Connecting a 4-20 mA pressure transductor
Hi everyone,
I'm new using arduino. And for my beginning i would like to make a air pressure control, but Arduino Uno has analogic inputs 0-5 Volts type and my pressure trasductor has an output 4-20 mA type and need to be feeded with 24 Vdc.
I´m not sure if there is any way to make this works.
Regards.
Hi sebastianc
These may help:
http://forum.arduino.cc/index.php/topic,21813.0.html
http://forum.arduino.cc/index.php/topic,167973.0.html
http://forum.arduino.cc/index.php/topic,105703.0.html
Regards
Ray
http://www.industrologic.com/aninput.htm
As simple as 24V to the sensor, and a 250 ohm resistor between the sensor and ground. The voltage dropped across a 250 ohm resistor from 4 to 20mA is 1V to 5V.
A 220 ohm resistor and a 100 ohm potentiometer can trim it to 5V at 20mA.
There are more complex ways to remove the offset.
