connection error on communicationg ethernet shield with webserver
Hi all!!! I am trying to upload the code given down but this is the message i get all the time!!
IP Address 0.0.0.0
Subnet Mask 0.0.0.0
DNS Server IP 255.255.255.0
Cannot connect to Server
My code is:
#include <Ethernet.h>           //library for ethernet functions
#include <SPI.h>
#include <Client.h>             //library for client functions
#include <Wire.h>
// Ethernet settings
byte mac[] = {0x09,0xA2,0xDA,0x00,0x01,0x26};  //Replace with your Ethernet shield MAC
byte ip[4] = {192,168,1,3};  //The Arduino device IP address
byte subnet[4] = {255,255,255,0};
byte gateway[4] = {192,168,1,1};
byte DBserver[]  = {192, 168, 1, 2};
IPAddress server(192,168,1,2);                  // IP-adress of server arduino sends data to
EthernetClient client;
bool connected = false;
      Wire.begin();
        delay (1000); //allow ethernet chip time to wakeup
 Serial.print("*********************************************\n");
 Serial.print("Initializing Ethernet.");
        Ethernet.begin(mac, ip, gateway); //set static IP
 Serial.println("*********************************************\n");
  Serial.print("IP Address        : ");
  Serial.println(Ethernet.localIP());
  Serial.print("Subnet Mask       : ");
  Serial.println(Ethernet.subnetMask());
  Serial.print("Default Gateway IP: ");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("DNS Server IP     : ");
  Serial.println(Ethernet.dnsServerIP());
 if (client.connect(server, 80)) {
    Serial.println("-> Connected");
    connected = true;
          int ramdom =analogRead(A1);
          Serial.print("ramdom");
          Serial.println(ramdom);
          Serial.println("******************************************");
          Serial.println("Sending to Server: ");
          client.print("GET 192.168.1.2/te/add_data.php?t0=");
          Serial.print("GET 192.168.1.2/te/add_data.php?t0=");
          client.print(ramdom);
          Serial.print(ramdom);
          client.println(" HTTP/1.1");
          Serial.println(" HTTP/1.1");
          client.println("Host: 192.168.1.2/te/");
          Serial.println("Host: 192.168.1.2/te");
          client.println("User-Agent: Arduino");
          Serial.println("User-Agent: Arduino");
          client.println("Accept: text/html");
          Serial.println("Accept: text/html");
   else{
        Serial.println("Cannot connect to Server");
Can anybody tell me what am I doing wrong!!
Do you have an SD card in the SD card slot? If so you have to set Pin 4 to OUTPUT HIGH to keep the SD card off the SPI bus so you can talk to the Ethernet chip without interference.
