system
November 5, 2012, 10:01pm
1
Can I connect 4, 12v DC motors to arduino Uno?
What is motor driver ?
I read that the UNO board have 6 pwm, that mean that I can connect 6 motors, or two?
If I understand the pwm connect to motor driver and than the motor driver control the motor by extranl power source?
And I saw that most of the motor drivers can handle up to 2A, what I can do if the motor needs more than 2A ?
system
November 6, 2012, 12:18am
2
1)yes, with a motor driver
2)Something that allows you to control a motor (this may work: http://www.vexrobotics.com/276-2193.html )
3)With #2 yes, but you can do more with a bunch of h-bridges(eg.http://www.ecelab.com/circuit-motor-control-2.htm )
dc42
November 6, 2012, 8:44am
3
Do you need to run the motors in one direction only, or in forward and reverse?
If in one direction only, then it's easy, you can control each one using a mosfet driven from a PWM pin.
If in both directions then you need an H-bridge per motor. There are dual H-bridge chips available. Pololu makes good motor controllers, for example this dual motor controller Arduinio shield: http://www.pololu.com/catalog/product/2503 .
system
November 6, 2012, 10:03am
4
thanks for the replies
i need to run the motors both forward and reverse,
the motor current is 7.75A at full load and 12v, so i will need something that support up to 8A, do you know something like this?
(this is the motors that use : http://www.ebay.com/itm/RS-550PH-Motor-12V-DC-14-100-RPM-High-Power-550-Size-DC-Motor-Nichibo-/280976231186?pt=LH_DefaultDomain_0&hash=item416b7d0b12 )
there is a motor shield the can move the motors both forward and reverse and can support 12v (from extrnal power source) and 8A ?
dc42
November 6, 2012, 10:09am
5
Go to www.pololu.com and search for "motor driver". This dual one Pololu - Dual VNH2SP30 Motor Driver Carrier MD03A may be suitable.
cr0sh
November 7, 2012, 1:53am
6
IdanAbutbul:
8A isn't enough, IMHO - I would personally go for something around 10A...
system
November 10, 2012, 8:23am
7
cr0sh:
IdanAbutbul:
Ok, and what is Stall Current 60A, Means?
dc42
November 10, 2012, 8:52am
8
It means that when the motors start up from standstill, they will each draw 60A. Also if the motor is prevented from rotating, it will try to draw 60A.
I suggest you choose a motor controller with built-in current limiting, to constrain the startup current to a more reasonable value. It's possible to use the Arduino itself to do the current limiting if you choose a motor controller with current sensing, but then you need to get the software right or you risk damaging something.
