Connect 6 Sensirion SFM3013 Gas Flow Sensors to an Arduino
Continuing the discussion from Using PCA9548A multiplexer for multiple Sensirion SFM3003 gas flow sensors:
Hi @ajaysinghredhu,
Our team is attempting to connect 6 Sensirion SFM3013 Gas Flow Sensors to an Arduino to get a reading. We understand that this requires a multiplexer, and the datasheet for the component states the requirement to use 3.3kW pull up resistors. Do these resistors need to be attached to both the SDL and SCL ports for each Mass flow meter that attach to the multiplexer? Are there any other components that we need to consider?
Please start your own topic.
Lol, those would be some mighty resistors! Of course, you meant 3.3K Ohm.
Yes, you will need a pair for each of the secondary busses you are using. A pair for the main bus is also good (it often works without pull-ups on the main bus because the Arduino uses it's internal pull-up resistors, but those are much weaker than the recommended values).
These resistors can be low power, eg. 1/4 Watt or 1/8 Watt
I split the posts to a dedicated topic as requested.
@shikhar2499 in the future please create a dedicated topic for your support requests. Replies to existing topics should serve to add to the original discussion. The reason is that it may sidetrack the discussion, even preventing the creator of the topic from getting the assistance they need. It also reduces your own chances of getting assistance.
This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
