i'm a total newbie to arduino. i've allready read some guides and searched the forum but i still can't get the thing to work. (arduino min as board is choosen, com3 as well - check in the device manager, programmer: avrisp mk2)
This is the error i get when i try to upload a sketch:
Arduino: 1.6.3 (Windows 7), Board: "Arduino Mini, ATmega328"
Sketch uses 18,486 bytes (64%) of program storage space. Maximum is 28,672 bytes.
Global variables use 607 bytes (29%) of dynamic memory, leaving 1,441 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3d
so, what have i done so far:
i've connected the USB serial light adapter to the arduino mini:
gnd->gnd
5v->5v
rx->rx
tx->tx
is that sufficient? somehwere i've read that if you don't connect the reset pin the mini resets randomly?
Press reset on the Mini when the IDE shows
"compiled xxx of 32xxx bytes" or similar
to kick off the bootloader so the mini is looking for the programming message coming in.
Yeah, i took a look at that guide. Thats the reason i was wondering if i obligatory have to connect the reset or not. So not connecting the reset via a capacitor prevents the mini from communicating with the programmer?
certhas:
Not connecting the reset via a capacitor and not manually reseting at the right time prevents the programmer from communicating with the bootloader on the Mini. If the programmer does not send a request to the bootloader in the short time after reset that the bootloader is looking for commands then the bootloader goes on to running the last sketch that was uploaded. After that the programmer has missed the opportunity to communicate with the bootloader.
Ok, now i did it like in the tutorial. Soldered a 0,1microF capacitor between the reset of the usb programmer and the arduino mini and soldered a led to the pin13.
The Led is blinking 3 times when i connect it to the pc, and then blinking 3 times very fast every 10sec or so.
But i still cant upload a sketch. Could the mini be broken? Or is there something else i might be missing? Here's a pic
Gnah, im really stupid.
I've assumed that TX is connected to TX and RX to RX. Logically a reciever cant recieve anything from another reciever and a transmitter cant recieve something...
After soldering TX to RX it worked.
Now you can slap me
