Arduino Pro Mini Upload problem
Hello,
I am experiencing an issue when uploading code to an 3.3v 8MHz with a 3.3v FDTI adapter. This is the first time I have used Arduino, so please excuse any silly mistakes. Every time that I try to upload code, I encounter the following error:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x40
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x40
Failed uploading: uploading error: exit status 1
I have tried multiple solutions, but none seem to work. I can confirm that I the correct COM port selected, the processor is correct and that I using the correct FDTI. Does anybody have a possible solution?
Kind regards
TheOneAndOnly
Wiring mistake? Did you connect the DTR pin of the adapter to the reset pin of the Pro Mini?
Incorrect serial port selected in the IDE? Disconnect the FTDI adapter from the PC, check the ports in the IDE. Next connect and check the ports again in the IDE. Do you get a new port?
We have no idea what those might be :wink:
Have you tried all the processor options in Tools
For debugging, you can try a loopback test.
Disconnect the Arduino from the FTDI adapter.
Connec the RX to TX on the FTDI adapter.
Open the serial monitor and send some data.
You should receive the same data you sent.
Thank you for all of the replies!
@sterretje: Here is the wiring that I used, FDTI to Pro mini:
DTR - DTR
RXI - TXO
TXO - RXI
VCC - VCC
GND - GND
When I enter the IDE and go to Tools > Ports, I see COM1 and COM3 no matter whether the FDTI is plugged in.
I tried different computers, different cables, multiple wiring combinations, disconnecting all of the Pro Mini's electronics, Manual reset timing and a loopback test.
@sonofcy I have tried all of the processor options, yet none work
@jim-p I tried the loopback test, but it didn't echo anything. Could this mean that the FDTI Adapter is faulty?
Either it or the USB cable or you really don't have the correct port selected.
My board has an LED that blinks when I send data. If I type in a long string of characters into the serial monitor I see it blink.
In that case your adapter does not seem to be recognised. Which operating system are you using?
have you set the FTDI adapter to 3.3V
selected the appropriate Tools>Board setting
should look something like
using IDE 2.3.4
I selected the other COM port (COM3) and tried the loopback test, and it worked. I also noticed that the LED was blinking when I was doing the test. However, I tried the upload again and I got the same error message.
I am using Windows 10 Pro
Well at least you know the cable and adaptor are good.
So either the pro mini is bad or you have a wiring error between the adaptor and the pro mini
can you show photo of your setup?
and list the wiring connections?
EDIT See correction in post 23.
My favourite FTDI has only
3v3
TX
RX
GND
5V
It always works.
The FTDI RX goes to the ProMini TX and the FTDI TX goes to the ProMini RX.
Did you get drivers for the FTDI chip from https://ftdichip.com/drivers/
@sonofcy
How do you upload? Press the reset button at the right time?
Here are some pictures:
Error code:
FDTI wiring:
Pro Mini wiring:
Wiring setup:
I assumed that they would be automatically installed. How do I do so?
I just click upload, but I have tried pressing the reset button and releasing when it starts uploading.
They are when you install the IDE. Reason being that there is on board (original classic Nano) that uses the FTDI.
One way is to run the arduino.inf (right click, install) in C:\Users\yourUserName\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\drivers
The question was directed at sonofcy, not at you :wink:
Looks like your pro mini is mounted on a proto board.
Is there something else connected to the mini?
It is on a perfboard, but the cables soldered to it are either not attached or going to the FDTI
No. But maybe the BOOT pin, it's been a while since I used one. I will pull out a ProMini tonight and give it a try, perhaps I am misremembering or confusing two different things.
[quote="TheOneAndOnly, post:14, topic:1410388"]
g:
[/quote]you don't appear to have grounded the FTDI CTS pin
this is a closeup of my connections
you can see CTS is connected to GND
not sure if this is the problem?
On the Pro Mini the CTS signal is just a ground pin. Pro Mini always sends “clear to send” by grounding that pin on the FTDI adapter. You may try just connecting all 6 pins like horace does. Grounding the CTS will let the FTDI know it is OK to send to the Pro Mini. I don’t know if it matters because I always hookup like horace shows. I bought an FTDI Basic which is similar to the ones pictured except does not have all the additional pads on the sides. And the pins match up to the Pro Mini. I like to put female pins on the FTDI adapter, and male pins on the Pro Mini.
