library in your Arduino IDE. You can install it from the Library Manager.
- Locate the
User_Setup.h
File: Navigate to the TFT_eSPI library folder and find the User_Setup.h
file. This is where you will define the parameters for your specific hardware.
- Define the Display Driver: Add the following line to define the ILI9341 driver, which is used by the GFX01M2 screen:
cpp
Copy code
#define ILI9341_DRIVER
- Pin Definitions: Define the pin connections between your NUCLEO-L452RE-P board and the GFX01M2 screen. Update the following lines with your actual pin numbers:
cpp
Copy code
#define TFT_CS PA4 // Chip select control pin
#define TFT_DC PA1 // Data Command control pin
#define TFT_RST PA0 // Reset pin (could connect to Arduino RESET pin)
#define TFT_MOSI PA7 // SPI MOSI
#define TFT_SCLK PA5 // SPI Clock
#define TFT_MISO PA6 // SPI MISO (not used by most displays)
- SPI Frequency: Set the SPI frequency to match your hardware capabilities. For example:
cpp
Copy code
#define SPI_FREQUENCY 27000000 // 27 MHz
- Additional Settings: Depending on your setup, you might need to adjust the following parameters:
cpp
Copy code
#define LOAD_GLCD // Font 1. Original Adafruit 8 pixel font needs ~1820 bytes in FLASH
#define LOAD_FONT2 // Font 2. Small 16 pixel high font, needs ~3534 bytes in FLASH, 96 characters
#define LOAD_FONT4 // Font 4. Medium 26 pixel high font, needs ~5848 bytes in FLASH, 96 characters
#define LOAD_FONT6 // Font 6. Large 48 pixel font, needs ~2666 bytes in FLASH, only characters 1234567890:-.apm
#define LOAD_FONT7 // Font 7. 7 segment 48 pixel font, needs ~2438 bytes in FLASH, only characters 1234567890:-.
#define LOAD_FONT8 // Font 8. Large 75 pixel font needs ~3256 bytes in FLASH, only characters 1234567890:.
#define LOAD_GFXFF // FreeFonts. Include access to the 48 Adafruit_GFX free fonts FF1 to FF48 and custom fonts
- Verify and Upload: After updating the
User_Setup.h
file, verify the configuration by compiling and uploading a simple TFT_eSPI example sketch to your NUCLEO-L452RE-P board.
Example Configuration
Here’s an example User_Setup.h
configuration for your NUCLEO-L452RE-P and GFX01M2:
cpp
Copy code
// Setup for NUCLEO-L452RE-P with GFX01M2 (ILI9341 driver)
If you encounter any issues or need further assistance, feel free to ask!
Good luck with your project!
Best Regards - Emily James | Custom Manufacturer
