Connect to PMC - PLC IDE
I can see COM6,7. I tried 2x reset, changed cable, port. I's a mess. It can't be this complicated.
IDE hangs after a while, cant stop it.
Try and contact Arduino Pro Support via Contact us with all the details of the issue.
Hello has this issue been resolved ?
I seem to have the same problem. I can download the sketch for first setup and re-initialization, without errors, but as soon as i want to connect to the PMC (via the button connect) the PLC IDE gets stuck and wont respont to any commands.
The blinking LED Upload from the regular Arduino IDE seems to be working perfectly fine.
Good afternoon,
Were you able to solve the problem? I'm going crazy with the topic, I can load the first sketch from the normal Arduino IDE and also from the PLC IDE, but then, although it finds the ports, it is not able to connect to any of them.
Hello All,
In Arduino IDE, please upload the sketch mentioned in the following tutorial https://docs.arduino.cc/tutorials/opta/memory-partitioning#partitioning-memory-of-an-opta-device. At the end you should see a success message in the serial monitor.
Then, open PLC IDE and follow this tutorial https://docs.arduino.cc/software/plc-ide/tutorials/plc-ide-setup-license/. Your Portenta Machine Control should be connected successfully.
Best,
@Hm_pro THANKS. it also works with the Opta.
