Hello there,
I'm pretty new to all kind of hardware programming, but I wanted to try something. So I decided to buy an Andruino UNO and an ESP8266. I followed many of the tutorials you can find on the internet and connected the modules as explained. Everything starts up and seems to be working. But as soon as I send some AT commands via serial monitor, my ESP responding with non readable Text.
So I configurated my softwareserial with all kinds of baud rates but none of it worked. At least 115200 provides some readable content. I attached a screenshot of my serial monitor.
Here is the code I'm using to send AT commands.
Software serial multple serial test
Receives from the hardware serial, sends to software serial.
Receives from software serial, sends to hardware serial.
The circuit:
* RX is digital pin 10 (connect to TX of other device)
* TX is digital pin 11 (connect to RX of other device)
Note:
Not all pins on the Mega and Mega 2560 support change interrupts,
so only the following can be used for RX:
10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
Not all pins on the Leonardo support change interrupts,
8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
created back in the mists of time
modified 25 May 2012
by Tom Igoe
based on Mikal Hart's example
This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Goodnight moon!");
// set the data rate for the SoftwareSerial port
mySerial.begin(115200);
void loop() { // run over and over
if (mySerial.available()) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
It seems the ESP reacts to my commands but the response is just rubish.
Could you pleas let me know what I can do?
Regards,
Michael
