Hello, i can't find a schematics proven to work with a device which is not 5v tolerant. Can someone tell me how i should do that?
Many thanks!
Many thanks!
Transmit from 3v3 device to 5v device just connect up.
Transmit from 5v device to 3v3 device, through two resistors forming a potential divider, 1K8 in the top and 3K3 in the bottom.
Thanks for your answer, did you already give it a try with an arduino promini or with another arduino? Can it be kept like this in the long term?
Will it affect transmission speeds?
So that's how you would do it:
5v Pro mini 3.3v serial
GND ---------------- GND
Tx ---1K8---3K3--- Rx
RX ------------------ Tx
Can you confirm? it would mean that the arduino pro mini understands the 3.3v logic on Rx!?
What is strange is that i different way to do that, some use a 1N4148 and a 330R on both Rx and Tx, but nothing really proven to work.
Many thanks
Yes.
No, there are no capacitors in the circuit that is the only thing that would affect the transmission speed.
No
TX --- 1K8 --- Rx & 3K3 --- ground
There is sufficient voltage on the 3V3 output for the 5V input to recognise it as a logic one.
In electronics there are often many ways to solve a problem, this is none of them. The advantages of simplicity are balanced against the fact that the noise margin is worse and the impedance is higher. However it will work. Do you want to do it cheap or right?
I have used this technique for converting logic levels but not used it in this specific configuration. This should not be a concern of yours.
I really appreciate your answer, i'm not quite familiar with electronic, and your answer really help me.
Just to make sure, the layout should be the following:
GND ------3K3------ GND
Tx --------1K8------ Rx
Sorry if its obvious i don't want to fry the boards.
Regards
No read again my previous answer.
Read about a potential divider
don't put resistors in the grounds EVER
Thanks, i think i got it!
Tx ---1K8----3K3-- GND
--------- Rx
right?
bump?
i don't know what's bump. But your circuit is what he was talking bout
thanks a lot!
