Hi all. I am attempting to make a SEN-30007-K function with my R3 UNO. I have grabbed the three required files from the Github, and wired my boards yet im seeing no results in my serial monitor that are accurate. Could this be an issue with the ICSP wiring as there is no offical pinout given by PlayingWithFusion or some other wiring problem. IF anyone has an input I would much appreciate it!
The web page says that the board is an Arduino UNO shield. If that is correct, then there shouldn't be an issue with the SPI interface using the ICSP 6-pin header.
Understood, I will attempt to connect directly to the ICSP header, if this proves unsuccessful what can the reason this issue is occuring be broken down to?
