Hi...
i'm trying to operate a philips TDA1543 DAC (http://www.datasheetcatalog.org/datasheet/philips/TDA1543.pdf), but i can't seem to get it working.
the DAC uses an I2S protocol, and therefore i cannot use the wire library.
has anyone tried this before? i've searched the forum and the internet, but i wasn't able to find a working solution.
I am using a Maple mini board (Maple | LeafLabs) which is almost identical to an arduino program-wise, except that it runs at 72 MHz, so hopefully it will be able to handle the interrupt routine.
i worked on this program, but it doesn't work...
int Rate = 10/32/16/2; //16 interrupts=1 channel... 2 channels= 1 step... 32 steps = 1 wavePeriod
// frequency=milliseconds/16/32/2 --> 1KHZ=1/16/32/2
// calls interrupt at aprox 1 MHz, which i hope a 72 MHz 32 bit microcontroller can handle
volatile int bck=30; //bit clock pin
volatile int data=27; //data pin
volatile int chan=25; //channel select pin
volatile byte pos=16;
volatile byte channel=0;
volatile byte k=16;
volatile unsigned int table[32];
arraysetup();
// Setup Timer
Timer2.setChannel1Mode(TIMER_OUTPUTCOMPARE);
Timer2.setPeriod(Rate); // in microseconds, sets the interrupt call rate
Timer2.setCompare1(1); // overflow might be small
Timer2.attachCompare1Interrupt(Clock_Out);
void arraysetup(void){
table[0]=127; // Put 32 step 8 bit sine table into array.
table[1]=152;
table[2]=176;
table[3]=198;
table[4]=217;
table[5]=233;
table[6]=245;
table[7]=252;
table[8]=254;
table[9]=252;
table[10]=245;
table[11]=233;
table[12]=217;
table[13]=198;
table[14]=176;
table[15]=152;
table[16]=128;
table[17]=103;
table[18]=79;
table[19]=57;
table[20]=38;
table[21]=22;
table[22]=10;
table[23]=3;
table[24]=0;
table[25]=3;
table[26]=10;
table[27]=22;
table[28]=38;
table[29]=57;
table[30]=79;
table[31]=103;
for (int i=0;i<32;i++)
table[i]=map(table[i],0,255,0,65535); //8 bit to 16 bit conversion
void Clock_Out(void) {
digitalWrite(bck, LOW); // bck = Bit Clock pin
pos--;
digitalWrite(data, !!(table[k] & (1 << pos))); //data= data output pin , Outputs each single bit (MSB)
if (pos=0) { //when all bits are sent it switches channel
pos=16;
channel ^=1;
digitalWrite(chan, channel); //chan= channel select pin (HIGH = right channel)
if (channel==1) { //when both channels are set it selects the next array
k++;
if (k=32) k=0;
digitalWrite(bck, HIGH); //brings the clock HIGH when all data is sent
any suggestions?
