hello all.
i am trying to connect 2 nodemcu esp32 via rs485 modules but its not working. the esp32 and modules are connected in the following diagram:
the code used is the following:
#include <Arduino.h>
#define RXD2 16
#define TXD2 17
#define CTD2 22
Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
Serial.println("Begin Software...");
Serial.println("Serial Txd is on pin: " + String(TX));
Serial.println("Serial Rxd is on pin: " + String(RX));
Serial.flush();
pinMode(CTD2, OUTPUT);
digitalWrite(CTD2, LOW);
while (Serial2.available())
int size = Serial2.available();
String data = Serial2.readStringUntil('\n');
Serial.println("RECEIVED: ");
Serial.println(data);
if (Serial.available())
String data = Serial.readString();
Serial.print("Sending: ");
digitalWrite(CTD2, HIGH);
Serial2.println(data);
N.B first i tested this code (without the transmission pin "22") on a normal uart communication without rs485 and it was working fine. what can be the problem?
thanks in advance
