So I got these esp8266 wifi shields and im trying to connect them to the wifi in order to have them receive mqtt messages from my pi.
And I followed this tutorial to get it connected to my network:
Im following this tutorial to send it mqtt messages:
I can send messages to the Arduino and I see the logs in the serial monitor but for some reason there is no voltage across either pin 3 and ground or pin 4 and ground. I’ve added logs inside the ifs so I know they’re getting called properly but voltage.
I get the raising and lowering logs in the serial monitor when I send the mqtt messages.
Here’s my code:
#include <EEPROM.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>
//#include <Adafruit_INA219.h>
#define in1 3 //We are not using PWM for this demo.
#define in2 4
// Connect to the WiFi
const char* ssid = "myssid";
const char* password = "mypwd";
IPAddress mqtt_server(192, 168, 1, 113);
WiFiClient espClient;
PubSubClient client(espClient);
const byte ledPin = 0; // Pin with LED on Adafruit Huzzah UNNECESSARY
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
char receivedChar = (char)payload[i];
Serial.print(receivedChar);
if (receivedChar == '0')
// ESP8266 Huzzah outputs are "reversed"
raiseCurtain();
digitalWrite(ledPin, HIGH);
if (receivedChar == '1')
lowerCurtain();
digitalWrite(ledPin, LOW);
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266 Client")) {
Serial.println("connected");
// ... and subscribe to topic
client.subscribe("curtainStatus");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup(){
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(ledPin, OUTPUT);//UNNECESSARY
setupMotor();
void setupMotor(){
//set the pins for output
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
//set the pins low - this will keep the motor from moving.
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
void raiseCurtain() {
Serial.println("raising curtains");
//Spin Motor in one direction UP
digitalWrite(in1, HIGH);
delay(5000); //let it spin for about 10 seconds
void lowerCurtain() {
Serial.println("lowering curtains");
//Spin Motor in the other direction DOWN
digitalWrite(in2, HIGH);
//Stop the motor
void loop(){
if (!client.connected()) {
reconnect();
client.loop();
