Im trying to send data from IR temperature Sensor MLX90614 to firebase database. This is my code. I added the ssl certificate of firebase and updated the firmware. Im doin Arduino since 4 das so im quite a noob but i dont know what im doing wrong.
#include <Adafruit_MLX90614.h>
#include <Wire.h>
Project: Send Data to Firebase Using Arduino Uno WiFi Rev2
Board: Arduino Uno WiFi Rev2
External libraries:
- Arduino_LSM6DS3 by Arduino V1.0.0
- Firebase Arduino based on WiFiNINA by Mobizt V1.1.4
#include <Arduino_LSM6DS3.h>
#include <Firebase_Arduino_WiFiNINA.h>
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
#define FIREBASE_HOST "console.firebase.google.com/project/ground-temp-sensor/database/ground-temp-sensor-default-rtdb/data/~2F.firebaseio.com"
#define FIREBASE_AUTH "QRGQakZj9i8PciZ4gG3I6ipmptHWUyCP7Yz2IQ19"
#define WIFI_SSID "FRITZ!Box 6490 Cable"
#define WIFI_PASSWORD "xxxxxxx"
FirebaseData firebaseData;
String path = "/MLX90614";
String jsonStr;
Serial.print("Initialize IR sensor...");
if (!mlx.begin()) {
Serial.println(" failed!");
while (1);
Serial.print("Connecting to WiFi...");
int status = WL_IDLE_STATUS;
while (status != WL_CONNECTED) {
status = WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print(".");
delay(300);
Serial.print(" IP: ");
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH, WIFI_SSID, WIFI_PASSWORD);
Firebase.reconnectWiFi(true);
float Umgebungstemperatur, Objekttemperatur;
//Ausgeben der Umgebungstemperatur in Grad Celsius
Serial.print("Umgebungstemperatur = ");
Serial.print(mlx.readAmbientTempC());
Serial.print("°C");
Serial.print("\t\t");
//Ausgeben der Tmeperatur eines Objektes in Grad Celsius
Serial.print("Temperatur des Objektes = ");
Serial.print(mlx.readObjectTempC());
Serial.println("°C");
delay(100); //eine kleine Pause von 750ms
// Send data to Firebase with specific path
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Umgebungstemperatur", Umgebungstemperatur)) {
Serial.println(firebaseData.dataPath() + " = " + Umgebungstemperatur);
if (Firebase.setFloat(firebaseData, path + "/1-setFloat/Objekttemperatur", Objekttemperatur)) {
Serial.println(firebaseData.dataPath() + " = " + Objekttemperatur);
// Push data using pushJSON
jsonStr = "{\"X\":" + String(Umgebungstemperatur,6) + ",\"Y\":" + String(Objekttemperatur,6) + "}";
if (Firebase.pushJSON(firebaseData, path + "/2-pushJSON", jsonStr)) {
Serial.println(firebaseData.dataPath() + " = " + firebaseData.pushName());
else {
Serial.println("Error: " + firebaseData.errorReason());
delay(2000);
This is my firebase data:
It always says connection refused or connection lost.
16:13:55.366 -> Initialize IR sensor...Connecting to WiFi.... IP: 192.168.178.87
16:13:58.811 ->
16:13:58.811 -> Umgebungstemperatur = 26.29°C Temperatur des Objektes = 25.79°C
16:14:47.809 -> Error: connection refused
16:14:47.809 ->
16:14:49.798 -> Umgebungstemperatur = 26.49°C Temperatur des Objektes = 26.59°C
16:15:04.055 -> Error: connection lost
16:15:04.101 ->
i would be so happy for any helpful comments. Thank you
