I am using Ameba RTL8195 modules. 1 module connects to sensors to get measurements in an outdoor environment. I want to get these readings to another module connected to PC. Is there any guidance available to connect these modules. Datasheet is available below:
I want to establish peer to peer communication between these 2 ameba devices, whereby, the one in the outdoor environment sends the measurements to the one indoor connected to the PC via usb. What is the way forward please ?
You've already defined that - serial. Incorrectly, in my opinion. Sending data over wires, from outdoors to indoors, hardly makes sense.
In any case, I don't understand what the problem is. If you ARE going to use Serial, you connect the TX pin of one device to the RX pin of the other, and you connect the grounds, and you use Serial.print(), Serial.println(), or Serial.write() to send the data, and Serial.available() and Serial.read() to get the data.
I apologise for not describing well the problem. I want to transmit the measurements wireless to indoor device be it any method. Then the indoor connected device's serial monitor should be able to display all those measurements taken outdoor.
If those ARE WiFo devices, wouldn't it be simpler to make one a server (the indoor one) and one a client? Then, the client just makes a GET request with the data, and the server handles the GET request.
I don't see the relationship between those things and Arduino.
Im trying to make one Ameba as server, but getting an error message.
/* Connects to the home WiFi network
* Asks some network parameters
* Starts WiFi server with fix IP and listens
* Receives and sends messages to the client
* Communicates: wifi_client_01.ino
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "mynetwork"; // SSID of your home WiFi
char pass[] = "myPassword"; // password of your home WiFi
int status = WL_IDLE_STATUS;
byte ledPin = 2;
WiFiServer server(80);
IPAddress ip(192,168,1,3); // IP address of the server
IPAddress gateway(192,168,1,1); // gateway of your network
IPAddress subnet(255,255,255,0); // subnet mask of your network
Serial.begin(9600); // only for debug
WiFi.config(ip, gateway, subnet); // forces to use the fix IP
WiFi.begin(ssid, pass); // connects to the WiFi router
Serial.print(".");
server.begin(); // starts the server
/* Serial.println("Connected to wifi");
Serial.print("Status: "); Serial.println(WiFi.status()); // some parameters from the network
Serial.print("IP: "); Serial.println(WiFi.localIP());
Serial.print("Subnet: "); Serial.println(WiFi.subnetMask());
Serial.print("Gateway: "); Serial.println(WiFi.gatewayIP());
Serial.print("SSID: "); Serial.println(WiFi.SSID());
Serial.print("Signal: "); Serial.println(WiFi.RSSI());
Serial.print("Networks: "); Serial.println(WiFi.scanNetworks());*/
pinMode(ledPin, OUTPUT);
void loop () {
WiFiClient client = server.available();
if (client) {
if (client.connected()) {
digitalWrite(ledPin, LOW); // to show the communication only (inverted logic)
Serial.println(".");
String request = client.readStringUntil('\r'); // receives the message from the client
Serial.print("From client: "); Serial.println(request);
client.flush();
client.println("Hi client! No, I am listening.\r"); // sends the answer to the client
digitalWrite(ledPin, HIGH);
client.stop(); // tarminates the connection with the client
sketch\wifi_server_01.ino.cpp.o: In function `setup':
C:\Users\eng.EEPROJ-DP.000\Downloads\wifi_server_01/wifi_server_01.ino:21: undefined reference to `WiFiClass::config(IPAddress, IPAddress, IPAddress)'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "WiFi.h"
Used: C:\Users\eng.EEPROJ-DP.000\AppData\Local\Arduino15\packages\realtek\hardware\ameba\2.0.4\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Error compiling for board Ameba RTL8195A.
option enabled in File -> Preferences.
You need to take this up with the (I'm trying to use a politically correct term here, but really don't want to) at ameba. There is NO excuse for them building a class with the same name as the Arduino-provided WiFi library, when it operates on different hardware.
