Confused re C/C++, "Wiring" and "Process" langauges
I know C/C++ very well. But I don't understand the purpose behind the Wiring and Process languages. I read info about them on the web, but I can't understand what they have that is very different from from C/C++. Can you someone summarize?
Processing is based on Java, so is quite different to Wiring, which is based on C/C++.
They're essentially a set of libraries with make things easier for beginner programmers. I've heard people saying that "programming in qt" is like a different language, and arduino/wiring/processing is kind of the same way.
And Java is sort of C-like, except where it's not...
AWOL:
That's not really helpful. Why would I use the Process or Wiring languages?
You would use Processing in the Processing IDE on your PC, to do PC things (capture images, play audio, do graphics, run a GUI...), and you would use Wiring on your Arduino to do Arduino things (toggle outputs, read analogue inputs, control PWM outputs, read/write SD cards, EEPROM...).
The Arduino isn't powerful enough to run Java, so you can't run Processing on your Arduino.
AWOL:
Ahhh, now I understand. That makes perfect sense.
Thank you.
