Hello,
I am creating a PCB that will connect to a Arduino Mini pro. Do I need to connect the header pins to the equivalent pins on the sides? For example, should the ground pins of the header be connected to "GND" like the pins on the sides that I use as ground in my circuit?
I know that the header is only used for uploading code to the Arduino, which is why I didn't think the header pins needed to be connected to anything in the schematic. I've attached my schematic, could someone confirm if its correct?
Thank you!
