Connecting Lifepo4 lithium Ion Battery 22AH to Arduino with 3 terminal toggle switch
Hi! Im a newbie here and a beginner to Arduino I want to ask, Can I directly connect the 9.6v Lifepo4 lithium ion battery 22AH to my arduino with 3 terminal toggle switch that was put to postive wire of 12v battery clip with adapter.
What do the switches three terminals connect? Is the 12v being divided in the switch to 9.6v on one of the terminals?
Does your switch have a center off position, or just two positions?
Yes, theres an off position in the center.
In the picture, as we can see to it I cut the positive wire of 12v battery clip then I connect the toggle switch in between.
If you use 9.6v on VIN, do not connect the Arduino USB to your computer USB.
