Connecting Processing to Arduino (Serial port)
Hello, I am beginner using arduino and I would like to know how to transfer two String arrays from Processing to Arduino or some hint to do it...
In processing, I tried:
port.write(a[i]);
port.write(b[i]);
And, in Arduino, I have:
void setupVariable(){
  a=Serial.readString(); //concatenating arrays
  //Serial.println(a);
I am not familiar with Processing.
For the Arduino side have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
It makes debugging much easier if you send data in human readable form. I would only send binary data if it was the only way to achieve the required performance.
…R
marta99:
port.write(a[i]);
port.write(b[i]);
If you are going to send one byte at a time in Processing, then in the Arduino sketch you need to read one byte at a time.
char aByte = Serial.Read();
