Hi
I have an ATMega2560 16U-IH chip connected to an FT232RL FTDI chip which is then connected to my PC. From the PC, I am able to see the FTDI chip but unable to communicate with the ATMega2560 chip.
The wiring:
PC (USB) -> FTDI chip: - see attached image
+5v (red USB wire) to Pin 20 (VCC). Also a 0.1uf non-polarised capacitor to GND and 10uf polarised capacitor to GND
GND (black USB wire) to Pin 7, 18, 21, 25 & 26 (GND)
D+ (green USB wire) to Pin 15 (USBDP)
D- (white usb wire) to Pin 16 (USBDM)
FTDI chip to ATMega2560 chip - see attached image
Pin 1 (TXO) to Pin 2 (PE0)
Pin 5 (RXD) to Pin 3 (PE1)
The ATMega2560 is also powered from the USB +5v and GND (power is getting to the ATMega2560 chip).
Is there anything I am missing here that would stop this from working?
In what sense? Not able to upload? Or a loaded sketch can't communicate with the PC?
Did you design your own board? If so, schematic please.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advise on) your project
See About the IDE 1.x category.
Unable to upload (it has a sketch already on the board which is also unable to speak to the PC).
Thanks BS
TX - Rx & RX to TX
Looks like you have RX to RX and TX to TX
I have:
FTDI 1 (TX) to ATMega2560 PE0 (Pin 2 - RX)
FTDI 5 (RX) to ATMega2560 PE1 (Pin 3 - TX)
Thanks BS
To elaborate:
I have installed the FTDI driver and I can see it under Ports in Device Manager (Windows) and ttyUSB0 in Linux.
I am (trying to) communicating with the ATMega2560 chip via the FTDI via serial in a program I've written in C. I can successfully connect to and communicate with an Arduino Mega (uses the same ATMega2560 chip) using my program and a program uploaded to the Arduino.
The ATMega2560 chip I am trying to communicate with has this same program burned to it.
@nickgammon
I am using your bootloader sketch and I get multiple verification errors (see attached .pdf
bootloadererror.pdf (80.3 KB)
file).
I am using a 0.1uf ceramic capacitor between VCC/AVCC and GND very close to the chip.
Thanks BS
