Connect to the RTL SDR
Hello Greetings!
I'm trying to build an ADS_B receiver, the ones that are used in planes but just a portable version of it. After googling for a while I came to know that RTL USB dongles can be configured to receive the ADS-B signals. So I decided to get this one:
https://a.co/d/cQiLBm9
And after searching more I came to know that it can't be accessed through a micro controller but needs higher processing power such as RPi. But then again I came across something on the Youtube which shows a teardown of a similar product in the market called SENTRY here's the link for it:
https://www.youtube.com/watch?v=UuHVWDl4YzU
Surprisingly it is designed around ESP12S. So I started wondering if my ADS-B can be built using ESP32Wroom32D? I mean it is more advanced than ESP12S. So I tried to look for some examples but couldn't see any.
So, is it possible to use ESP32Wroom32D and program it in Arduino to receive and process the ADS-B signals?
That is not a "receiver". What are you really trying to do? Post spam?
Sorry, I can't help, my LKY doesn't respond to my PPZ.
Not a spam. Why would I even do that?
Here:
https://www.amazon.com/dp/B07MV68BJH?ref_=cm_sw_r_cp_ud_dp_ZFGSB6VEEF9BDA4A2NXQ
If you would have tried to access it you would have been given the same link .
Great question! If it is not spam, why would you post a link to a USB 3.0 female to female cable adapter, rather than a receiver?
OOps Sorry. I bought that alongwith the RTL Dongle hooping that I might need it and I accidentally pasted the same link here.
Here's the dongle:
https://www.amazon.com/dp/B011HVUEME?encoding=UTF8&psc=1&ref=cm_sw_r_cp_ud_dp_NZEDBQPG7A89D6KDMZXJ
So all the replies were just to be sarcastic and point out my mistakes in the link I shared?
No replies after putting up the correct links?
Not sure if you can do easily with Arduino boards but there are multiple RTL projects on Raspberry Pi boards.
