can someone that knows what theyre doing please confirm that thisexample compiles?
The code that you did not post does not compile
(deleted)
UKHeliBob:
when i opened an issue at the git my response was
"If you want to use the examples shown in in the latest git here, you have to install latest git of the core, not the release."
im not sure what this means but i installed gitbash and copied the command they posted on their read me overwrote the version downloaded with board manager and i still get an error but it just says cant compile for generic esp.
i cant figure out if im just not following the directions? right or if there really is a problem with something else
sorry the code disappeared it was suppose to be an embedded link i fixed the link anyways. this is directly off their github
This sketch shows how to handle HTTP Digest Authorization.
Written by Parham Alvani and Sajjad Rahnama, 2018-01-07.
This example is released into public domain,
or, at your option, CC0 licensed.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
const char* ssid = "SSID";
const char* ssidPassword = "PASSWORD";
const char *username = "admin";
const char *password = "admin";
const char *server = "http://httpbin.org";
const char *uri = "/digest-auth/auth/admin/admin/MD5";
String exractParam(String& authReq, const String& param, const char delimit) {
int _begin = authReq.indexOf(param);
if (_begin == -1) {
return "";
return authReq.substring(_begin + param.length(), authReq.indexOf(delimit, _begin + param.length()));
String getCNonce(const int len) {
static const char alphanum[] =
"0123456789"
"ABCDEFGHIJKLMNOPQRSTUVWXYZ"
"abcdefghijklmnopqrstuvwxyz";
String s = "";
for (int i = 0; i < len; ++i) {
s += alphanum[rand() % (sizeof(alphanum) - 1)];
return s;
String getDigestAuth(String& authReq, const String& username, const String& password, const String& uri, unsigned int counter) {
// extracting required parameters for RFC 2069 simpler Digest
String realm = exractParam(authReq, "realm=\"", '"');
String nonce = exractParam(authReq, "nonce=\"", '"');
String cNonce = getCNonce(8);
char nc[9];
snprintf(nc, sizeof(nc), "%08x", counter);
// parameters for the RFC 2617 newer Digest
MD5Builder md5;
md5.begin();
md5.add(username + ":" + realm + ":" + password); // md5 of the user:realm:user
md5.calculate();
String h1 = md5.toString();
md5.begin();
md5.add(String("GET:") + uri);
md5.calculate();
String h2 = md5.toString();
md5.begin();
md5.add(h1 + ":" + nonce + ":" + String(nc) + ":" + cNonce + ":" + "auth" + ":" + h2);
md5.calculate();
String response = md5.toString();
String authorization = "Digest username=\"" + username + "\", realm=\"" + realm + "\", nonce=\"" + nonce +
"\", uri=\"" + uri + "\", algorithm=\"MD5\", qop=auth, nc=" + String(nc) + ", cnonce=\"" + cNonce + "\", response=\"" + response + "\"";
Serial.println(authorization);
return authorization;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, ssidPassword);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
HTTPClient http;
WiFiClient client;
Serial.print("[HTTP] begin...\n");
// configure traged server and url
http.begin(client, String(server) + String(uri));
const char *keys[] = {"WWW-Authenticate"};
http.collectHeaders(keys, 1);
Serial.print("[HTTP] GET...\n");
// start connection and send HTTP header
int httpCode = http.GET();
if (httpCode > 0) {
String authReq = http.header("WWW-Authenticate");
Serial.println(authReq);
String authorization = getDigestAuth(authReq, String(username), String(password), String(uri), 1);
http.end();
http.addHeader("Authorization", authorization);
if (httpCode > 0) {
String payload = http.getString();
Serial.println(payload);
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
delay(10000);
I installed the latest released ESP8266 core and tried to compile for Generic ESP8266. The compile failed but I was able to get it to succeed by changing two lines:
// http.begin(client, String(server) + String(uri)); ///// Removed
http.begin(String(server), 80, String(uri)); ////// Added
I can't be sure that the lines I inserted do the same as the lines I removed, but at least it compiles without errors.
